    MMM-Jeedom
    20 Posts 4 Posters 8.1k Views 4 Watching
      sdetweil @ELMAGO
      @ELMAGO i can read some french, I will use an online conversion tool to translate long text and sometimes my responses
      je peux lire du français, j’utiliserai un outil de conversion en ligne pour traduire des textes longs et parfois mes réponses
      E 1 Reply Last reply
      • E
        ELMAGO @sdetweil
        okay so i would make the effort, no problem, can answer my previous question?
        • E
          ELMAGO @ELMAGO
          @ELMAGO said in MMM-Jeedom:
          Exemple :
          				idx: "77",
          				customTitle: "Batterie Etage : ",
          				unit : "%",
          if the result is greater than 50 then I would like it to be in green
            sdetweil @ELMAGO
            @ELMAGO see my prior response
            le module ne fournit aucun nom de classe spécial que vous pouvez remplacer dans custom.css.
            c’est la seule section du module qui fait des noms de classe
            crée une ligne (tr)
            • E
              ELMAGO @sdetweil
              I’m sorry, I understood correctly for the css part, but not for the module itself.
              Could you give me this concrete example?
                sdetweil @ELMAGO
                @ELMAGO i’m not sure I understand the comment, but i’ll try…
                when the module generates content for the screen, each little piece can have different classes assigned.
                those classes can be used in the custom.css to manipulate the presentation of that segment.
                the cod in this modules does
                create tablerow (tr)
                assign class = ‘normal’ to everything in the row
                then it looks at the sensor data
                			if(sensor.boolean && sensor.status==1) symbolClass = sensor.symbolon;
                		        ----> if(typeof sensor.boolean== 'undefined') symbolClass = sensor.symbol;
                			symbol.className = symbolClass;
                and assigns a value to the (symbol is the icon )
                symbol.className
                and that is all
                so u have a class for the symbol
                and a class for the row.
                I think u want a class for the VALUE on the row but that was not supplied
                • E
                  ELMAGO @sdetweil
                  ok but how can i know it?
                    sdetweil @ELMAGO
                    @ELMAGO someone would have to change the code to add a class that you could then manipulate
                      chassain 0
                      Hello ,
                      I have tried this module (after an intallation of jeedom on rasp4) and i have no results on mirror… my config is certainly false because the result on terminal is good like this
                      curl -H “Content-Type: application/json” -X POST -d ‘{“jsonrpc”: “2.0”, “id”: “1000”, “method”: “cmd::execCmd”, “params”: {“apikey”: “my key”, “id”: 1}}’ http://192.168.1.28/core/api/jeeApi.php | python -m json.tool
                      % Total % Received % Xferd Average Speed Time Time Time Current
                      Dload Upload Total Spent Left Speed
                      100 248 100 123 100 125 1556 1582 --:–:-- --:–:-- --:–:-- 3179
                      “id”: “1000”,
                      “jsonrpc”: “2.0”,
                      “result”: {
                      “collectDate”: “2019-12-28 10:00:35”,
                      “value”: “A570; A57; Quai Marcel Pagnol Toulon”
                      my config is like
                      			module: 'MMM-Jeedom',
                      			header: 'Jeedom Maison',
                      			position: "center",
                      				updateInterval: 3000,
                      			      	jeedomAPIKey: "my key",
                      				jeedomURL: "192.168.1.28",
                      				jeedomPORT: 443,
                      				jeedomHTTPS: false,
                      				jeedomAPIPath: "/core/api/jeeApi.php",
                      				sensors: [
                      					idx: "1",
                      					customTitle: "Itinéraire1",
                      if you have an idea…thanks
                        sdetweil @chassain 0
                        @chassain-0 said in MMM-Jeedom:
                        	jeedomPORT: 443,    // < ---- should be 80 I think, because the url above uses port 80
                        	jeedomHTTPS: false,
                          chassain 0
                          hello man,
                          it’s the same result…
                            chassain 0
                            just this with console
                            Uncaught ReferenceError: moment is not defined
                            at Class.start (MMM-Jeedom.js:39)
                            at startModules (loader.js:55)
                            at loader.js:40
                            at HTMLLinkElement.stylesheet.onload (loader.js:200)
                            npm install on vendor done
                              @chassain-0 in your sample above you use
                              content-type:
                              but the module uses
                              ‘Content-Type’: ‘application/x-www-form-urlencoded’,
                              but sends json
                              if you start MM using the terminal window,
                              npm start
                              you should see some error
                              		  req.on('error', (e) => {
                              		  console.log(`problem with request: ${e.message}`);
                              also, the code does have a bug…
                              if sends the ‘chunk of data’, not the final response
                                              var databuffer="";
                              		var req = protocol.request(options, (res) => {
                              		  res.setEncoding('utf8');   // < --- hm should be ascii for json
                              		  res.on('data', (chunk) => {
                                                     databuffer+=chunk;
                              		  res.on('end', () => {
                              			self.sendSocketNotification("RELOAD_DONE",JSON.parse(databuffer));
                                this error is fatal… the module is dead
                                add to the MMM-Jeedom.js, the getScripts function below
                                	getStyles: function() {
                                	    return ['font-awesome.css'];
                                        getScripts: function() {                    //
                                            return ["moment.js"]                  //
                                  chassain 0
                                  @sdetweil said in MMM-Jeedom:
                                  that’s why i m noob and you…the professor :)
                                  Perfect !!! thanks
                                  • K
                                    kris1208
                                    Bonjour,
                                    Le module ne fonctionne plus ??
                                    J’ai pas d’affichage sur le mirroir.
                                    Jeedom en V3.3.45
                                    Merci
