    Updating a Docker Mirror image
    7 Posts 2 Posters 2.0k Views 2 Watching
    • T Offline
      technofab
      I’ve setup in my centos 7 box, a docker mirror image following the instructions in github. All works ok, but I want to know the right update sequence. Is sufficient to make a:
      docker pull bastilimbach/docker-magicmirror
      and restart my docker istance, or what else?
        sdetweil @technofab
        @technofab that should be the typical approach, assuming the docker image doesn’t change any implementation details between releases… (Only seen THAT a million times!)
        • T Offline
          technofab
          Mmhmm great, so what you suggest? Backup config and modules delete all, reinstall container and restore config and modules?
            sdetweil @technofab
            @technofab well, TRY it…
            • T Offline
              technofab
              For now I suppose this scenario:
              docker stop magic_mirror
              docker rm magic_mirror
              docker system prune -a -f
              docker run -d --publish 80:8080 --restart always…
              In this way I suppose that after run is completed is full updated.
                sdetweil @technofab
                @technofab looks like docker added a new flag to handle some of this
                on docker run
                --pull=[always,*missing,never]
                I think there should have been ‘updated’ too
                so add
                --pull=always
                then u don’t need the other steps
                • T Offline
                  technofab
                  I don’t know that switch! But it read from dockerfile? My strategy is a bit longer but it can guarantee that all is updated and I can also add git pull for every module in the sequence…
                  Edit: I give a try, but not works, and didn’t find that on documentation.
                  https://docs.docker.com/engine/reference/commandline/run/
