    Error performing TLS handshake: An unexpected TLS packet was received
    22 Posts 2 Posters 6.2k Views 2 Watching
      sdetweil @Keudn
      @Keudn pm2 stop 0 or 1 ( or use there name)
      pm2 delete 0 or 1
      Edit the config and fix line 86 with that *
      • K Offline
        Keudn @sdetweil
        @sdetweil Got the mmstart process deleted, but now the mirror hangs at the booting up screen with the command line on the top. I can access it correctly from a browser on another computer, so it looks like it just isn’t opening a web browser locally on the Pi.
          sdetweil @Keudn
          @Keudn the new run-start.sh script is waiting for the server process to say its ready
          then it starts the browser
          u should be able to test it
          ~/MagicMirror
          bash -x run-start.sh
          starts mm in serveronly mode (on pi 0)
          loops reading console output, waiting for the message
          “point\ your\ browser”
          then launches chromium-browser
          but if that message doesn’t come… it will be hung…
          so, try
          ~/MagicMirror
          node serveronly
          should look like this (with your module list)
          ~/MagicMirror$ node serveronly
          [23:31:31.854] [LOG]    Starting MagicMirror: v2.10.0-develop
          [23:31:31.865] [LOG]    Loading config ...
          [23:31:31.871] [LOG]    Loading module helpers ...
          [23:31:31.874] [LOG]    No helper found for module: alert.
          [23:31:31.925] [LOG]    Initializing new module helper ...
          [23:31:31.925] [LOG]    Module helper loaded: updatenotification
          [23:31:31.927] [LOG]    No helper found for module: clock.
          [23:31:31.928] [LOG]    No helper found for module: currentweather.
          [23:31:31.929] [LOG]    No helper found for module: weatherforecast.
          [23:31:32.508] [LOG]    Initializing new module helper ...
          [23:31:32.509] [LOG]    Module helper loaded: newsfeed
          [23:31:32.759] [LOG]    Initializing new module helper ...
          [23:31:32.760] [LOG]    Module helper loaded: MMM-CalendarExt2
          [23:31:32.771] [LOG]    handler helper in init
          [23:31:32.772] [LOG]    Module helper loaded: ImageService
          [23:31:34.273] [LOG]    scheduler helper in init
          [23:31:34.273] [LOG]    Module helper loaded: ImageScheduler
          [23:31:34.274] [LOG]    All module helpers loaded.
          [23:31:34.275] [LOG]    Starting server on port 8080 ...
          [23:31:34.281] [INFO]   You're using a full whitelist configuration to allow for all IPs
          [23:31:34.288] [LOG]    Server started ...
          [23:31:34.289] [LOG]    Connecting socket for: updatenotification
          [23:31:34.290] [LOG]    Connecting socket for: newsfeed
          [23:31:34.290] [LOG]    Starting module: newsfeed
          [23:31:34.291] [LOG]    Connecting socket for: MMM-CalendarExt2
          [23:31:34.291] [LOG]    Connecting socket for: ImageService
          [23:31:34.292] [LOG]    handler helper in start
          [23:31:34.292] [LOG]    Connecting socket for: ImageScheduler
          [23:31:34.293] [LOG]    scheduler helper in start
          [23:31:34.293] [LOG]    Sockets connected & modules started ...
          Ready to go! Please point your browser to: http://localhost:8080
          • K Offline
            Keudn @sdetweil
            @sdetweil Both commands get it to “Ready to go! Please point your browser…”, but it is immediately followed by
            ~/MagicMirror $ node serveronly
            [23:41:39.439] [LOG]    Starting MagicMirror: v2.10.0-develop
            [23:41:39.530] [LOG]    Loading config ...
            [23:41:39.604] [LOG]    Loading module helpers ...
            [23:41:39.617] [LOG]    No helper found for module: alert.
            [23:41:39.624] [LOG]    No helper found for module: clock.
            [23:41:42.789] [LOG]    Initializing new module helper ...
            [23:41:42.795] [LOG]    Module helper loaded: calendar
            [23:41:45.193] [LOG]    Initializing new module helper ...
            [23:41:45.198] [LOG]    Module helper loaded: MMM-Weather-Now
            [23:41:45.224] [LOG]    Initializing new module helper ...
            [23:41:45.236] [LOG]    Module helper loaded: MMM-3Day-Forecast
            [23:41:45.247] [LOG]    Initializing new module helper ...
            [23:41:45.254] [LOG]    Module helper loaded: MMM-MoonPhase
            [23:41:45.269] [LOG]    Initializing new module helper ...
            [23:41:45.274] [LOG]    Module helper loaded: MMM-MyScoreboard
            [23:41:45.279] [LOG]    All module helpers loaded.
            [23:41:45.289] [LOG]    Starting server on port 8080 ...
            [23:41:45.338] [INFO]   You're using a full whitelist configuration to allow for all IPs
            [23:41:45.394] [LOG]    Server started ...
            [23:41:45.401] [LOG]    Connecting socket for: calendar
            [23:41:45.407] [LOG]    Starting node helper for: calendar
            [23:41:45.412] [LOG]    Connecting socket for: MMM-Weather-Now
            [23:41:45.418] [LOG]    MMM-Weather-Now helper, started...
            [23:41:45.424] [LOG]    Connecting socket for: MMM-3Day-Forecast
            [23:41:45.429] [LOG]    MMM-3Day-Forecast helper, started...
