Solved Error performing TLS handshake: An unexpected TLS packet was received
@sdetweil Got the mmstart process deleted, but now the mirror hangs at the booting up screen with the command line on the top. I can access it correctly from a browser on another computer, so it looks like it just isn’t opening a web browser locally on the Pi.
@Keudn the new run-start.sh script is waiting for the server process to say its ready
then it starts the browseru should be able to test it
~/MagicMirror bash -x run-start.sh
starts mm in serveronly mode (on pi 0)
loops reading console output, waiting for the message
“point\ your\ browser”
then launches chromium-browserbut if that message doesn’t come… it will be hung…
so, try
~/MagicMirror node serveronly
should look like this (with your module list)
~/MagicMirror$ node serveronly [23:31:31.854] [LOG] Starting MagicMirror: v2.10.0-develop [23:31:31.865] [LOG] Loading config ... [23:31:31.871] [LOG] Loading module helpers ... [23:31:31.874] [LOG] No helper found for module: alert. [23:31:31.925] [LOG] Initializing new module helper ... [23:31:31.925] [LOG] Module helper loaded: updatenotification [23:31:31.927] [LOG] No helper found for module: clock. [23:31:31.928] [LOG] No helper found for module: currentweather. [23:31:31.929] [LOG] No helper found for module: weatherforecast. [23:31:32.508] [LOG] Initializing new module helper ... [23:31:32.509] [LOG] Module helper loaded: newsfeed [23:31:32.759] [LOG] Initializing new module helper ... [23:31:32.760] [LOG] Module helper loaded: MMM-CalendarExt2 [23:31:32.771] [LOG] handler helper in init [23:31:32.772] [LOG] Module helper loaded: ImageService [23:31:34.273] [LOG] scheduler helper in init [23:31:34.273] [LOG] Module helper loaded: ImageScheduler [23:31:34.274] [LOG] All module helpers loaded. [23:31:34.275] [LOG] Starting server on port 8080 ... [23:31:34.281] [INFO] You're using a full whitelist configuration to allow for all IPs [23:31:34.288] [LOG] Server started ... [23:31:34.289] [LOG] Connecting socket for: updatenotification [23:31:34.290] [LOG] Connecting socket for: newsfeed [23:31:34.290] [LOG] Starting module: newsfeed [23:31:34.291] [LOG] Connecting socket for: MMM-CalendarExt2 [23:31:34.291] [LOG] Connecting socket for: ImageService [23:31:34.292] [LOG] handler helper in start [23:31:34.292] [LOG] Connecting socket for: ImageScheduler [23:31:34.293] [LOG] scheduler helper in start [23:31:34.293] [LOG] Sockets connected & modules started ... [23:31:34.293] [LOG] Ready to go! Please point your browser to: http://localhost:8080
@sdetweil Both commands get it to “Ready to go! Please point your browser…”, but it is immediately followed by
~/MagicMirror $ node serveronly [23:41:39.439] [LOG] Starting MagicMirror: v2.10.0-develop [23:41:39.530] [LOG] Loading config ... [23:41:39.604] [LOG] Loading module helpers ... [23:41:39.617] [LOG] No helper found for module: alert. [23:41:39.624] [LOG] No helper found for module: clock. [23:41:42.789] [LOG] Initializing new module helper ... [23:41:42.795] [LOG] Module helper loaded: calendar [23:41:45.193] [LOG] Initializing new module helper ... [23:41:45.198] [LOG] Module helper loaded: MMM-Weather-Now [23:41:45.224] [LOG] Initializing new module helper ... [23:41:45.236] [LOG] Module helper loaded: MMM-3Day-Forecast [23:41:45.247] [LOG] Initializing new module helper ... [23:41:45.254] [LOG] Module helper loaded: MMM-MoonPhase [23:41:45.269] [LOG] Initializing new module helper ... [23:41:45.274] [LOG] Module helper loaded: MMM-MyScoreboard [23:41:45.279] [LOG] All module helpers