    git issues after automatic install
    Scheduled Pinned Locked Moved Solved Bug Hunt
    7 Posts 2 Posters 1.3k Views 2 Watching
      benjay
      Dear all,
      I hope you can quickly provide support for this. After I did a successful installation of mm2 on my PI2 - I’d like to download & install new modules now. Unfortunately, GIT seems to be in a kind of hanging state and I`m a total noob to GIT. :(
      Please check some of the RCs I get when trying to install a 3rd Party module.
      As an example --> This happens when I try to clone a repository to my modules folder:
      pi@MAGICMIRROR:~/MagicMirror/modules $ git clone https://github.com/rseidt/MMM-bringList
      Cloning 'MMM-bringList' ...
      remote: Enumerating objects: 22, done.
      remote: Counting objects: 100% (22/22), done.
      remote: Compressing objects: 100% (15/15), done.
      error: Could not create temporary file: The argument is invalid
      fatal: failed to write object
      fatal: unpack-objects failed
      OK, so far so good - seems like GIT has an issue with my local repos. I tried already GIT with the argument GIT rebase which leads to the following output:
      pi@MAGICMIRROR:~/MagicMirror/modules $ git rebase
      error: rebase not possible: You have changes that are not marked for commit.
      error: Please commit the changes or use "stash".
      Running the stash option - this asks me to provide an email etc. - so no option to move onwards.
      So quick break here - hope one of you - guys have an idea how to solve this.
      cheers
      Benjay
        sdetweil @benjay
        @benjay from the MagicMirror folder do
        git status
        df -k
        which auto install script did u use? linked from MagicMirror github readme page?
        if so, erase MagicMirror/installers/dumpactivemodules.js
        then run the updated installer
        see here
        https://forum.magicmirror.builders/topic/10171/updated-installer-script-available-for-testing
          benjay
          Hi Sam,
          thx - so here we go:
          pi @ MAGICMIRROR: ~ / MagicMirror $ git status
          On branch master
          Your branch is on the same level as 'origin / master'.
          Changes that are not marked for commit:
            (use "git add <file> ..." to mark the commit changes)
            (use "git checkout - <file> ..." to discard the changes in the working directory)
                  changed: package-lock.json
          Unversioned files:
                  core
          no commit commit changes (use "git add" and / or "git commit
           -a")
          df -k returns (imho engough space left):
          pi@MAGICMIRROR:~/MagicMirror $ df -k
          Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
          /dev/root       30358348 3935644  25138208   14% /
          devtmpfs          443156       0    443156    0% /dev
          tmpfs             447764   19884    427880    5% /dev/shm
          tmpfs             447764   45300    402464   11% /run
          tmpfs               5120       4      5116    1% /run/lock
          tmpfs             447764       0    447764    0% /sys/fs/cgroup
          /dev/mmcblk0p1    258095   53034    205061   21% /boot
          tmpfs              89552       0     89552    0% /run/user/1000
          The file MagicMirror/installers/dumpactivemodules.js has been erased/moved to temp folder (/home/pi/temp).
          Yep - for installation - I used the CMD (user PI) from the README as below:
          bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
          I tried the update script as mentioned in the related link- please find the RCs below:
          pi@MAGICMIRROR:~/MagicMirror $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
          install log being saved to /home/pi/install.log
          Updating packages ...
          Installing helper tools ...
          Paketlisten werden gelesen... Fertig
          Abhängigkeitsbaum wird aufgebaut.
          Statusinformationen werden eingelesen.... Fertig
          build-essential ist schon die neueste Version (12.6).
          curl ist schon die neueste Version (7.64.0-4).
          git ist schon die neueste Version (1:2.20.1-2+deb10u1).
          unzip ist schon die neueste Version (6.0-23+deb10u1).
          wget ist schon die neueste Version (1.20.1-1.1).
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 3 nicht aktualisiert.
          Minimum Node version: v10.1.0
          Installed Node version: v10.18.0
          No Node.js upgrade necessary.
          Minimum npm version: V6.0.0
          Installed npm version: V6.13.4
          No npm upgrade necessary.