            [23:41:45.434] [LOG]    Connecting socket for: MMM-MoonPhase
            [23:41:45.438] [LOG]    Starting module helper: MMM-MoonPhase
            [23:41:45.443] [LOG]    Connecting socket for: MMM-MyScoreboard
            [23:41:45.448] [LOG]    Starting node_helper for module [MMM-MyScoreboard]
            [23:41:50.375] [LOG]    Sockets connected & modules started ...
            [23:41:50.381] [LOG]
            Ready to go! Please point your browser to: http://0.0.0.0:8080
            [23:41:50.456] [LOG]    Whoops! There was an uncaught exception...
            [23:41:50.462] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                at Server.setupListenHandle [as _listen2] (net.js:1279:14)
                at listenInCluster (net.js:1327:12)
                at doListen (net.js:1460:7)
                at process._tickCallback (internal/process/next_tick.js:63:19)
                at Function.Module.runMain (internal/modules/cjs/loader.js:832:11)
                at startup (internal/bootstrap/node.js:283:19)
                at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '0.0.0.0',
              port: 8080 }
            [23:41:50.528] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [23:41:50.533] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            I’m not sure why there would be the address already in use unless it already started correctly. In that case why would the browser not open?
              sdetweil @Keudn
              @Keudn because the pm2 instance is running…
              • K Offline
                Keudn @sdetweil
                @sdetweil Yeah, I just don’t understand why running “bash -x run-start.sh” would give the exact same output as “node serveronly” and not open the browser once it sees it is ready. The run-start.sh script doesn’t get to the #start chromium section.
                When I run “bash -x run-start.sh” this is the output I get
                $ bash -x run-start.sh
                + ./untrack-css.sh
                + '[' -z '' ']'
                + export DISPLAY=:0
                + DISPLAY=:0
                ++ uname -m
                + arch=armv6l
                ++ awk '{print tolower($2)}'
                ++ tr -d ',"'\'''
                ++ grep -i serveronly: config/config.js
                + serveronly=
                + serveronly=false
                ++ pgrep Xorg
                + xorg=
                ++ uname
                + mac=Linux
                + '[' false. '!=' false. -o armv6l == armv6l ']'
                + '[' false. == true. -o . == . ']'
                + node serveronly
                [23:50:08.974] [LOG]    Starting MagicMirror: v2.10.0-develop
                [23:50:09.097] [LOG]    Loading config ...
                [23:50:09.217] [LOG]    Loading module helpers ...
                [23:50:09.236] [LOG]    No helper found for module: alert.
                [23:50:09.245] [LOG]    No helper found for module: clock.
                [23:50:13.447] [LOG]    Initializing new module helper ...
                [23:50:13.458] [LOG]    Module helper loaded: calendar
                [23:50:16.551] [LOG]    Initializing new module helper ...
                [23:50:16.568] [LOG]    Module helper loaded: MMM-Weather-Now
                [23:50:16.610] [LOG]    Initializing new module helper ...
                [23:50:16.649] [LOG]    Module helper loaded: MMM-3Day-Forecast
                [23:50:16.685] [LOG]    Initializing new module helper ...
                [23:50:16.694] [LOG]    Module helper loaded: MMM-MoonPhase
                [23:50:16.725] [LOG]    Initializing new module helper ...
                [23:50:16.734] [LOG]    Module helper loaded: MMM-MyScoreboard
                [23:50:16.740] [LOG]    All module helpers loaded.
                [23:50:16.754] [LOG]    Starting server on port 8080 ...
                [23:50:16.822] [INFO]   You're using a full whitelist configuration to allow for all IPs
                [23:50:16.899] [LOG]    Server started ...
                [23:50:16.910] [LOG]    Connecting socket for: calendar
                [23:50:16.918] [LOG]    Starting node helper for: calendar
                [23:50:16.924] [LOG]    Connecting socket for: MMM-Weather-Now
                [23:50:16.932] [LOG]    MMM-Weather-Now helper, started...
                [23:50:16.937] [LOG]    Connecting socket for: MMM-3Day-Forecast
                [23:50:16.944] [LOG]    MMM-3Day-Forecast helper, started...
                [23:50:16.951] [LOG]    Connecting socket for: MMM-MoonPhase
                [23:50:16.956] [LOG]    Starting module helper: MMM-MoonPhase
                [23:50:16.965] [LOG]    Connecting socket for: MMM-MyScoreboard
                [23:50:16.970] [LOG]    Starting node_helper for module [MMM-MyScoreboard]
                [23:50:23.495] [LOG]    Sockets connected & modules started ...
                [23:50:23.506] [LOG]
                [23:50:23.607] [LOG]    Whoops! There was an uncaught exception...
                [23:50:23.615] [ERROR]  { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '0.0.0.0',
                  port: 8080 }
                [23:50:23.702] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [23:50:23.706] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  sdetweil @Keudn
                  @Keudn right, but the run failed, cause of the address in use problem… need to stop the other instance to test…
                  pm2 stop MagicMirror
                    @Keudn do this
                    should return a null line
                      its stuck cause the script didn’t find xorg running
                      pgrep Xorg returned ‘’
                      edit the run-start.sh script and change line
                      if [ "$serveronly." == "true." -o "$xorg." == "." ]; then
                      to
                      if [ "$serveronly." == "true." -a "$xorg." == "." ]; then
                        @sdetweil are u running in text mode on the pi 0? no… cause u expect browser to open
                        can u post output of
                        ps -ef
                        thx
                        • 2 / 3
