Solved Third-Party Module - how to get help?
@sdetweil said in Third-Party Module - how to get help?:
and other than image, you are running default modules, correct?
I have installed your MMM-ImagesPhotos and MMM-BackgroundSlideshow. Even paring the configuration down to ONLY one third-party module running, it will die unless I have the http cache disabled.
I have changed the swap size from the default of 100 to 250 and when it crashed, there was only a small portion of swap being used.
@ember1205 hm
my uname -a
Linux raspberrypi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
we have different kernels… wonder why
just got the pi4 yesterday -
@sdetweil Possibly because you’re running on a 4 and I’m on a 3?
are u using pm2 to manage? if so, do a pm2 logs --lines=100 >somefile
I’d like to see the error
@ember1205 ok, from my pi3
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
I just did an apt-get update and apt-get upgrade. I then flushed the PM2 logs and restarted. When it crashes again, I’ll post the log info as you asked.
At a minimum, the apt-get update / upgrade seems to have at least helped. After installing the updates and restarting, I’ve been running this module with clock, calendar, current weather, and weather forecast all enabled and it hasn’t crashed in about an hour.
I stopped everything and reverted to the BackgroundSlideshow module to see if it would also run clean, but it died pretty quickly. I’ve flushed the logs again (although I did capture their contents from the other module’s crash) and once again changed over to ImagesPhotos to see what happens after another run.
While I’m waiting to see if it will crash, I have some questions about the rendering configuration.
I’ve tried both the “fullscreen” and “middle_center” settings and the photos are not constrained to the screen (in terms of the actual image, not where it’s shown). I can change the details so that I use less than full height and/or width, and there is a black border. However, the image itself is getting cropped - badly.
How can I get this to display the entire image on the screen like I can with the other module?
[TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 100 lines: PM2 | 2019-12-12T14:19:37: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2019-12-12T14:19:37: PM2 log: App [mm:0] online PM2 | 2019-12-12T14:41:26: PM2 log: Stopping app:mm id:0 PM2 | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:41:27: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=process killed PM2 | 2019-12-12T14:41:27: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2019-12-12T14:41:27: PM2 log: App [mm:0] online PM2 | 2019-12-12T14:43:33: PM2 log: Stopping app:mm id:0 PM2 | 2019-12-12T14:43:33: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2019-12-12T14:43:33: PM2 log: pid=4543 msg=process killed PM2 | 2019-12-12T14:43:33: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2019-12-12T14:43:33: PM2 log: App [mm:0] online PM2 | 2019-12-12T14:46:33: PM2 log: Stopping app:mm id:0 PM2 | 2019-12-12T14:46:33: PM2 log: pid=4667 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:46:33: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2019-12-12T14:46:33: PM2 log: pid=4667 msg=process killed PM2 | 2019-12-12T14:46:33: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2019-12-12T14:46:33: PM2 log: App [mm:0] online PM2 | 2019-12-12T14:47:42: PM2 log: Stopping app:mm id:0 PM2 | 2019-12-12T14:47:43: PM2 log: pid=4822 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T14:47:43: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2019-12-12T14:47:43: PM2 log: pid=4822 msg=process killed PM2 | 2019-12-12T14:47:43: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2019-12-12T14:47:43: PM2 log: App [mm:0] online PM2 | 2019-12-12T15:00:40: PM2 log: Stopping app:mm id:0 PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms PM2 | 2019-12-12T15:00:42: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=process killed /home/pi/.pm2/logs/mm-error.log last 100 lines: 0|mm | [5004:1212/145553.006275:FATAL:memory.cc(22)] Out of memory. size=96641024 /home/pi/.pm2/logs/mm-out.log last 100 lines: 0|mm | No helper found for module: weatherforecast. 0|mm | All module helpers loaded. 0|mm | Starting server on port 8080 ... 0|mm | Server started ... 0|mm | Connecting socket for: MMM-ImagesPhotos 0|mm | Starting node helper for: MMM-ImagesPhotos 0|mm | Connecting socket for: updatenotification 0|mm | Connecting socket for: calendar 0|mm | Starting node helper for: calendar 0|mm | Sockets connected & modules started ... 