    Third-Party Module - how to get help?
    64 Posts 3 Posters 39.4k Views 4 Watching
      sdetweil @ember1205
      @ember1205 yes, it contains the code for the transition handling.
      I would make the swap 1 gig… its only a little disk (memory card) space…
      the code.
      basically it adds an img (appends) to the div to display, the image is hidden,
      then there is an onload handler, that gets notified when the image is loaded (not yet visible)
      it also adjusts the image size to keep the proportions correct, (css background-size:cover and contain both distort the image)
      it makes the image visible, and starts the timer for the next image.
      it then checks to see if there are TWO images in the div,
      if so, it hides the 1st, shows the second and removes the 1st (old image)
      repeat
      • E Offline
        ember1205 @sdetweil
        I will give your code a try. Increasing the swap size and re-enabling the cache resulted in another almost immediate crash.
          sdetweil @ember1205
          @ember1205 hm… mine runs like a top on pi0 , pi3 b+, pi4, odroid, jetson nano , macOs, ubuntu
          my selected pics holds 100 pics, some as large as 15meg. 7.4 meg avg
          • E Offline
            ember1205 @sdetweil
            Seems your code has dependencies? I’m getting an error when trying to load:
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
              sdetweil @ember1205
              @ember1205 node_help is the build in module,
              sounds like u did an npm install, even tho not needed (and finds a bug or new feature we don’t want)
              recover with this
              git checkout modules/node_modules/node_helper/index.js
              • E Offline
                ember1205 @sdetweil
                @sdetweil said in Third-Party Module - how to get help?:
                yeah, I get into the habit of installing add-ons this way and I did the npm install.
                Your fix cleaned it right up and it started up. But, guess what? Out of memory again.
                Seems that I have bigger issues here…
                  sdetweil @ember1205
                  @ember1205 show me the output of
                  node-v
                  npm -v
                  lsb_release -a
                  uname -a
                  and other than image, you are running default modules, correct?
                  I’m gonna be out for a couple hours, running xmas errands. will try to look in on my phone
                  E 2 Replies Last reply Reply Quote 0
                  • E Offline
                    ember1205 @sdetweil
                    pi@raspberrypi:~ $ node -v
                    v10.17.0
                    pi@raspberrypi:~ $ npm -v
                    6.11.3
                    pi@raspberrypi:~ $ lsb_release -a
                    No LSB modules are available.
                    Distributor ID: Raspbian
                    Description:    Raspbian GNU/Linux 10 (buster)
                    Release:        10
                    Codename:       buster
                    pi@raspberrypi:~ $ uname -a
                    Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                    • E Offline
                      ember1205 @sdetweil
                      I have installed your MMM-ImagesPhotos and MMM-BackgroundSlideshow. Even paring the configuration down to ONLY one third-party module running, it will die unless I have the http cache disabled.
                      I have changed the swap size from the default of 100 to 250 and when it crashed, there was only a small portion of swap being used.
                        sdetweil @ember1205
                        @ember1205 hm
                        my uname -a
                        Linux raspberrypi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                        we have different kernels… wonder why
                        just got the pi4 yesterday
                        • E Offline
                          ember1205 @sdetweil
                          @sdetweil Possibly because you’re running on a 4 and I’m on a 3?
                            are u using pm2 to manage? if so, do a pm2 logs --lines=100 >somefile
                            I’d like to see the error
                              sdetweil @ember1205
                              @ember1205 ok, from my pi3
                              • E Offline
                                ember1205
                                I just did an apt-get update and apt-get upgrade. I then flushed the PM2 logs and restarted. When it crashes again, I’ll post the log info as you asked.
                                • E Offline
                                  ember1205
                                  At a minimum, the apt-get update / upgrade seems to have at least helped. After installing the updates and restarting, I’ve been running this module with clock, calendar, current weather, and weather forecast all enabled and it hasn’t crashed in about an hour.
