    MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion
    50 Posts 5 Posters 19.4k Views 5 Watching
      A Former User @MichaelKrems
      @MichaelKrems
      You don’t need to use all of the fields of configuration sample.
      Just try from here;
      https://github.com/eouia/MMM-AssistantMk2/wiki/Configuration#with-mmm-hotwordv2 (with MMM-Hotword(v2) section)
      • G Offline
        guongthongminh @Guest
        @Sean You can help me with the command exec section, calling the browser with the parameter as well as the command line in mmm-hotword
          A Former User @guongthongminh
          @guongthongminh Sorry, I can’t catch your intention. What exactly do you want to do?
          G 2 Replies Last reply Reply Quote 0
          • G Offline
            @Sean Can you help me with the website part shown on the mirror?
            • G Offline
              @Sean using MMM-NotificationTrigger to invoke the voice search browser
                @guongthongminh
                Do you mean, you want to show specific web page when you say hotword?
                In that case, which module are you using to show web page?
                • G Offline
                  @Sean Can I use the default browser, Chromium?
                  MMM-PageReader is also possible.
                  Sorry for not good at english!
                    @guongthongminh
                    First, using default Browser(Chromium) is not so good idea. You could lose control.
                    I’m reading MMM-PageReader(https://github.com/dgburr/MMM-PageReader) now, it seems possible to use.
                    models: [
                        hotwords    : "smart_mirror",
                        file        : "smart_mirror.umdl",
                        sensitivity : "0.5",
                      // You can add more models here.
                    commands: {
                      "smart_mirror": {
                        notificationExec: {
                          notification: "PAGE_READER_LOAD",
                          payload: "https://forum.magicmirror.builders/topic...."
                    // You can add more commands here
                    In this example, you can activate MMM-PageReader with hotword “smart mirror”. Not tested, but ideally working like this.
                    G S 3 Replies Last reply Reply Quote 0
                    • G Offline
                      @Sean Thank you very much!
                      Let me try and see how I hope it will look perfect
                      • G Offline
                        @Sean Is my config file ok?
                        I think it’s almost not working, please help me!
                        alt text
                          sdetweil @Guest
                          @Sean said in MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion:
                          on the armv6 processors (pi 0, 1 and some 3), the electron browser is no longer available at the newer node versions (>8) we are running on 10, so they have to use some other browser and serveronly split mode
                          • G Offline
                            guongthongminh @sdetweil
                            @sdetweil Can you be more specific? Can you help me finish my project because I’m interested in it !!!
                              sdetweil @guongthongminh
                              @guongthongminh I dont think this is your problem
                              you have two models: [] sections above
                              one that says the hotword is smart_mirror
                              and one that says “tin_tuc”
                              I don’t know which became active…
                              just take the
                                  hotwords: "tin tuc",
                                  file:   ..,
                                  sensitivity: "0.5"
                              and put it into the the models array above
                              • G Offline
                                @sdetweil The hot word is “hotword” for using mmm-asisstantMK2
                                hot word “tun tuc” to call mmm-pagereader
                                The result I want it like this https://www.youtube.com/watch?v=xdLz0bdxO58
                                Can you help me because I don’t know much about this!
                                  @guongthongminh sorry, I cannot help…
                                  • G Offline
                                    guongthongminh
                                    @Sean
                                    I really need your support !!! Please
                                      @guongthongminh
                                      You did define models twice, so previous one (“smart_mirror”) is ignored.
                                      do like this; (I wrote You can add more models here but you might not see.)
                                      models: [
                                          hotwords: "smart_mirror",
                                          hotwords: "tin_tuc",
                                      • G Offline
                                        @Sean I fixed this but still could not get the MMM-PageReader module to appear on the screen. Could the cause be from the MMM-PageReader modules?
                                        alt text
                                          @guongthongminh
                                          Don’t do what you can’t understand.
                                          I wrote in my earlier answer, payload was something like this;
                                          payload: "URL TO OPEN",
                                          But in your last post, you did like this;
                                          payload: (detected, afterRecord) => { ... }
                                          It doesn’t make sense.
                                          • G Offline
                                            @Sean Sorry, I tried this but the result is still the same
                                            alt text
