    MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion
    50 Posts 5 Posters 18.9k Views 5 Watching
    • G Offline
      guongthongminh @Guest
      @Sean Can I use the default browser, Chromium?
      MMM-PageReader is also possible.
      Sorry for not good at english!
        [[global:former-user]] @guongthongminh
        @guongthongminh
        First, using default Browser(Chromium) is not so good idea. You could lose control.
        I’m reading MMM-PageReader(https://github.com/dgburr/MMM-PageReader) now, it seems possible to use.
        models: [
            hotwords    : "smart_mirror",
            file        : "smart_mirror.umdl",
            sensitivity : "0.5",
          // You can add more models here.
        commands: {
          "smart_mirror": {
            notificationExec: {
              notification: "PAGE_READER_LOAD",
              payload: "https://forum.magicmirror.builders/topic...."
        // You can add more commands here
        In this example, you can activate MMM-PageReader with hotword “smart mirror”. Not tested, but ideally working like this.
        G S 3 Replies Last reply Reply Quote 0
        • G Offline
          @Sean Thank you very much!
          Let me try and see how I hope it will look perfect
          • G Offline
            @Sean Is my config file ok?
            I think it’s almost not working, please help me!
            alt text
              sdetweil @Guest
              @Sean said in MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion:
              on the armv6 processors (pi 0, 1 and some 3), the electron browser is no longer available at the newer node versions (>8) we are running on 10, so they have to use some other browser and serveronly split mode
              • G Offline
                guongthongminh @sdetweil
                @sdetweil Can you be more specific? Can you help me finish my project because I’m interested in it !!!
                  sdetweil @guongthongminh
                  @guongthongminh I dont think this is your problem
                  you have two models: [] sections above
                  one that says the hotword is smart_mirror
                  and one that says “tin_tuc”
                  I don’t know which became active…
                  just take the
                      hotwords: "tin tuc",
                      file:   ..,
                      sensitivity: "0.5"
                  and put it into the the models array above
                  • G Offline
                    @sdetweil The hot word is “hotword” for using mmm-asisstantMK2
                    hot word “tun tuc” to call mmm-pagereader
                    The result I want it like this https://www.youtube.com/watch?v=xdLz0bdxO58
                    Can you help me because I don’t know much about this!
                      @guongthongminh sorry, I cannot help…
                      • G Offline
                        guongthongminh
                        @Sean
                        I really need your support !!! Please
                          @guongthongminh
                          You did define models twice, so previous one (“smart_mirror”) is ignored.
                          do like this; (I wrote You can add more models here but you might not see.)
                          models: [
                              hotwords: "smart_mirror",
                              hotwords: "tin_tuc",
                          • G Offline
                            @Sean I fixed this but still could not get the MMM-PageReader module to appear on the screen. Could the cause be from the MMM-PageReader modules?
                            alt text
                              @guongthongminh
                              Don’t do what you can’t understand.
                              I wrote in my earlier answer, payload was something like this;
                              payload: "URL TO OPEN",
                              But in your last post, you did like this;
                              payload: (detected, afterRecord) => { ... }
                              It doesn’t make sense.
                              • G Offline
                                @Sean Sorry, I tried this but the result is still the same
                                alt text
                                  @guongthongminh
                                  Let’s check. See the backend logs and the frontend logs.
                                  1. Hotword tin_tuc was caught normally? (You can check the result on backend log)
                                    1. If so, notification was emitted normally? (You can check it on frontend log)
                                      1. if so, well, that’s not my business. Maybe MMM-PageReader has some issue about using notification.
                                      2. If not, you probably have some error(s) on frontend to prevent working of module. Solve them first.
                                    2. If not, you should solve the hotword issue first. maybe your tin_tuc.pmdl was not catchable.
                                  • G Offline
                                    @Sean The mirror receives and answers like this: “This feature is not yet supported on this device”. I cannot determine the cause.
                                      @guongthongminh ??? where did you see that message?
                                      • G Offline
                                        @Sean google assistant said
                                          @guongthongminh
                                          ??? You are working about MMM-Hotword, not MMM-AssistantMk2 right?
                                          If Google says something, you’ve activated MMM-AssistantMk2. It means…
                                          You played like this? "smart mirror, tin tuc!"? This is not the usage you are doing.
                                          I answered How to use hotword to control other modules until now, and your current approach is totally wrong.
                                          So what you want exactly? Using Google Assistant to tin tuc? (I think its not needed because you’ve already your .pmdl made)
                                          • G Offline
                                            @Sean Sorry for my mistake. I want the result to be the same as the video: https://www.youtube.com/watch?v=xdLz0bdxO58