loaded. [23:41:45.289] [LOG] Starting server on port 8080 ... [23:41:45.338] [INFO] You're using a full whitelist configuration to allow for all IPs [23:41:45.394] [LOG] Server started ... [23:41:45.401] [LOG] Connecting socket for: calendar [23:41:45.407] [LOG] Starting node helper for: calendar [23:41:45.412] [LOG] Connecting socket for: MMM-Weather-Now [23:41:45.418] [LOG] MMM-Weather-Now helper, started... [23:41:45.424] [LOG] Connecting socket for: MMM-3Day-Forecast [23:41:45.429] [LOG] MMM-3Day-Forecast helper, started... [23:41:45.434] [LOG] Connecting socket for: MMM-MoonPhase [23:41:45.438] [LOG] Starting module helper: MMM-MoonPhase [23:41:45.443] [LOG] Connecting socket for: MMM-MyScoreboard [23:41:45.448] [LOG] Starting node_helper for module [MMM-MyScoreboard] [23:41:50.375] [LOG] Sockets connected & modules started ... [23:41:50.381] [LOG] Ready to go! Please point your browser to: http://0.0.0.0:8080 [23:41:50.456] [LOG] Whoops! There was an uncaught exception... [23:41:50.462] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080 at Server.setupListenHandle [as _listen2] (net.js:1279:14) at listenInCluster (net.js:1327:12) at doListen (net.js:1460:7) at process._tickCallback (internal/process/next_tick.js:63:19) at Function.Module.runMain (internal/modules/cjs/loader.js:832:11) at startup (internal/bootstrap/node.js:283:19) at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3) code: 'EADDRINUSE', errno: 'EADDRINUSE', syscall: 'listen', address: '0.0.0.0', port: 8080 } [23:41:50.528] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [23:41:50.533] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
I’m not sure why there would be the address already in use unless it already started correctly. In that case why would the browser not open?
@Keudn because the pm2 instance is running…
@sdetweil Yeah, I just don’t understand why running “bash -x run-start.sh” would give the exact same output as “node serveronly” and not open the browser once it sees it is ready. The run-start.sh script doesn’t get to the #start chromium section.
When I run “bash -x run-start.sh” this is the output I get
$ bash -x run-start.sh + ./untrack-css.sh + '[' -z '' ']' + export DISPLAY=:0 + DISPLAY=:0 ++ uname -m + arch=armv6l ++ awk '{print tolower($2)}' ++ tr -d ',"'\''' ++ grep -i serveronly: config/config.js + serveronly= + serveronly=false ++ pgrep Xorg + xorg= ++ uname + mac=Linux + '[' false. '!=' false. -o armv6l == armv6l ']' + '[' false. == true. -o . == . ']' + node serveronly [23:50:08.974] [LOG] Starting MagicMirror: v2.10.0-develop [23:50:09.097] [LOG] Loading config ... [23:50:09.217] [LOG] Loading module helpers ... [23:50:09.236] [LOG] No helper found for module: alert. [23:50:09.245] [LOG] No helper found for module: clock. [23:50:13.447] [LOG] Initializing new module helper ... [23:50:13.458] [LOG] Module helper loaded: calendar [23:50:16.551] [LOG] Initializing new module helper ... [23:50:16.568] [LOG] Module helper loaded: MMM-Weather-Now [23:50:16.610] [LOG] Initializing new module helper ... [23:50:16.649] [LOG] Module helper loaded: MMM-3Day-Forecast [23:50:16.685] [LOG] Initializing new module helper ... [23:50:16.694] [LOG] Module helper loaded: MMM-MoonPhase [23:50:16.725] [LOG] Initializing new module helper ... [23:50:16.734] [LOG] Module helper loaded: MMM-MyScoreboard [23:50:16.740] [LOG] All module helpers loaded. [23:50:16.754] [LOG] Starting server on port 8080 ... [23:50:16.822] [INFO] You're using a full whitelist configuration to allow for all IPs [23:50:16.899] [LOG] Server started ... [23:50:16.910] [LOG] Connecting socket for: calendar [23:50:16.918] [LOG] Starting node helper for: calendar [23:50:16.924] [LOG] Connecting socket for: MMM-Weather-Now [23:50:16.932] [LOG] MMM-Weather-Now helper, started... [23:50:16.937] [LOG] Connecting socket for: MMM-3Day-Forecast [23:50:16.944] [LOG] MMM-3Day-Forecast helper, started... [23:50:16.951] [LOG] Connecting socket for: MMM-MoonPhase [23:50:16.956] [LOG] Starting module helper: MMM-MoonPhase [23:50:16.965] [LOG] Connecting socket for: MMM-MyScoreboard [23:50:16.970] [LOG] Starting node_helper for module [MMM-MyScoreboard] [23:50:23.495] [LOG] Sockets connected & modules started ... [23:50:23.506] [LOG] Ready to go! Please point your browser to: http://0.0.0.0:8080 [23:50:23.607] [LOG] Whoops! There was an uncaught exception... [23:50:23.615] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080 at Server.setupListenHandle [as _listen2] (net.js:1279:14) at listenInCluster (net.js:1327:12) at doListen (net.js:1460:7) at process._tickCallback (internal/process/next_tick.js:63:19) at Function.Module.runMain (internal/modules/cjs/loader.js:832:11) at startup (internal/bootstrap/node.js:283:19) at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3) code: 'EADDRINUSE', errno: 'EADDRINUSE', syscall: 'listen', address: '0.0.0.0', port: 8080 } [23:50:23.702] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [23:50:23.706] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
@Keudn right, but the run failed, cause of the address in use problem… need to stop the other instance to test…
pm2 stop MagicMirror
its stuck cause the script didn’t find xorg running
pgrep Xorg returned ‘’
edit the run-start.sh script and change line
if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
to
if [ "$serveronly." == "true." -a "$xorg." == "." ]; then
@sdetweil are u running in text mode on the pi 0? no… cause u expect browser to open
can u post output of
ps -efthx
@sdetweil Stopping the magic mirror process before running bash -x run-start.sh just hangs on the line “Ready to go…” and never goes further.
grep -i serveronly: config/config.js does in fact return nothing.
I edited the line, stopped the MagicMirror process, and re-ran run-start.sh. It now gives this output
$ bash -x run-start.sh + ./untrack-css.sh + '[' -z '' ']' + export DISPLAY=:0 + DISPLAY=:0 ++ uname -m + arch=armv6l ++ awk '{print tolower($2)}' ++ grep -i serveronly: config/config.js ++ tr -d ',"'\''' + serveronly= + serveronly=false ++ pgrep Xorg + xorg= ++ uname + mac=Linux + '[' false. '!=' false. -o armv6l == armv6l ']' + '[' false. == true. -a . == . ']' + exec + read line ++ node serveronly + case "$line" in + echo 0 '[LOG]' Starting MagicMirror: v2.10.0-develop 0 [LOG] Starting MagicMirror: v2.10.0-develop + read line + case "$line" in + echo 0 '[LOG]' Loading config ... 0 [LOG] Loading config ... + read line + case "$line" in + echo 0 '[LOG]' Loading module helpers ... 0 [LOG] Loading module helpers ... + read line + case "$line" in + echo 0 '[LOG]' No helper found for module: alert. 0 [LOG] No helper found for module: alert. + read line + case "$line" in + echo 0 '[LOG]' No helper found for module: clock. 0 [LOG] No helper found for module: clock. + read line + case "$line" in + echo 0 '[LOG]' Initializing new module helper ... 0 [LOG] Initializing new module helper ... + read line + case "$line" in + echo 0 '[LOG]' Module helper loaded: calendar 0 [LOG] Module helper loaded: calendar + read line + case "$line" in + echo 0 '[LOG]' Initializing new module helper ... 