                                  I stopped everything and reverted to the BackgroundSlideshow module to see if it would also run clean, but it died pretty quickly. I’ve flushed the logs again (although I did capture their contents from the other module’s crash) and once again changed over to ImagesPhotos to see what happens after another run.
                                  While I’m waiting to see if it will crash, I have some questions about the rendering configuration.
                                  I’ve tried both the “fullscreen” and “middle_center” settings and the photos are not constrained to the screen (in terms of the actual image, not where it’s shown). I can change the details so that I use less than full height and/or width, and there is a black border. However, the image itself is getting cropped - badly.
                                  How can I get this to display the entire image on the screen like I can with the other module?
                                  • E Offline
                                    ember1205
                                    PM2        | 2019-12-12T14:19:37: PM2 log: App [mm:0] starting in -fork mode-
                                    PM2        | 2019-12-12T14:19:37: PM2 log: App [mm:0] online
                                    PM2        | 2019-12-12T14:41:26: PM2 log: Stopping app:mm id:0
                                    PM2        | 2019-12-12T14:41:26: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms
                                    PM2        | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=failed to kill - retrying in 100ms
                                    PM2        | 2019-12-12T14:41:27: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                    PM2        | 2019-12-12T14:41:27: PM2 log: pid=4285 msg=process killed
                                    PM2        | 2019-12-12T14:41:27: PM2 log: App [mm:0] starting in -fork mode-
                                    PM2        | 2019-12-12T14:41:27: PM2 log: App [mm:0] online
                                    PM2        | 2019-12-12T14:43:33: PM2 log: Stopping app:mm id:0
                                    PM2        | 2019-12-12T14:43:33: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                    PM2        | 2019-12-12T14:43:33: PM2 log: pid=4543 msg=process killed
                                    PM2        | 2019-12-12T14:43:33: PM2 log: App [mm:0] starting in -fork mode-
                                    PM2        | 2019-12-12T14:43:33: PM2 log: App [mm:0] online
                                    PM2        | 2019-12-12T14:46:33: PM2 log: Stopping app:mm id:0
                                    PM2        | 2019-12-12T14:46:33: PM2 log: pid=4667 msg=failed to kill - retrying in 100ms
                                    PM2        | 2019-12-12T14:46:33: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                    PM2        | 2019-12-12T14:46:33: PM2 log: pid=4667 msg=process killed
                                    PM2        | 2019-12-12T14:46:33: PM2 log: App [mm:0] starting in -fork mode-
                                    PM2        | 2019-12-12T14:46:33: PM2 log: App [mm:0] online
                                    PM2        | 2019-12-12T14:47:42: PM2 log: Stopping app:mm id:0
                                    PM2        | 2019-12-12T14:47:43: PM2 log: pid=4822 msg=failed to kill - retrying in 100ms
                                    PM2        | 2019-12-12T14:47:43: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                    PM2        | 2019-12-12T14:47:43: PM2 log: pid=4822 msg=process killed
                                    PM2        | 2019-12-12T14:47:43: PM2 log: App [mm:0] starting in -fork mode-
                                    PM2        | 2019-12-12T14:47:43: PM2 log: App [mm:0] online
                                    PM2        | 2019-12-12T15:00:40: PM2 log: Stopping app:mm id:0
                                    PM2        | 2019-12-12T15:00:41: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms
                                    PM2        | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=failed to kill - retrying in 100ms
                                    PM2        | 2019-12-12T15:00:42: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                    PM2        | 2019-12-12T15:00:42: PM2 log: pid=4943 msg=process killed
                                    0|mm       | [5004:1212/145553.006275:FATAL:memory.cc(22)] Out of memory. size=96641024
                                    0|mm       | No helper found for module: weatherforecast.
                                    0|mm       | All module helpers loaded.
                                    0|mm       | Starting server on port 8080 ...
                                    0|mm       | Server started ...
                                    0|mm       | Connecting socket for: MMM-ImagesPhotos
                                    0|mm       | Starting node helper for: MMM-ImagesPhotos
                                    0|mm       | Connecting socket for: updatenotification
                                    0|mm       | Connecting socket for: calendar
                                    0|mm       | Starting node helper for: calendar
                                    0|mm       | Sockets connected & modules started ...
