    MMM-Jeedom
    20 Posts 4 Posters 5.4k Views 4 Watching
    • E Offline
      ELMAGO
      Hello
      I use this plugin to get information on my Jeedom.
      I would like following the answer to change the font.
      For example in this query, if the answer is “green” then the font will be green.
      Dans cette autre exemple, si le trajet est supérieur à 18 alors la police sera rouge et gras.
      Merci pour votre aide
      • E Offline
        ELMAGO
        How can I help?
          sdetweil @ELMAGO
          @ELMAGO the module does not provide any special class names that you can override in custom.css.
          this is the only section of the module that does classnames
          creates a row (tr)
          le module ne fournit aucun nom de classe spécial que vous pouvez remplacer dans custom.css.
          c’est la seule section du module qui fait des noms de classe
          crée une ligne (tr)
          			var sensorWrapper = document.createElement("tr"); //on créé la liste principale, qu'on va remplir après
          			----> sensorWrapper.className = "normal";  <----
          			//on commence par afficher le symbole, selon tous les cas possible : symbol; symbolon, symboloff, ...
          			var symbolTD = document.createElement('td');
          			-----> symbolTD.className = "symbol align-left"; < -----
          			var symbol = document.createElement('i');
          			var symbolClass = sensor.symboloff;
          			if(sensor.boolean && sensor.status==1) symbolClass = sensor.symbolon;
          		        ----> if(typeof sensor.boolean== 'undefined') symbolClass = sensor.symbol;
          			symbol.className = symbolClass; < -----
          			symbolTD.appendChild(symbol);
          			sensorWrapper.appendChild(symbolTD); //et on ajoute le symbole au Wrapper
          symbol and whatever the sensor.symbol turns out to be (which is taken directly from the api response data)
          u might be able to change the font/color for the class ‘normal’
          in custom.css
          .MMM-Jeedom .tr .normal {
          color: red;
          • E Offline
            ELMAGO @sdetweil
            Hello
            thank you for your answer, I have the impression that you speak French, I’m wrong?
            What you have provided me is a change of symbol if I understand well, how to do for the color of the font?
            Thanks in advance.
              sdetweil @ELMAGO
              @ELMAGO i can read some french, I will use an online conversion tool to translate long text and sometimes my responses
              je peux lire du français, j’utiliserai un outil de conversion en ligne pour traduire des textes longs et parfois mes réponses
              • E Offline
                ELMAGO @sdetweil
                okay so i would make the effort, no problem, can answer my previous question?
                • E Offline
                  ELMAGO @ELMAGO
                  @ELMAGO said in MMM-Jeedom:
                  Exemple :
                  				idx: "77",
                  				customTitle: "Batterie Etage : ",
                  				unit : "%",
                  if the result is greater than 50 then I would like it to be in green
                    sdetweil @ELMAGO
                    @ELMAGO see my prior response
                    crée une ligne (tr)
                    • E Offline
                      ELMAGO @sdetweil
                      I’m sorry, I understood correctly for the css part, but not for the module itself.
                      Could you give me this concrete example?
                        sdetweil @ELMAGO
                        @ELMAGO i’m not sure I understand the comment, but i’ll try…
                        when the module generates content for the screen, each little piece can have different classes assigned.
                        those classes can be used in the custom.css to manipulate the presentation of that segment.
                        the cod in this modules does
                        create tablerow (tr)
                        assign class = ‘normal’ to everything in the row
                        then it looks at the sensor data
                        and assigns a value to the (symbol is the icon )
                        symbol.className
                        and that is all
                        so u have a class for the symbol
                        and a class for the row.
                        I think u want a class for the VALUE on the row but that was not supplied
