    Third-Party Module - how to get help?
    64 Posts 3 Posters 39.4k Views 4 Watching
    • E Offline
      ember1205
      I’ve been working on setting up the MMM-BackgroundSlideshow module up and running, but am having issues.
      I have about a dozen photos that I shot with a 24MP DSLR, edited, and exported as JPG. They are anywhere from about 4MB to about 9MB in size. I’ve copied these into a folder on the Pi and was able to get the module to begin showing them. Then, it would randomly die with an “out of memory” error (from the error log) and the whole screen would go black. Restarting MM would fix it temporarily.
      I commented that section of the config out to make some updates to the calendar section. Once done tinkering there, I tried re-enabling the background image stuff and I get zip. No errors, no pictures, nothing.
      So, my question is how to go about getting help from the author of the third-party module? How do I determine any details about where the module is dying out and not even loading?
        sdetweil @ember1205
        @ember1205 did u install.my MMM-ImagesPhotos or the original?
        I JUST updated mine before telling u, and I just checked the new code is there.
        In the MMM-ImagePhotos folder do
        git remote -v
        Should point to sdetweil
          sdetweil @ember1205
          @ember1205 open the developers window on the pi, using ctrl-shift-i on the keyboard.
          select the tab labeled console, and scroll up to see any errors, usually read text…
          you can also filter messages by module with some part of the name in the filter field.
          like ‘back’ (no quotes)…
          let us know what you find.
            sdetweil @ember1205
            @ember1205 as for getting support for any module, you can open an issue on its github repository.
            there is NO commitment from any author to respond or fix any issue reported…
            the base also includes this statement,
            this is an opensource project, all volunteer. many times if u want a fix, you may have to develop it yourself and submit it back to the module author, and hope they take it,
            • E Offline
              ember1205
              This line just keeps repeating:
              MMM-BackgroundSlideshow received a system notification: CLOCK_SECOND
              The only red text is for an error with the weather module then it states that it’s changing to a different forecast.
              • E Offline
                ember1205
                I thought I would follow this up as I have found and solved this specific issue.
                Long story short, this particular module has a pre-defined list of file extensions that it will recognize as images. For some reason, I pulled a copy of image files from two different locations and the extension changed from JPG to JPEG. The former is default, the latter is not. I updated the module configuration and it started working again.
                I also discovered that the module is running out of memory while running. The error seems to be very consistent although the image in place when it crashes is not. I’ve posted an issue to the module owner’s repository to see what help that might bring.
                  sdetweil @ember1205
                  @ember1205 you could try to force electron not to cache images
                  edit the js/electron.js file and add this line
                  	app.commandLine.appendSwitch('disable-http-cache');
                  function createWindow() {
                  	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required");
                  ----> here
                  • E Offline
                    ember1205 @sdetweil
                    @sdetweil said in Third-Party Module - how to get help?:
                    app.commandLine.appendSwitch(‘disable-http-cache’);
                    Thanks. I have made the change and restarted the mirror.
                    I’m running with only this module and the clock enabled and am finding that having the image caching disabled (so far) is significantly slowing down the rendering of the images on screen.
                    Is there a way to set the node.js maximum memory or set a limit on cache size? I have found some commentary that seems to say that node.js will use up to 1.7G of RAM by default and have no idea if there is anything in any of these configuration files that would lower that limit using the settings:
                    --max-old-space-size={limit in KB} --optimize-for-size --max-executable-size={limit in KB}
                    Given that my system is 1GB of RAM, and the default for node.js is to use up to 1.7GB, I could see where it could conceivably be trying to use memory beyond the bounds of the system, especially if there were some sort of issue with the underlying OS and its interaction with node.js to control the memory usage.
                      sdetweil @ember1205
                      @ember1205 you should increase the swap space .
                      https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
                      yes, lack of cache will slow down rendering.
