    MMM-Jeedom
    20 Posts 4 Posters 7.0k Views 4 Watching
    • E Offline
      ELMAGO @sdetweil
      Hello
      thank you for your answer, I have the impression that you speak French, I’m wrong?
      What you have provided me is a change of symbol if I understand well, how to do for the color of the font?
      Thanks in advance.
        sdetweil @ELMAGO
        @ELMAGO i can read some french, I will use an online conversion tool to translate long text and sometimes my responses
        je peux lire du français, j’utiliserai un outil de conversion en ligne pour traduire des textes longs et parfois mes réponses
        • E Offline
          ELMAGO @sdetweil
          okay so i would make the effort, no problem, can answer my previous question?
          • E Offline
            ELMAGO @ELMAGO
            @ELMAGO said in MMM-Jeedom:
            Exemple :
            				idx: "77",
            				customTitle: "Batterie Etage : ",
            				unit : "%",
            if the result is greater than 50 then I would like it to be in green
              sdetweil @ELMAGO
              @ELMAGO see my prior response
              le module ne fournit aucun nom de classe spécial que vous pouvez remplacer dans custom.css.
              c’est la seule section du module qui fait des noms de classe
              crée une ligne (tr)
              • E Offline
                ELMAGO @sdetweil
                I’m sorry, I understood correctly for the css part, but not for the module itself.
                Could you give me this concrete example?
                  sdetweil @ELMAGO
                  @ELMAGO i’m not sure I understand the comment, but i’ll try…
                  when the module generates content for the screen, each little piece can have different classes assigned.
                  those classes can be used in the custom.css to manipulate the presentation of that segment.
                  the cod in this modules does
                  create tablerow (tr)
                  assign class = ‘normal’ to everything in the row
                  then it looks at the sensor data
                  			if(sensor.boolean && sensor.status==1) symbolClass = sensor.symbolon;
                  		        ----> if(typeof sensor.boolean== 'undefined') symbolClass = sensor.symbol;
                  			symbol.className = symbolClass;
                  and assigns a value to the (symbol is the icon )
                  symbol.className
                  and that is all
                  so u have a class for the symbol
                  and a class for the row.
                  I think u want a class for the VALUE on the row but that was not supplied
                  • E Offline
                    ELMAGO @sdetweil
                    ok but how can i know it?
                      sdetweil @ELMAGO
                      @ELMAGO someone would have to change the code to add a class that you could then manipulate
                        chassain 0
                        Hello ,
                        I have tried this module (after an intallation of jeedom on rasp4) and i have no results on mirror… my config is certainly false because the result on terminal is good like this
                        curl -H “Content-Type: application/json” -X POST -d ‘{“jsonrpc”: “2.0”, “id”: “1000”, “method”: “cmd::execCmd”, “params”: {“apikey”: “my key”, “id”: 1}}’ http://192.168.1.28/core/api/jeeApi.php | python -m json.tool
                        % Total % Received % Xferd Average Speed Time Time Time Current
                        Dload Upload Total Spent Left Speed
                        100 248 100 123 100 125 1556 1582 --:–:-- --:–:-- --:–:-- 3179
                        “id”: “1000”,
                        “jsonrpc”: “2.0”,
                        “result”: {
                        “collectDate”: “2019-12-28 10:00:35”,
                        “value”: “A570; A57; Quai Marcel Pagnol Toulon”
                        my config is like
                        			module: 'MMM-Jeedom',
                        			header: 'Jeedom Maison',
                        			position: "center",
                        				updateInterval: 3000,
                        			      	jeedomAPIKey: "my key",
                        				jeedomURL: "192.168.1.28",
                        				jeedomPORT: 443,
                        				jeedomHTTPS: false,
                        				jeedomAPIPath: "/core/api/jeeApi.php",
                        				sensors: [
                        					idx: "1",
                        					customTitle: "Itinéraire1",
                        if you have an idea…thanks