0|mm | Launching application. 0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/EDITED%40gmail.com/EDITED/basic.ics - Interval: 900000 0|mm | 0|mm | > magicmirror@2.9.0 start /home/pi/MagicMirror 0|mm | > sh run-start.sh 0|mm | 0|mm | Starting MagicMirror: v2.9.0 0|mm | Loading config ... 0|mm | Loading module helpers ... 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: MMM-ImagesPhotos 0|mm | No helper found for module: alert. 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: updatenotification 0|mm | No helper found for module: clock. 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: calendar 0|mm | No helper found for module: currentweather. 0|mm | No helper found for module: weatherforecast. 0|mm | All module helpers loaded. 0|mm | Starting server on port 8080 ... 0|mm | Server started ... 0|mm | Connecting socket for: MMM-ImagesPhotos 0|mm | Starting node helper for: MMM-ImagesPhotos 0|mm | Connecting socket for: updatenotification 0|mm | Connecting socket for: calendar 0|mm | Starting node helper for: calendar 0|mm | Sockets connected & modules started ... 0|mm | Launching application. 0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/EDITED%40gmail.com/EDITED/basic.ics - Interval: 900000 0|mm | 0|mm | > magicmirror@2.9.0 start /home/pi/MagicMirror 0|mm | > sh run-start.sh 0|mm | 0|mm | Starting MagicMirror: v2.9.0 0|mm | Loading config ... 0|mm | Loading module helpers ... 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: MMM-ImagesPhotos 0|mm | No helper found for module: alert. 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: updatenotification 0|mm | No helper found for module: clock. 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: calendar 0|mm | No helper found for module: currentweather. 0|mm | No helper found for module: weatherforecast. 0|mm | All module helpers loaded. 0|mm | Starting server on port 8080 ... 0|mm | Server started ... 0|mm | Connecting socket for: MMM-ImagesPhotos 0|mm | Starting node helper for: MMM-ImagesPhotos 0|mm | Connecting socket for: updatenotification 0|mm | Connecting socket for: calendar 0|mm | Starting node helper for: calendar 0|mm | Sockets connected & modules started ... 0|mm | Launching application. 0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/EDITED%40gmail.com/EDITED/basic.ics - Interval: 900000 0|mm | 0|mm | > magicmirror@2.9.0 start /home/pi/MagicMirror 0|mm | > sh run-start.sh 0|mm | 0|mm | Starting MagicMirror: v2.9.0 0|mm | Loading config ... 0|mm | Loading module helpers ... 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: MMM-ImagesPhotos 0|mm | No helper found for module: alert. 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: updatenotification 0|mm | No helper found for module: clock. 0|mm | Initializing new module helper ... 0|mm | Module helper loaded: calendar 0|mm | No helper found for module: currentweather. 0|mm | No helper found for module: weatherforecast. 0|mm | All module helpers loaded. 0|mm | Starting server on port 8080 ... 0|mm | Server started ... 0|mm | Connecting socket for: MMM-ImagesPhotos 0|mm | Starting node helper for: MMM-ImagesPhotos 0|mm | Connecting socket for: updatenotification 0|mm | Connecting socket for: calendar 0|mm | Starting node helper for: calendar 0|mm | Sockets connected & modules started ... 0|mm | Launching application. 0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/EDITED%40gmail.com/EDITED/basic.ics - Interval: 900000 0|mm | Shutting down server... 0|mm | Stopping module helper: MMM-ImagesPhotos 0|mm | Stopping module helper: updatenotification 0|mm | Stopping module helper: calendar
@ember1205 you need to use position:‘fullscreen’ for my sizing to work.
there is a space around the picture, its NOT ‘fullscreen’, its the fullscreen section of the mirror ui.
i adjust the pic to fix exactly with the same relative dimensions as actual
I do not fill (cover) the screen
and do not contain (the image)
whatever it takes to get 100% of the image, no clipping, onto the screen.
they will NEVER fill the screen, the measurements are different.
the grey is the background color in the config to use to fill the empty space around the pic
backgroundColor: "#808080", // the default is #000 , ie, black
the pics are centered on the screen
@ember1205 if you don’t use position:“fullscreen” then the image will be clipped or shrunk based on the area u pick, which is less that 100% of the display space.
I wanted a full background image without clipping or stretching
I checked a few thousand images to insure the right calculations.
