    Third-Party Module - how to get help?
    64 Posts 3 Posters 39.4k Views 4 Watching
      sdetweil @ember1205
      @ember1205 you could try to force electron not to cache images
      edit the js/electron.js file and add this line
      	app.commandLine.appendSwitch('disable-http-cache');
      function createWindow() {
      	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required");
      ----> here
      • E Offline
        ember1205 @sdetweil
        @sdetweil said in Third-Party Module - how to get help?:
        app.commandLine.appendSwitch(‘disable-http-cache’);
        Thanks. I have made the change and restarted the mirror.
        I’m running with only this module and the clock enabled and am finding that having the image caching disabled (so far) is significantly slowing down the rendering of the images on screen.
        Is there a way to set the node.js maximum memory or set a limit on cache size? I have found some commentary that seems to say that node.js will use up to 1.7G of RAM by default and have no idea if there is anything in any of these configuration files that would lower that limit using the settings:
        --max-old-space-size={limit in KB} --optimize-for-size --max-executable-size={limit in KB}
        Given that my system is 1GB of RAM, and the default for node.js is to use up to 1.7GB, I could see where it could conceivably be trying to use memory beyond the bounds of the system, especially if there were some sort of issue with the underlying OS and its interaction with node.js to control the memory usage.
          sdetweil @ember1205
          @ember1205 you should increase the swap space .
          https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
          yes, lack of cache will slow down rendering.
          I added javascript code to the other module to wait til the image was loaded before showing,
          made a huge improvement, no lag rendering
          you could try it
          https://github.com/sdetweil/MMM-ImagesPhotos
          git clone that and then use this in config
          			module: "MMM-ImagesPhotos",
          			position: "fullscreen",
          				opacity: 0.9,
          				animationSpeed: 0,
          				updateInterval: 30000,  // how often to change pic
          				backgroundColor: "#808080", // color around pic (if u want something other than black)
          u have to put images in the uploads folder,
          or make a link (ln command) for the uploads folder where the pics are (I use my linux server, external usb drive)
          cd ~/MagicMirror/modules/MMM-ImagesPhotos
          ls -laF
          lrwxrwxrwx   1 sam sam    45 Dec 12 08:53 uploads -> /media/buildserver/media/Photos/selectedpics//
          add
          disabled: true,
          the the existing module definition (after the name)
          to turn it off, without changing anything
            the command
            free -m
            will show u memory usage
            nano
            sam@nano:~/MagicMirror$ free -m
                          total        used        free      shared  buff/cache   available
            Mem:           3956        2097         359         559        1499        1149
            Swap:          1978         460        1517
            pi4 -4gig, default swap space
            free -m
            Mem:           3906         650        2053         447        1201        2656
            Swap:            99           3          96
            • E Offline
              ember1205 @sdetweil
              I will give this a shot. Given that each time the slideshow has died, it has indicated that it ran out of memory at roughly 100Mb (and the default swap is 100Mb), this could definitely be related. I’ll try doubling it to see what happens with this module.
              I was going to try tackling the transitioning to prevent changing to the new image until it was rendered (to prevent the “painting”), but need the memory issue fixed first. :)
              Does your image module contain the JS code you were referring to that hides the image until it’s rendered?
                sdetweil @ember1205
                @ember1205 yes, it contains the code for the transition handling.
                I would make the swap 1 gig… its only a little disk (memory card) space…
                the code.
                basically it adds an img (appends) to the div to display, the image is hidden,
                then there is an onload handler, that gets notified when the image is loaded (not yet visible)
                it also adjusts the image size to keep the proportions correct, (css background-size:cover and contain both distort the image)
                it makes the image visible, and starts the timer for the next image.
                it then checks to see if there are TWO images in the div,
                if so, it hides the 1st, shows the second and removes the 1st (old image)
                repeat
                • E Offline
                  ember1205 @sdetweil
                  I will give your code a try. Increasing the swap size and re-enabling the cache resulted in another almost immediate crash.
                    sdetweil @ember1205
                    @ember1205 hm… mine runs like a top on pi0 , pi3 b+, pi4, odroid, jetson nano , macOs, ubuntu
                    my selected pics holds 100 pics, some as large as 15meg. 7.4 meg avg
                    • E Offline
                      ember1205 @sdetweil
                      Seems your code has dependencies? I’m getting an error when trying to load:
                      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                        sdetweil @ember1205
                        @ember1205 node_help is the build in module,
                        sounds like u did an npm install, even tho not needed (and finds a bug or new feature we don’t want)
                        recover with this
                        git checkout modules/node_modules/node_helper/index.js
                        • E Offline
                          ember1205 @sdetweil
                          yeah, I get into the habit of installing add-ons this way and I did the npm install.
                          Your fix cleaned it right up and it started up. But, guess what? Out of memory again.
                          Seems that I have bigger issues here…
                            sdetweil @ember1205
                            @ember1205 show me the output of
                            node-v
                            npm -v
                            lsb_release -a
                            uname -a
                            and other than image, you are running default modules, correct?
                            I’m gonna be out for a couple hours, running xmas errands. will try to look in on my phone
                            E 2 Replies Last reply Reply Quote 0
                            • E Offline
                              ember1205 @sdetweil
                              pi@raspberrypi:~ $ node -v
                              v10.17.0
                              pi@raspberrypi:~ $ npm -v
                              6.11.3
                              pi@raspberrypi:~ $ lsb_release -a
                              No LSB modules are available.
                              Distributor ID: Raspbian
                              Description:    Raspbian GNU/Linux 10 (buster)
                              Release:        10
                              Codename:       buster
                              pi@raspberrypi:~ $ uname -a
                              Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                              • E Offline
                                ember1205 @sdetweil
                                I have installed your MMM-ImagesPhotos and MMM-BackgroundSlideshow. Even paring the configuration down to ONLY one third-party module running, it will die unless I have the http cache disabled.
                                I have changed the swap size from the default of 100 to 250 and when it crashed, there was only a small portion of swap being used.
                                  sdetweil @ember1205
                                  @ember1205 hm
                                  my uname -a
                                  Linux raspberrypi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                                  we have different kernels… wonder why
                                  just got the pi4 yesterday
                                  • E Offline
                                    ember1205 @sdetweil
                                    @sdetweil Possibly because you’re running on a 4 and I’m on a 3?
                                      are u using pm2 to manage? if so, do a pm2 logs --lines=100 >somefile
                                      I’d like to see the error
                                        sdetweil @ember1205
                                        @ember1205 ok, from my pi3
                                        • E Offline
                                          ember1205
                                          I just did an apt-get update and apt-get upgrade. I then flushed the PM2 logs and restarted. When it crashes again, I’ll post the log info as you asked.
                                          • E Offline
                                            ember1205
                                            At a minimum, the apt-get update / upgrade seems to have at least helped. After installing the updates and restarting, I’ve been running this module with clock, calendar, current weather, and weather forecast all enabled and it hasn’t crashed in about an hour.
                                            I stopped everything and reverted to the BackgroundSlideshow module to see if it would also run clean, but it died pretty quickly. I’ve flushed the logs again (although I did capture their contents from the other module’s crash) and once again changed over to ImagesPhotos to see what happens after another run.
                                            While I’m waiting to see if it will crash, I have some questions about the rendering configuration.
                                            I’ve tried both the “fullscreen” and “middle_center” settings and the photos are not constrained to the screen (in terms of the actual image, not where it’s shown). I can change the details so that I use less than full height and/or width, and there is a black border. However, the image itself is getting cropped - badly.
                                            How can I get this to display the entire image on the screen like I can with the other module?
                                            • 1 / 4