0 [LOG] Initializing new module helper ... + read line + case "$line" in + echo 0 '[LOG]' Module helper loaded: MMM-Weather-Now 0 [LOG] Module helper loaded: MMM-Weather-Now + read line + case "$line" in + echo 0 '[LOG]' Initializing new module helper ... 0 [LOG] Initializing new module helper ... + read line + case "$line" in + echo 0 '[LOG]' Module helper loaded: MMM-3Day-Forecast 0 [LOG] Module helper loaded: MMM-3Day-Forecast + read line + case "$line" in + echo 0 '[LOG]' Initializing new module helper ... 0 [LOG] Initializing new module helper ... + read line + case "$line" in + echo 0 '[LOG]' Module helper loaded: MMM-MoonPhase 0 [LOG] Module helper loaded: MMM-MoonPhase + read line + case "$line" in + echo 0 '[LOG]' Initializing new module helper ... 0 [LOG] Initializing new module helper ... + read line + case "$line" in + echo 0 '[LOG]' Module helper loaded: MMM-MyScoreboard 0 [LOG] Module helper loaded: MMM-MyScoreboard + read line + case "$line" in + echo 0 '[LOG]' All module helpers loaded. 0 [LOG] All module helpers loaded. + read line + case "$line" in + echo 0 '[LOG]' Starting server on port 8080 ... 0 [LOG] Starting server on port 8080 ... + read line + case "$line" in + echo 0 '[INFO]' 'You'\''re' using a full whitelist configuration to allow for all IPs 0 [INFO] You're using a full whitelist configuration to allow for all IPs + read line + case "$line" in + echo 0 '[LOG]' Server started ... 0 [LOG] Server started ... + read line + case "$line" in + echo 0 '[LOG]' Connecting socket for: calendar 0 [LOG] Connecting socket for: calendar + read line + case "$line" in + echo 0 '[LOG]' Starting node helper for: calendar 0 [LOG] Starting node helper for: calendar + read line + case "$line" in + echo 0 '[LOG]' Connecting socket for: MMM-Weather-Now 0 [LOG] Connecting socket for: MMM-Weather-Now + read line + case "$line" in + echo 0 '[LOG]' MMM-Weather-Now helper, started... 0 [LOG] MMM-Weather-Now helper, started... + read line + case "$line" in + echo 0 '[LOG]' Connecting socket for: MMM-3Day-Forecast 0 [LOG] Connecting socket for: MMM-3Day-Forecast + read line + case "$line" in + echo 0 '[LOG]' MMM-3Day-Forecast helper, started... 0 [LOG] MMM-3Day-Forecast helper, started... + read line + case "$line" in + echo 0 '[LOG]' Connecting socket for: MMM-MoonPhase 0 [LOG] Connecting socket for: MMM-MoonPhase + read line + case "$line" in + echo 0 '[LOG]' Starting module helper: MMM-MoonPhase 0 [LOG] Starting module helper: MMM-MoonPhase + read line + case "$line" in + echo 0 '[LOG]' Connecting socket for: MMM-MyScoreboard 0 [LOG] Connecting socket for: MMM-MyScoreboard + read line + case "$line" in + echo 0 '[LOG]' Starting node_helper for module '[MMM-MyScoreboard]' 0 [LOG] Starting node_helper for module [MMM-MyScoreboard] + read line + case "$line" in + echo 0 '[LOG]' Sockets connected '&' modules started ... 0 [LOG] Sockets connected & modules started ... + read line + case "$line" in + echo 0 '[LOG]' 0 [LOG] + read line + case "$line" in + echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080 Ready to go! Please point your browser to: http://0.0.0.0:8080 + break + exec ++ echo Ready to 'go!' Please point your browser to: http://0.0.0.0:8080 ++ awk -F: '{print $4}' + port=8080 + echo 'Starting chromium browser now, have patience, it takes a minute' Starting chromium browser now, have patience, it takes a minute + chromium-browser -noerrdialogs -kiosk -start_maximized --disable-infobars --app=http://localhost:8080 --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors + exit
however it doesn’t actually open the chromium browser.