                      I added javascript code to the other module to wait til the image was loaded before showing,
                      made a huge improvement, no lag rendering
                      you could try it
                      https://github.com/sdetweil/MMM-ImagesPhotos
                      git clone that and then use this in config
                      			module: "MMM-ImagesPhotos",
                      			position: "fullscreen",
                      				opacity: 0.9,
                      				animationSpeed: 0,
                      				updateInterval: 30000,  // how often to change pic
                      				backgroundColor: "#808080", // color around pic (if u want something other than black)
                      u have to put images in the uploads folder,
                      or make a link (ln command) for the uploads folder where the pics are (I use my linux server, external usb drive)
                      cd ~/MagicMirror/modules/MMM-ImagesPhotos
                      ls -laF
                      lrwxrwxrwx   1 sam sam    45 Dec 12 08:53 uploads -> /media/buildserver/media/Photos/selectedpics//
                      add
                      disabled: true,
                      the the existing module definition (after the name)
                      to turn it off, without changing anything
                        the command
                        free -m
                        will show u memory usage
                        nano
                        sam@nano:~/MagicMirror$ free -m
                                      total        used        free      shared  buff/cache   available
                        Mem:           3956        2097         359         559        1499        1149
                        Swap:          1978         460        1517
                        pi4 -4gig, default swap space
                        free -m
                        Mem:           3906         650        2053         447        1201        2656
                        Swap:            99           3          96
                        • E Offline
                          ember1205 @sdetweil
                          I will give this a shot. Given that each time the slideshow has died, it has indicated that it ran out of memory at roughly 100Mb (and the default swap is 100Mb), this could definitely be related. I’ll try doubling it to see what happens with this module.
                          I was going to try tackling the transitioning to prevent changing to the new image until it was rendered (to prevent the “painting”), but need the memory issue fixed first. :)
                          Does your image module contain the JS code you were referring to that hides the image until it’s rendered?
                            sdetweil @ember1205
                            @ember1205 yes, it contains the code for the transition handling.
                            I would make the swap 1 gig… its only a little disk (memory card) space…
                            the code.
                            basically it adds an img (appends) to the div to display, the image is hidden,
                            then there is an onload handler, that gets notified when the image is loaded (not yet visible)
                            it also adjusts the image size to keep the proportions correct, (css background-size:cover and contain both distort the image)
                            it makes the image visible, and starts the timer for the next image.
                            it then checks to see if there are TWO images in the div,
                            if so, it hides the 1st, shows the second and removes the 1st (old image)
                            repeat
                            • E Offline
                              ember1205 @sdetweil
                              I will give your code a try. Increasing the swap size and re-enabling the cache resulted in another almost immediate crash.
                                sdetweil @ember1205
                                @ember1205 hm… mine runs like a top on pi0 , pi3 b+, pi4, odroid, jetson nano , macOs, ubuntu
                                my selected pics holds 100 pics, some as large as 15meg. 7.4 meg avg
                                • E Offline
                                  ember1205 @sdetweil
                                  Seems your code has dependencies? I’m getting an error when trying to load:
                                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                                    sdetweil @ember1205
                                    @ember1205 node_help is the build in module,
                                    sounds like u did an npm install, even tho not needed (and finds a bug or new feature we don’t want)
                                    recover with this
                                    git checkout modules/node_modules/node_helper/index.js
                                    • E Offline
                                      ember1205 @sdetweil
                                      yeah, I get into the habit of installing add-ons this way and I did the npm install.
                                      Your fix cleaned it right up and it started up. But, guess what? Out of memory again.
                                      Seems that I have bigger issues here…
                                        sdetweil @ember1205
                                        @ember1205 show me the output of
                                        node-v
                                        npm -v
                                        lsb_release -a
                                        uname -a
                                        and other than image, you are running default modules, correct?
                                        I’m gonna be out for a couple hours, running xmas errands. will try to look in on my phone
                                        E 2 Replies Last reply Reply Quote 0
                                        • E Offline
                                          ember1205 @sdetweil
                                          pi@raspberrypi:~ $ node -v
                                          v10.17.0
                                          pi@raspberrypi:~ $ npm -v
                                          6.11.3
                                          pi@raspberrypi:~ $ lsb_release -a
                                          No LSB modules are available.
                                          Distributor ID: Raspbian
                                          Description:    Raspbian GNU/Linux 10 (buster)
                                          Release:        10
                                          Codename:       buster
                                          pi@raspberrypi:~ $ uname -a
                                          Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
                                          • E Offline
                                            ember1205 @sdetweil
                                            I have installed your MMM-ImagesPhotos and MMM-BackgroundSlideshow. Even paring the configuration down to ONLY one third-party module running, it will die unless I have the http cache disabled.
                                            I have changed the swap size from the default of 100 to 250 and when it crashed, there was only a small portion of swap being used.
                                              sdetweil @ember1205
                                              @ember1205 hm
                                              my uname -a
                                              Linux raspberrypi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                                              we have different kernels… wonder why
                                              just got the pi4 yesterday
                                              • 1 / 4
