    Problem with updating to 2.10.0 from 2.9.0 using update script
    15 Posts 3 Posters 7.0k Views 3 Watching
      yeh, a bug got thru … i have a temporary updated script
      see here.
      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
      also posted after Mich’s topic of the version update yesterday…
      https://forum.magicmirror.builders/topic/11899/v2-10-0
      • O
        outlying
        Unluckily scripts under 1st post
        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing/1
        have the same issue at the ones I already tried, I’m not sure if I should go through whole thread, I admit I didn’t
          sdetweil @outlying
          @outlying show me the log file, ~/MagicMirror/installers/upgrade.log
            @sdetweil u need to erase the ~/MagicMirror/installers/dumpactivemodules.js file…
            then run the updated script.
            sorry, forgot that
            • O
              outlying
              Oh, my bad, I just deleted file rm ~/MagicMirror/installers/dumpactivemodules.js
              and I did run update script, with result
              the log will be /home/pi/MagicMirror/installers/upgrade.log
              No LSB modules are available.
              doing test run = false
              saving custom.css
              upgrading from version 2.9.0 to 2.10.0
              fetching latest revisions
              apply: line 244: npm: command not found
              no modules found needing npm refresh
              restoring custom.css
              So I restarted pm2 restart mm but now MM is in error, according to pm2 status
              Running standard pm2 start mm.sh does not start MM anymore, it just go to errored status
                sdetweil @outlying
                @outlying but npm had to be installed before… I just use it
                that line 244 is npm install
                and I don’t know where the 'apply: ’ came from
                  this is what my MM/installers/upgrade.log says
                  Upgrade started - Thu Jan  2 06:29:19 CST 2020
                  system is Linux raspberrypi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                  user requested to apply changes
                  saving custom.css
                  remote name = origin
                  git fetch rc=0
                  current branch = master
                  On branch master
                  Your branch is behind 'origin/master' by 2832 commits, and can be fast-forwarded.
                    (use "git pull" to update your local branch)
                  Changes to be committed:
                    (use "git reset HEAD <file>..." to unstage)
                  	deleted:    css/custom.css
                    (use "git add <file>..." to update what will be committed)
                    (use "git checkout -- <file>..." to discard changes in working directory)
                  	modified:   package-lock.json
                  	modified:   package.json
                  Untracked files:
                    (use "git add <file>..." to include in what will be committed)
                  	css/save_custom.css
                  	somefile
                  there are 2 local files that are different than the master repo
                     package-lock.json
                     package.json
                  save/restore files selection = n
                  restoring package-lock.json from repo
                  restoring package.json from repo
                  test merge result rc='' , if empty, no conflicts
                  executing merge, apply specified
                  merge result rc= 0
                   Updating 500147e..b595cdd Fast-forward  .gitignore
                      6 -  .snyk
                     14 -  .travis.yml
                      8 +-  CHANGELOG.md
                     28 +-  README.md
                     17 +-  config/config.js.sample
                      7 +-  css/custom.css
                     14 -  installers/dumpactivemodules.js
                     15 +  installers/fixuppm2.sh
                    183 +  installers/raspberry.sh
                    560 ++-  installers/screensaveroff.sh
                    101 +  installers/upgrade-script.sh
                    361 ++  js/app.js
                      6 +  js/main.js
                     17 +-  .../node_helper/index.js => js/node_helper.js
                      2 +-  js/server.js
                      2 +-  modules/default/calendar/calendar.js
                      1 +  modules/default/calendar/calendarfetcher.js
                      7 +-  modules/default/calendar/debug.js
                      4 +-  modules/default/compliments/compliments.js
                     39 +-  modules/default/weatherforecast/weatherforecast.js
                      4 +-  package-lock.json
                   4187 +++++++++++---------  package.json
                     17 +-  run-start.sh
                     64 +-  tests/e2e/modules/weather_spec.js
                    138 +-  tests/e2e/vendor_spec.js
                      5 +-  untrack-css.sh
                      2 +-  vendor/package-lock.json
                      2 +-  28 files changed, 3648 insertions(+), 2163 deletions(-)  delete mode 100644 .snyk  delete mode 100644 css/custom.css
                  create mode 100644 installers/dumpactivemodules.js
                  create mode 100755 installers/fixuppm2.sh
                  mode change 100644 => 100755 installers/raspberry.sh
                  create mode 100755 installers/screensaveroff.sh
                  create mode 100755 installers/upgrade-script.sh  rename modules/node_modules/node_helper/index.js => js/node_helper.js (98%)
                  mode change 100644 => 100755 run-start.sh
                  processor architecture is armv7l
                  • O
                    outlying
                    @sdetweil I don’t know how to respond in that case, ofc I have to had it installed earlier in order for MM to work, but right now it seems system is not seeing it, only bash: npm: command not found sooooo … I think since it’s fresh install I will reinstall everything
                      sdetweil @outlying
                      @outlying close that terminal window and reopen it, npm should not have been removed…
                      O 1 Reply Last reply
                      • O
                        outlying @sdetweil
                        @sdetweil I’ve done it right away it but it’s not there anymore, somehow it’s messed up
                          sdetweil @outlying
                          @outlying weird… sudo apt-get install npm
                          then sudo npm i -g npm to get latest
                          node -v
                          and
                          npm -v
                          to verify levels
                            ChrizZz
                            sorry to use the same topic. I have also trouble with the update to 2.10.0. The update script works, but I still have the notification that there is an update for MM. But the update log ends with “Upgrade ended - Do Jan 2 20:24:45 CET 2020”.
                            • O
                              outlying
                              @sdetweil I appreciate your fast responses :-) it’s really inspiring, but it would be way easier for me to set it up again in a matter of few minutes instead of trying to figure out what went wrong
                              Right now I have lock on dpkg files
                              E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
                              E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
                              So it all messed up :-/ this is very fresh setup so I really don’t mind purging it
                                sdetweil @outlying
                                @outlying save your magicmirror config.js at least!