ps -ef returns
ps -ef UID PID PPID C STIME TTY TIME CMD root 1 0 0 Dec16 ? 00:00:05 /sbin/init splash root 2 0 0 Dec16 ? 00:00:00 [kthreadd] root 3 2 0 Dec16 ? 00:00:00 [ksoftirqd/0] root 5 2 0 Dec16 ? 00:00:00 [kworker/0:0H] root 7 2 0 Dec16 ? 00:00:00 [lru-add-drain] root 8 2 0 Dec16 ? 00:00:00 [kdevtmpfs] root 9 2 0 Dec16 ? 00:00:00 [netns] root 10 2 0 Dec16 ? 00:00:00 [khungtaskd] root 11 2 0 Dec16 ? 00:00:00 [oom_reaper] root 12 2 0 Dec16 ? 00:00:00 [writeback] root 13 2 0 Dec16 ? 00:00:00 [kcompactd0] root 14 2 0 Dec16 ? 00:00:00 [crypto] root 15 2 0 Dec16 ? 00:00:00 [bioset] root 16 2 0 Dec16 ? 00:00:00 [kblockd] root 17 2 0 Dec16 ? 00:00:00 [watchdogd] root 19 2 0 Dec16 ? 00:00:00 [rpciod] root 20 2 0 Dec16 ? 00:00:00 [xprtiod] root 21 2 0 Dec16 ? 00:00:00 [kswapd0] root 22 2 0 Dec16 ? 00:00:00 [nfsiod] root 32 2 0 Dec16 ? 00:00:00 [kthrotld] root 33 2 0 Dec16 ? 00:00:00 [bioset] root 34 2 0 Dec16 ? 00:00:00 [bioset] root 35 2 0 Dec16 ? 00:00:00 [bioset] root 36 2 0 Dec16 ? 00:00:00 [bioset] root 37 2 0 Dec16 ? 00:00:00 [bioset] root 38 2 0 Dec16 ? 00:00:00 [bioset] root 39 2 0 Dec16 ? 00:00:00 [bioset] root 40 2 0 Dec16 ? 00:00:00 [bioset] root 41 2 0 Dec16 ? 00:00:00 [bioset] root 42 2 0 Dec16 ? 00:00:00 [bioset] root 43 2 0 Dec16 ? 00:00:00 [bioset] root 44 2 0 Dec16 ? 00:00:00 [bioset] root 45 2 0 Dec16 ? 00:00:00 [bioset] root 46 2 0 Dec16 ? 00:00:00 [bioset] root 47 2 0 Dec16 ? 00:00:00 [bioset] root 48 2 0 Dec16 ? 00:00:00 [bioset] root 49 2 0 Dec16 ? 00:00:00 [bioset] root 50 2 0 Dec16 ? 00:00:00 [bioset] root 51 2 0 Dec16 ? 00:00:00 [bioset] root 52 2 0 Dec16 ? 00:00:00 [bioset] root 53 2 0 Dec16 ? 00:00:00 [bioset] root 54 2 0 Dec16 ? 00:00:00 [bioset] root 55 2 0 Dec16 ? 00:00:00 [bioset] root 56 2 0 Dec16 ? 00:00:00 [bioset] root 57 2 0 Dec16 ? 00:00:00 [iscsi_eh] root 58 2 0 Dec16 ? 00:00:00 [dwc_otg] root 59 2 0 Dec16 ? 00:00:00 [DWC Notificatio] root 60 2 0 Dec16 ? 00:00:00 [VCHIQ-0] root 61 2 0 Dec16 ? 00:00:00 [VCHIQr-0] root 62 2 0 Dec16 ? 00:00:00 [VCHIQs-0] root 63 2 0 Dec16 ? 00:00:00 [VCHIQka-0] root 64 2 0 Dec16 ? 00:00:00 [SMIO] root 65 2 0 Dec16 ? 00:00:00 [kworker/0:2] root 66 2 0 Dec16 ? 00:00:00 [irq/86-mmc1] root 68 2 0 Dec16 ? 00:00:00 [bioset] root 69 2 0 Dec16 ? 00:00:02 [mmcqd/0] root 70 2 0 Dec16 ? 00:00:00 [jbd2/mmcblk0p2-] root 71 2 0 Dec16 ? 00:00:00 [ext4-rsv-conver] root 72 2 0 Dec16 ? 00:00:00 [ipv6_addrconf] root 89 2 0 Dec16 ? 00:00:00 [kworker/u2:1] root 105 2 0 Dec16 ? 