    My-Commute flooded google api - 1.73/ sec while it was set to default 10 minutes!
    4 Posts 2 Posters 910 Views 2 Watching
    • N
      nakulbende
      Hello - Here is my config file with default poll freq. I got it working, but it kept blinking at refreshing at a very high rate. Not sure why that was happening. I checked the API console, and was thankful for it. The module had posted 18724 queries in a couple of minutes! That is $139 worth of queries! Please help me with debugging this? I am using a RPi3, And following is my config file. I was checking the MM interface through VNC stream, if that has something to do with it.
      Thanks in advance!
      Just the MyCommute section:
      // Commute
      			module: 'MMM-MyCommute',
      			position: 'bottom_right',
      			header: 'XXXX',
      			classes: 'default everyone',
      				apikey: 'XXXX ',
      				origin: 'XXXX',
      				startTime: '06:00',
      				endTime: '18:00',
      				hideDays: [0,6],
      				pollFrequency: '10 * 60 * 1000',
      				destinations: [
      						destination: 'XXXX',
      						label: 'XXXX',
      						mode: 'transit',
      						color: '#82E5AA'
      						label: 'XXXX',
      						mode: 'driving'
      						label: 'XXXX',
      						mode: 'transit',
      						color: '#82E5AA'
      						label: 'XXXX',
      						mode: 'driving'
      The full config file:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "metric",
      	// Modules //
      		// Alert
      			module: "alert",
      		// Notifications
      			module: "updatenotification",
      			position: "top_bar"
      		// Clock
      			module: "clock",
      				timeFormat: '12',
      				displaySeconds: 'false',
      				showPeriod: 'true',
      				clockBold: 'true',
      				timezone: 'America/New_York' //Karachi
      		// calendar
      			//header: "Calenar",
      						symbol: "island-tropical",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      						symbol: "user-friends",
      		//Buller - this one will be todo in house
      			module: 'MMM-Buller',
      			position: 'top_right',
      			header: 'To Do',
      				debug: false,
      				lists: [
      						type: 'gTasks',
      						updateInterval: 1000 * 60 * 1 * 1, //every minutes
      						icon: 'fas tasks',
      		// dARKYsKY module
      			module: "MMM-DarkSkyForecast",
      			header: "XXXXX",
      			classes: "default everyone",
      				apikey: "XXXX",
      				latitude: "XXXX",
      				longitude: "XXXX",
      				iconset: "3c",
      				concise: false,
      				forecastLayout: "table",
      				units: "us",
      				maxHourliesToShow: "4",
      				maxDailiesToShow: "4",
      		// XKCD
      			module: 'DailyXKCD',
      			position: 'bottom_left',
      				invertColors: true,
      				showTitle: true,
      				showAltText: true,
      				randomComic: true
      		// Bring shopping list
      			module: "MMM-Bring",
      			position: "bottom_center",
      				email: "USER@EXAMPLE.COM",
      				password: "SECRET",
      				updateInterval: 15, // in Minutes
      				listName: "Weggies", // optional
      				showListName: true,
      				activeItemColor: "#EE524F",
      				latestItemColor: "#4FABA2",
      				showLatestItems: false,
      				maxItems: 0,
      				maxLatestItems: 0,
      				locale: "de-DE"
      		// MBTA - Main x Emerson
      			module: 'MMM-MBTA',
      			position: 'bottom_left', // This can be any of the regions.
      			header: "XXXXXx",
      				apikey: 'XXXX',
      				updateInterval: 30,
      				stations: 'XXX',
      				formatETA: 'true',
      				showOnly: ["Subway", "Bus"],
      				colorIcons: 'true',
      				direction: 'Inbound',
      				noETAToBack: 'false'
      		// MBTA - Davis
      			module: 'MMM-MBTA',
      			header: "XXXX",
      				apikey: 'XXXX',
      				updateInterval: 20,
      				stations: 'XXX": "XXX',
      				formatETA: 'true',
      				colorIcons: 'true',
      				flipDirection: 'true',
      		// Commute
      			header: 'XXXX',
      				apikey: 'XXXX ',
      				origin: 'XXXX',
      				startTime: '06:00',
      				endTime: '18:00',
      				hideDays: [0,6],
      				destinations: [
      						label: 'XXXX',
      						mode: 'transit',
      						color: '#82E5AA'
      						label: 'XXXX',
      						mode: 'driving'
      						label: 'XXXX',
      						mode: 'transit',
      						color: '#82E5AA'
      						label: 'XXXX',
      						mode: 'driving'
      • N
        nakulbende
        So, this got solved when I commented out the pollFrequency field. Not sure what is going on.
          @nakulbende said in My-Commute flooded google api - 1.73/ sec while it was set to default 10 minutes!:
          pollFrequency: ‘10 * 60 * 1000’,
          u need to take the quotes off, the value needs to be a number, with the quotes its a string
          N 1 Reply Last reply
          • N
            nakulbende @sdetweil
            @sdetweil - thanks again! o my!
