    MMM-Jeedom
    20 Posts 4 Posters 8.1k Views 4 Watching
    • E
      ELMAGO @sdetweil
      okay so i would make the effort, no problem, can answer my previous question?
      E 1 Reply Last reply
      • E
        ELMAGO @ELMAGO
        @ELMAGO said in MMM-Jeedom:
        Exemple :
        				idx: "77",
        				customTitle: "Batterie Etage : ",
        				unit : "%",
        if the result is greater than 50 then I would like it to be in green
          sdetweil @ELMAGO
          @ELMAGO see my prior response
          le module ne fournit aucun nom de classe spécial que vous pouvez remplacer dans custom.css.
          c’est la seule section du module qui fait des noms de classe
          crée une ligne (tr)
          • E
            ELMAGO @sdetweil
            I’m sorry, I understood correctly for the css part, but not for the module itself.
            Could you give me this concrete example?
              sdetweil @ELMAGO
              @ELMAGO i’m not sure I understand the comment, but i’ll try…
              when the module generates content for the screen, each little piece can have different classes assigned.
              those classes can be used in the custom.css to manipulate the presentation of that segment.
              the cod in this modules does
              create tablerow (tr)
              assign class = ‘normal’ to everything in the row
              then it looks at the sensor data
              			if(sensor.boolean && sensor.status==1) symbolClass = sensor.symbolon;
              		        ----> if(typeof sensor.boolean== 'undefined') symbolClass = sensor.symbol;
              			symbol.className = symbolClass;
              and assigns a value to the (symbol is the icon )
              symbol.className
              and that is all
              so u have a class for the symbol
              and a class for the row.
              I think u want a class for the VALUE on the row but that was not supplied
              • E
                ELMAGO @sdetweil
                ok but how can i know it?
                  sdetweil @ELMAGO
                  @ELMAGO someone would have to change the code to add a class that you could then manipulate
                    chassain 0
                    Hello ,
                    I have tried this module (after an intallation of jeedom on rasp4) and i have no results on mirror… my config is certainly false because the result on terminal is good like this
                    curl -H “Content-Type: application/json” -X POST -d ‘{“jsonrpc”: “2.0”, “id”: “1000”, “method”: “cmd::execCmd”, “params”: {“apikey”: “my key”, “id”: 1}}’ http://192.168.1.28/core/api/jeeApi.php | python -m json.tool
                    % Total % Received % Xferd Average Speed Time Time Time Current
                    Dload Upload Total Spent Left Speed
                    100 248 100 123 100 125 1556 1582 --:–:-- --:–:-- --:–:-- 3179
                    “id”: “1000”,
                    “jsonrpc”: “2.0”,
                    “result”: {
                    “collectDate”: “2019-12-28 10:00:35”,
                    “value”: “A570; A57; Quai Marcel Pagnol Toulon”
                    my config is like
                    			module: 'MMM-Jeedom',
                    			header: 'Jeedom Maison',
                    			position: "center",
                    				updateInterval: 3000,
                    			      	jeedomAPIKey: "my key",
                    				jeedomURL: "192.168.1.28",
                    				jeedomPORT: 443,
                    				jeedomHTTPS: false,
                    				jeedomAPIPath: "/core/api/jeeApi.php",
                    				sensors: [
                    					idx: "1",
                    					customTitle: "Itinéraire1",
                    if you have an idea…thanks
                      sdetweil @chassain 0
                      @chassain-0 said in MMM-Jeedom:
                      	jeedomPORT: 443,    // < ---- should be 80 I think, because the url above uses port 80
                      	jeedomHTTPS: false,
                        chassain 0
                        hello man,
                        it’s the same result…
                          chassain 0
                          just this with console
                          Uncaught ReferenceError: moment is not defined
                          at Class.start (MMM-Jeedom.js:39)
                          at startModules (loader.js:55)
                          at loader.js:40
                          at HTMLLinkElement.stylesheet.onload (loader.js:200)
                          npm install on vendor done
                            @chassain-0 in your sample above you use
                            content-type:
                            but the module uses
                            ‘Content-Type’: ‘application/x-www-form-urlencoded’,
                            but sends json
                            if you start MM using the terminal window,
                            npm start
                            you should see some error
                            		  req.on('error', (e) => {
                            		  console.log(`problem with request: ${e.message}`);
                            also, the code does have a bug…
                            if sends the ‘chunk of data’, not the final response
                                            var databuffer="";
                            		var req = protocol.request(options, (res) => {
                            		  res.setEncoding('utf8');   // < --- hm should be ascii for json
                            		  res.on('data', (chunk) => {
                                                   databuffer+=chunk;
                            		  res.on('end', () => {
                            			self.sendSocketNotification("RELOAD_DONE",JSON.parse(databuffer));
                              this error is fatal… the module is dead
                              add to the MMM-Jeedom.js, the getScripts function below
                              	getStyles: function() {
                              	    return ['font-awesome.css'];
                                      getScripts: function() {                    //
                                          return ["moment.js"]                  //
                                chassain 0
                                @sdetweil said in MMM-Jeedom:
                                that’s why i m noob and you…the professor :)
                                Perfect !!! thanks
                                • K
                                  kris1208
                                  Bonjour,
                                  Le module ne fonctionne plus ??
                                  J’ai pas d’affichage sur le mirroir.
                                  Jeedom en V3.3.45
                                  Merci