00:00:00 [kworker/u2:2] root 118 1 0 Dec16 ? 00:00:01 /lib/systemd/systemd-journald root 120 1 0 Dec16 ? 00:00:00 /lib/systemd/systemd-udevd root 187 2 0 Dec16 ? 00:00:00 [cfg80211] root 191 2 0 Dec16 ? 00:00:00 [brcmf_wq/mmc1:0] root 192 2 0 Dec16 ? 00:00:00 [brcmf_wdog/mmc1] root 273 2 0 Dec16 ? 00:00:00 [kworker/0:1H] root 356 1 0 Dec16 ? 00:00:00 /usr/sbin/ModemManager avahi 357 1 0 Dec16 ? 00:00:01 avahi-daemon: running [raspberrypi.local] root 367 1 0 Dec16 ? 00:00:00 /usr/sbin/rsyslogd -n avahi 368 357 0 Dec16 ? 00:00:00 avahi-daemon: chroot helper root 370 1 0 Dec16 ? 00:00:00 /usr/sbin/cron -f message+ 375 1 0 Dec16 ? 00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation root 382 1 0 Dec16 ? 00:00:00 /sbin/dhcpcd -q -b root 410 1 0 Dec16 ? 00:00:00 /lib/systemd/systemd-logind root 441 1 0 Dec16 ? 00:00:00 /usr/lib/policykit-1/polkitd --no-debug root 442 1 0 Dec16 ? 00:00:00 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf root 495 1 0 Dec16 ? 00:00:00 /usr/sbin/sshd -D root 525 2 0 Dec16 ? 00:00:00 [kworker/u3:0] root 526 2 0 Dec16 ? 00:00:00 [hci0] root 527 2 0 Dec16 ? 00:00:00 [hci0] root 528 1 0 Dec16 ? 00:00:00 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow - b8:27:eb:b2:57:5c root 530 2 0 Dec16 ? 00:00:00 [kworker/u3:2] nobody 536 1 0 Dec16 ? 00:00:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/thd.pid --user nobody /dev/inpu root 550 1 0 Dec16 ? 00:00:00 /usr/lib/bluetooth/bluetoothd ntp 577 1 0 Dec16 ? 00:00:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111 xrdp 583 1 0 Dec16 ? 00:00:00 /usr/sbin/xrdp root 586 1 0 Dec16 ? 00:00:00 /usr/sbin/xrdp-sesman root 607 1 0 Dec16 tty1 00:00:00 /bin/login -f pi 651 1 0 Dec16 ? 00:00:00 /lib/systemd/systemd --user pi 666 651 0 Dec16 ? 00:00:00 (sd-pam) pi 694 607 0 Dec16 tty1 00:00:01 -bash pi 735 1 2 Dec16 ? 00:00:24 PM2 v4.2.1: God Daemon (/home/pi/.pm2) root 792 495 0 Dec16 ? 00:00:00 sshd: pi [priv] pi 798 792 0 Dec16 ? 00:00:00 sshd: pi@pts/0 pi 800 798 0 Dec16 pts/0 00:00:01 -bash root 905 2 0 Dec16 ? 00:00:00 [kworker/0:0] root 922 2 0 Dec16 ? 00:00:00 [kworker/0:1] root 923 2 0 00:00 ? 00:00:00 [kworker/u2:0] pi 957 1 0 00:01 pts/0 00:00:00 bash -x run-start.sh pi 958 957 19 00:01 pts/0 00:00:16 node serveronly pi 995 800 0 00:03 pts/0 00:00:00 ps -ef
I am running these commands from SSH, and I have the Pi configured to boot to Console Autologin (Boot Options -> B1 Desktop/CLI -> B2 Console Autologin).