                                    0|mm       | Launching application.
                                    0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/EDITED%40gmail.com/EDITED/basic.ics - Interval: 900000
                                    0|mm       |
                                    0|mm       | > magicmirror@2.9.0 start /home/pi/MagicMirror
                                    0|mm       | > sh run-start.sh
                                    0|mm       |
                                    0|mm       | Starting MagicMirror: v2.9.0
                                    0|mm       | Loading config ...
                                    0|mm       | Loading module helpers ...
                                    0|mm       | Initializing new module helper ...
                                    0|mm       | Module helper loaded: MMM-ImagesPhotos
                                    0|mm       | No helper found for module: alert.
                                    0|mm       | Module helper loaded: updatenotification
                                    0|mm       | No helper found for module: clock.
                                    0|mm       | Module helper loaded: calendar
                                    0|mm       | No helper found for module: currentweather.
                                    0|mm       |
                                    0|mm       |
                                    0|mm       |
                                    0|mm       |
                                    0|mm       | Shutting down server...
                                    0|mm       | Stopping module helper: MMM-ImagesPhotos
                                    0|mm       | Stopping module helper: updatenotification
                                    0|mm       | Stopping module helper: calendar
                                      sdetweil @ember1205
                                      @ember1205 you need to use position:‘fullscreen’ for my sizing to work.
                                      there is a space around the picture, its NOT ‘fullscreen’, its the fullscreen section of the mirror ui.
                                      i adjust the pic to fix exactly with the same relative dimensions as actual
                                      I do not fill (cover) the screen
                                      and do not contain (the image)
                                      alt text
                                      alt text
                                      alt text
                                      whatever it takes to get 100% of the image, no clipping, onto the screen.
                                      they will NEVER fill the screen, the measurements are different.
                                      the grey is the background color in the config to use to fill the empty space around the pic
                                        backgroundColor: "#808080",  // the default is #000 , ie, black
                                      the pics are centered on the screen
                                      S E 2 Replies Last reply Reply Quote 0
                                        @ember1205 if you don’t use position:“fullscreen” then the image will be clipped or shrunk based on the area u pick, which is less that 100% of the display space.
                                        I wanted a full background image without clipping or stretching
                                        I checked a few thousand images to insure the right calculations.
                                        • E Offline
                                          ember1205 @sdetweil
                                          I tried with the config you provided:
                                          			module: "MMM-ImagesPhotos",
                                          			position: "fullscreen",
                                          				opacity: 0.9,
                                          				animationSpeed: 0,
                                          				updateInterval: 30000,  // how often to change pic
                                          				backgroundColor: "#808080", // color around pic (if u want something other than black)
                                          This results in the photos running off the edges of the screen and not being able to view the entire image. I have also tried using the config on the project page, and adding the maxHeight and maxWidth variables as well.
                                          Just for the heck of it, I even tried using the “fullscreen_below” positioning area that the other module uses.
                                          The photos always run off the edge of the screen. And by a lot.
                                          As of right now, these are all photos that were shot on a 24MP DSLR and they are being displayed on a 1080 TV. There is definitely more pixels in the photo and the device needs to ‘resize’ them down to fit the screen (which it does not appear to be doing).
                                          While you don’t ‘contain’ the images, I do recall that was an option being used in the other module that would ensure they did not overrun the screen edges. Is there a config option for yours that would enable it?
                                            sdetweil @ember1205
                                            @ember1205 no. Contain…etc.
                                            My pics are from a Nikon D3300 24mp I don’t see anything strange.
                                            U set fullscreen. I add .above
                                            I just checked 50 pics, and they display exactly the same as shown in Windows Media viewer and explorer.
                                            I just installed the module on two systems. Pi3 and pi4. Cut/pasted the config I posted and both systems present the same. One at 1920x1080, and one at 3840x2160. I get the screen size dynamically. Nothing is hard coded
                                            • 1 / 4
