    Volkswagen CarNet
    6 Posts 3 Posters 2.5k Views 3 Watching
      A Former User @jorgeb1502
      @jorgeb1502 Its github repository is broken. I think it might be out-of-date.
        jorgeb1502
          jorgeb1502 @Guest
          @sean
          Would it be possible to use this one? https://github.com/wez3/volkswagen-carnet-client
          Edit:
          I have tested it, and I it works. Is it possible to use python in a module?
            @jorgeb1502 you can make python app and run as daemon. And add some communication part with RESTful API or any other spec. Your another nodejs mm module can talk with with your python app, I guess.
            • N Offline
              nekman
              You can also try https://www.npmjs.com/package/node-vw-carnet (if you have not already solved your problem)
