    git issues after automatic install
    Scheduled Pinned Locked Moved Solved Bug Hunt
    7 Posts 2 Posters 1.3k Views 2 Watching
      sdetweil @benjay
      @benjay from the MagicMirror folder do
      git status
      df -k
      which auto install script did u use? linked from MagicMirror github readme page?
      if so, erase MagicMirror/installers/dumpactivemodules.js
      then run the updated installer
      see here
      https://forum.magicmirror.builders/topic/10171/updated-installer-script-available-for-testing
        benjay
        Hi Sam,
        thx - so here we go:
        pi @ MAGICMIRROR: ~ / MagicMirror $ git status
        On branch master
        Your branch is on the same level as 'origin / master'.
        Changes that are not marked for commit:
          (use "git add <file> ..." to mark the commit changes)
          (use "git checkout - <file> ..." to discard the changes in the working directory)
                changed: package-lock.json
        Unversioned files:
                core
        no commit commit changes (use "git add" and / or "git commit
         -a")
        df -k returns (imho engough space left):
        pi@MAGICMIRROR:~/MagicMirror $ df -k
        Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
        /dev/root       30358348 3935644  25138208   14% /
        devtmpfs          443156       0    443156    0% /dev
        tmpfs             447764   19884    427880    5% /dev/shm
        tmpfs             447764   45300    402464   11% /run
        tmpfs               5120       4      5116    1% /run/lock
        tmpfs             447764       0    447764    0% /sys/fs/cgroup
        /dev/mmcblk0p1    258095   53034    205061   21% /boot
        tmpfs              89552       0     89552    0% /run/user/1000
        The file MagicMirror/installers/dumpactivemodules.js has been erased/moved to temp folder (/home/pi/temp).
        Yep - for installation - I used the CMD (user PI) from the README as below:
        bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
        I tried the update script as mentioned in the related link- please find the RCs below:
        pi@MAGICMIRROR:~/MagicMirror $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
        install log being saved to /home/pi/install.log
        Updating packages ...
        Installing helper tools ...
        Paketlisten werden gelesen... Fertig
        Abhängigkeitsbaum wird aufgebaut.
        Statusinformationen werden eingelesen.... Fertig
        build-essential ist schon die neueste Version (12.6).
        curl ist schon die neueste Version (7.64.0-4).
        git ist schon die neueste Version (1:2.20.1-2+deb10u1).
        unzip ist schon die neueste Version (6.0-23+deb10u1).
        wget ist schon die neueste Version (1.20.1-1.1).
        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 3 nicht aktualisiert.
        Minimum Node version: v10.1.0
        Installed Node version: v10.18.0
        No Node.js upgrade necessary.
        Minimum npm version: V6.0.0
        Installed npm version: V6.13.4
        No npm upgrade necessary.
        It seems like MagicMirror is already installed.
        To prevent overwriting, the installer will be aborted.
        Please rename the ~/MagicMirror folder and try again.
        If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
        pi@MAGICMIRROR:~/MagicMirror $ cd installers/
        pi@MAGICMIRROR:~/MagicMirror/installers $ ll
        insgesamt 84
        drwxr-xr-x  3 pi pi  4096 Jan  6 20:22 .
        drwxr-xr-x 17 pi pi  4096 Jan  5 20:45 ..
        -rw-r--r--  1 pi pi   342 Jan  6 20:22 dumpactivemodules.js
        -rwxr-xr-x  1 pi pi  6443 Jan  4 18:23 fixuppm2.sh
        -rwxr-xr-x  1 pi pi    38 Jan  4 18:23 mm.sh
        -rw-r--r--  1 pi pi   181 Jan  4 18:23 pm2_MagicMirror.json
        drwxr-xr-x  2 pi pi  4096 Jan  4 18:23 postinstall
        -rwxr-xr-x  1 pi pi 22409 Jan  4 18:23 raspberry.sh
        -rwxr-xr-x  1 pi pi  4443 Jan  4 18:23 screensaveroff.sh
        -rw-r--r--  1 pi pi  3799 Jan  6 20:22 upgrade.log
        -rwxr-xr-x  1 pi pi 12710 Jan  4 18:23 upgrade-script.sh
        pi@MAGICMIRROR:~/MagicMirror/installers $ ./upgrade-script.sh
        the log will be /home/pi/MagicMirror/installers/upgrade.log
        No LSB modules are available.
        doing test run = true
        saving custom.css
        cp: der Aufruf von stat für 'custom.css' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
        upgrading from version 2.10.0 to 2.10.0
        fetching latest revisions
        no modules found needing npm refresh
        restoring custom.css
        cp: der Aufruf von stat für 'save_custom.css' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
        rm: das Entfernen von 'save_custom.css' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
        and again GIT status returns the same as above.
        Cheers
          sdetweil @benjay
          @benjay ok, both install and update have bugs on the official page…
          because u have moved patially to 2.10, you need to do this to update
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
          I can’t tell what u wanted to do…
          install is 1st time (using raspberry.sh)
          update is every quarter (using update_script.sh)
            benjay
            thx for the hint. I did the “forced” update as requested:
            pi@MAGICMIRROR:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubuserconten                                      t.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            doing test run = false
            > magicmirror@2.10.0 install /home/pi/MagicMirror
            > cd vendor && npm install
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fse                                      vents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                      1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                      )
            audited 220 packages in 24.324s
            found 5 vulnerabilities (4 low, 1 high)
              run `npm audit fix` to fix them, or `npm audit` for details
            > magicmirror@2.10.0 postinstall /home/pi/MagicMirror
            > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run insta                                      ll-fonts
            MagicMirror installation successful!
            > magicmirror@2.10.0 install-fonts /home/pi/MagicMirror
            > cd fonts && npm install
            audited 1 package in 2.217s
            found 0 vulnerabilities
            updated 3 packages and audited 3684 packages in 169.644s
            15 packages are looking for funding
              run `npm fund` for details
            Unfortunately the GIT status is still reporting issues (same as before)
            pi@MAGICMIRROR:~/MagicMirror/modules $ git status
            Auf Branch master
            Ihr Branch ist auf demselben Stand wie 'origin/master'.
            Änderungen, die nicht zum Commit vorgemerkt sind:
              (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
              (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                    geändert:       ../package-lock.json
            Unversionierte Dateien:
                    ../0
                    ../core
            keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
              benjay
              reboot it was :D
                sdetweil @benjay
                @benjay Unfortunately the GIT status is still reporting issues (same as before)
                those aren’t issues
                the package-lock.json is generated by the npm install, so its new and changed.
                the 0 is a bug from the installer once
                and the core is some dump from npm/node crashing at some time.
                all is good…
                (git status in the MagicMirror folder should show the same output after reboot)
