    MMM-CalendarExt2
    4 Posts 3 Posters 2.3k Views 4 Watching
      shfaxx
      Re: MMM-CalendarExt2
      Hello all, loving this project, new to MM… I see lots of things I like but don’t always see how to accomplish then, any help you guys can provide would be awesome.
      Using a 1920x1080 display rotated, want full month view to replace traditional wall calendar.
      • How can I get events to wrap to second line in month view?
        Saw somewhere that it’s not possible due to multi day events? However I think I just saw someone post this.
      • My entire left side of my calendar getting cut off - How can I shift the whole calendar to the right? I’m assuming I have some conflict border or margin setting somewhere, but after many edits, I still cannot correct it.
      • Why does calendar disappear for a second and come back? Is it refreshing? Can I stop it from disappearing?
      *************  CONFIG.JS **********
                                module: 'MMM-CalendarExt2',
                                  calendars : [
                                      url: "https://rest.cozi.com/api/ext/
      /*                              url: "https://calendar.google.com/calendar/
                                  views: [
                                        title: "What's Happening Soon",
                                        mode: "daily",
                                        calendars: [],
                                        position:"top_left",
                                        hideOverflow: false,
                                        slotCount: 3,
                                        className: "remove_empty_slot"
                                      mode: "month",
                                      position: "fullscreen_below",
                                      timeFormat: "h:mm",
                                      slotMaxHeight: "200px",
                                      maxItems: 500,
                                  scenes: [
      ******************CSS*****************
      body {
              margin: 10px;
      /*      height: calc(100%);*/
              width: 1060px;
      .CX2 .remove_empty_slot .eventCount_0 {
        display:none;
      .CX2 .cellSlot .slotSubTitle {
      color:#3A6061;
      .CX2 .cellSlot .slotTitle {
      color:#999;
      text-alignment: "right";
      .CX2 .cellSlot.weekday_6 .slotSubTitle {
      color:#3A6061;
      .CX2 .cellSlot.weekday_6 .slotTitle {
      color:#999;
      .CX2 .cellSlot.weekday_7 .slotSubTitle {
      color:#661414;
      .CX2 .slot{
      padding:0px 4px;
      border:4px solid #000000;
      /* Formats header */
      .CX2 .slot .slotHeader {
      background-color:#000000;
      border-top:2px solid #3A6061;
      border-bottom:2px solid #3A6061;
      margin-top:5px;
      margin-bottom:15px;
      height:calc(var(--font-size) + 6px);
      font-weight:normal;
      padding:6px 6px 0;
      .CX2 .today .slotHeader { /* today slot /
      background-color:#afcecf;
      /* background-color:#080a0a;*/
      color:#999;
      .CX2 .today .slotHeader * {
      color:#999;
      .CX2 .today .slotSubTitle {
      color:#3A6061;
      .CX2 .weekSlot {
      position:relative;
      .CX2 .today.slot {
      /*background-color:#afcecf;*/
      background-color:#0a1010;
      border:4px solid #1d2f30;
      .CX2 .slot > .slotContent{
      position:relative;
      width:100%;
      background-image: none;
      .CX2 .module-content { /* fake module body */
      color:#999;
      font-family: 'Roboto', sans-serif;
      .CX2 .weeksmark {
      display:none;
      /***** Event *****/
      .CX2 .event {
      padding:5px;
      margin:12px 0 0 8px;
      background-color:transparent;
      position:relative;
      text-align:left;
      /* how to treat full day events*/
      .CX2 .event.fullday {
      border-radius:unset;
      color:#999;
      S ? 2 Replies Last reply Reply Quote 0
        shfaxx @shfaxx
        Also would like to know how to remove the extra line at the bottom of the events in each day. This sucks up a bunch of space.
        • BKeyportB Offline
          BKeyport Module Developer @shfaxx
          @shfaxx Check to see if “hideOverflow: false,” in your view section takes out the extra space. It did for me in another view style.
          also, @sean would have the answer on the cutoff, but I suspect it’s something to do with the rotation - I think it’s been covered before, check the main topic at https://forum.magicmirror.builders/topic/9279/
            A Former User @shfaxx
            @shfaxx said in MMM-CalendarExt2:
            Can’t wrap. Ideally, it could be done by modification of CSS, but I don’t recommend it.
            I regard this table views as a summary or overview, so I didn’t make it show details. MagicMirror screen resolution is not so enough(especially vertical layout). If wrapping would be allowed, the number of showing events should be less. For example, you have 6 events on Nov. 13, 4 are partially shown and 2 are hidden. With wrapping, 1 or 2 events would be displayed fully but others might be hidden. I believe it would be worse than current.
            My suggestions are;
            • To use with other detail views - daily or upcoming, current views - together to get detailed information.
            • You can abbreviate titles and give separated styles by transform option to distinguish easily with less text.
              (Example; you can give an icon and blue font for Kim's schedule and remove the text Kim from event Title.)
            Maybe. But without whole CSS, I have no idea about it.
            Yes, it is refreshing. Adjust interval from configuration.