          It seems like MagicMirror is already installed.
          To prevent overwriting, the installer will be aborted.
          Please rename the ~/MagicMirror folder and try again.
          If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
          pi@MAGICMIRROR:~/MagicMirror $ cd installers/
          pi@MAGICMIRROR:~/MagicMirror/installers $ ll
          insgesamt 84
          drwxr-xr-x  3 pi pi  4096 Jan  6 20:22 .
          drwxr-xr-x 17 pi pi  4096 Jan  5 20:45 ..
          -rw-r--r--  1 pi pi   342 Jan  6 20:22 dumpactivemodules.js
          -rwxr-xr-x  1 pi pi  6443 Jan  4 18:23 fixuppm2.sh
          -rwxr-xr-x  1 pi pi    38 Jan  4 18:23 mm.sh
          -rw-r--r--  1 pi pi   181 Jan  4 18:23 pm2_MagicMirror.json
          drwxr-xr-x  2 pi pi  4096 Jan  4 18:23 postinstall
          -rwxr-xr-x  1 pi pi 22409 Jan  4 18:23 raspberry.sh
          -rwxr-xr-x  1 pi pi  4443 Jan  4 18:23 screensaveroff.sh
          -rw-r--r--  1 pi pi  3799 Jan  6 20:22 upgrade.log
          -rwxr-xr-x  1 pi pi 12710 Jan  4 18:23 upgrade-script.sh
          pi@MAGICMIRROR:~/MagicMirror/installers $ ./upgrade-script.sh
          the log will be /home/pi/MagicMirror/installers/upgrade.log
          No LSB modules are available.
          doing test run = true
          saving custom.css
          cp: der Aufruf von stat für 'custom.css' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
          upgrading from version 2.10.0 to 2.10.0
          fetching latest revisions
          no modules found needing npm refresh
          restoring custom.css
          cp: der Aufruf von stat für 'save_custom.css' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
          rm: das Entfernen von 'save_custom.css' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
          and again GIT status returns the same as above.
          Cheers
            sdetweil @benjay
            @benjay ok, both install and update have bugs on the official page…
            because u have moved patially to 2.10, you need to do this to update
            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            I can’t tell what u wanted to do…
            install is 1st time (using raspberry.sh)
            update is every quarter (using update_script.sh)
              benjay
              thx for the hint. I did the “forced” update as requested:
              pi@MAGICMIRROR:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubuserconten                                      t.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
              doing test run = false
              > magicmirror@2.10.0 install /home/pi/MagicMirror
              > cd vendor && npm install
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fse                                      vents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                      1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                      )
              audited 220 packages in 24.324s
              found 5 vulnerabilities (4 low, 1 high)
                run `npm audit fix` to fix them, or `npm audit` for details
              > magicmirror@2.10.0 postinstall /home/pi/MagicMirror
              > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run insta                                      ll-fonts
              MagicMirror installation successful!
              > magicmirror@2.10.0 install-fonts /home/pi/MagicMirror
              > cd fonts && npm install
              audited 1 package in 2.217s
              found 0 vulnerabilities
              updated 3 packages and audited 3684 packages in 169.644s
              15 packages are looking for funding
                run `npm fund` for details
              Unfortunately the GIT status is still reporting issues (same as before)
              pi@MAGICMIRROR:~/MagicMirror/modules $ git status
              Auf Branch master
              Ihr Branch ist auf demselben Stand wie 'origin/master'.
              Änderungen, die nicht zum Commit vorgemerkt sind:
                (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                      geändert:       ../package-lock.json
              Unversionierte Dateien:
                      ../0
                      ../core
              keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
                benjay
                reboot it was :D
                  sdetweil @benjay
                  @benjay Unfortunately the GIT status is still reporting issues (same as before)
                  those aren’t issues
                  the package-lock.json is generated by the npm install, so its new and changed.
                  the 0 is a bug from the installer once
                  and the core is some dump from npm/node crashing at some time.
                  all is good…
                  (git status in the MagicMirror folder should show the same output after reboot)
