    MMM - Spotify
    22 Posts 3 Posters 7.5k Views 3 Watching
    • E Offline
      ELMAGO @Guest
      @Sean
      a player was running, the Galaxy S10 precisely.
      I just want to make a display of the music that passes on some players.
      Why need Raspotify?
        A Former User @ELMAGO
        @ELMAGO
        if u has no need to play spotify on rpi, raspotify is not required.
        anyway, to get current spotify playback info, one of your spotify player(galaxy s10) should be activated already before MMM-Spotify. The module doesn’t know which player is available until the player is activated.
        • E Offline
          ELMAGO @Guest
          @Sean said in MMM - Spotify:
          ok, I understand and I do not want to play spotify on this Rasp, I just want a display of music that passes on some players. So why when I do not restrict devices and change device, the module detects it well, whereas when I restrict it there is no display.
          • E Offline
            ELMAGO
            Someone will have an idea?
              @ELMAGO
              I’ve updated, Update module and try again.
                    module: "MMM-Spotify",
                    position: "bottom_right",
                      allowDevices:["My iPhoneXI Pro"], // < - Change this to your device name.
              • E Offline
                ELMAGO @Guest
                @Sean
                Hello
                and thank you, how to update the module?
                  @ELMAGO
                  git pull in MMM-Spotify directory.
                  • E Offline
                    ELMAGO
                    • E Offline
                      ELMAGO @Guest
                      @Sean
                      Hello
                      it’s perfect, great. For several devices I have to put a comma and [“XXXX”]?
                      The Spotify logo, does not disappear?
                      ? E 2 Replies Last reply Reply Quote 0
                        @ELMAGO
                        Yes. ["My iPhoneXI Pro", "DESKTOP-ABCD", "RASPOTIFY"].
                        You can hide it by CSS or change the logo image file to what you want.
                        • E Offline
                          ELMAGO @ELMAGO
                          @Sean
                          So, I went around the problem by making transparent the image that you apply.
                          Thanks for your help.
                          It works nickel …
                          Really, thank you
