Doesn't contain package.json file
8 Posts 2 Posters 2.0k Views 2 Watching
    allancherianbiju
    Re: include npm module like firebase module into our own MM module
    I’ve been trying for a while and I got the same error every single time.
    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
    Expected directory: electron-v3.0-linux-arm-glibc
    Found: [node-v59-linux-arm-glibc]
    cd ~/MagicMirror/modules/MMM-hellotsuhan
    npm install --save-dev electron-rebuild
    ./node_modules/.bin/electron-rebuild
    Tried executing this and I got this
    How do I get that file?
    I’m very new to this.
    S 1 Reply Last reply Dec 24, 2019, 6:11 PM Reply Quote 0
      sdetweil @allancherianbiju
      @allancherianbiju said in Doesn't contain package.json file:
      got what?
        allancherianbiju
        Formatting mistake. The error I posted isn’t showing up due to some reason.
        npm ERR! Could not install from “node_modules/ .bin/electron-rebuild” as it does not contain a package.json file.
          many components in a javascript application need to have their versions match the surrounding runtime. grpc is one of those… it will run in and outside the electron browser…
          the electron-rebuild module is loaded as part of the base,
          so you would do
          node_modules/.bin/electron_rebuild
            allancherianbiju
            Just closing notes. I was able to fix this!
            @sdetweil provided extra commands.
            npm install electron-rebuild
            That worked for me, but I was faced with a new error.
            Error: Cannot find module 'node_helper_.
            Fixed that by running
            cd -/MagicMirror
            git checkout modules/node_modules/node_helper/index.js
            Thanks for the help guys!
              allancherianbiju
              I had to reinstall MM and had to go through all of this again. Rebuilding electron fixed the issue and I found out that the git command I used doesn’t work anymore. Zzz… Updating should help.
              cd -/MagicMirror
              S 1 Reply Last reply Mar 5, 2020, 12:15 PM Reply Quote 0
                @allancherianbiju in version 2.10 we fixed this problem, by moving the file to a different location.
                A 1 Reply Last reply Mar 10, 2020, 7:38 AM Reply Quote 0
                  allancherianbiju @sdetweil
                  @sdetweil Oh! That’s great! Onward, then :D
