    MagicMirror stopped working after screensaver installed
    16 Posts 2 Posters 5.5k Views 3 Watching
      sdetweil @demetry07
      @demetry07 weird…
      please do
      npm instal
      advise npm start results after
        demetry07
        That fixed it thank you.
          sdetweil @demetry07
          @demetry07 for the future, I have a script as part of install to disable screensaver on a lot of systems…
          its also in the installers folder with 2.10
          screensaveroff.sh
            demetry07 @sdetweil
            @sdetweil When I ran the install it asked me if I wanted to disable screensaver and I said yes but my screen was still going black over night. I would have to CTRL-Q out then it would run again automatically after a few seconds. Thought installing the screensaver and disabling it would help. Will see after tonight.
              demetry07
              I spoke to soon. This morning it stopped working again.
              I ran
              npm install
              then
              sudo reboot
              then cd ~/MagicMirror
              then
              npm start
              Here are the results
              magicmirror@2.10.0 start /home/pi/MagicMirror
              ./run-start.sh
              [11:35:13.428] [LOG] Starting MagicMirror: v2.10.0
              [11:35:13.448] [LOG] Loading config …
              [11:35:13.463] [LOG] Loading module helpers …
              [11:35:13.466] [LOG] No helper found for module: alert.
              [11:35:13.594] [LOG] Initializing new module helper …
              [11:35:13.596] [LOG] Module helper loaded: updatenotification
              [11:35:13.597] [LOG] No helper found for module: clock.
              [11:35:13.599] [LOG] No helper found for module: currentweather.
              /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorENS_14SideEffectTypeE
              npm ERR! code ELIFECYCLE
              npm ERR! syscall spawn
              npm ERR! file sh
              npm ERR! errno ENOENT
              npm ERR! magicmirror@2.10.0 start: ./run-start.sh
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.10.0 start script.
              npm ERR! /home/pi/.npm/_logs/2020-01-07T17_35_13_737Z-debug.log
              I pulled the log file here is the data in the log file.
              1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
              2 info using npm@6.13.4
              3 info using node@v10.18.0
              4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
              5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
              6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
              7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
              8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
              10 silly lifecycle magicmirror@2.10.0~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
              11 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
              12 verbose stack Error: magicmirror@2.10.0 start: ./run-start.sh
              12 verbose stack spawn ENOENT
              12 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
              12 verbose stack at ChildProcess.emit (events.js:198:13)
              12 verbose stack at maybeClose (internal/child_process.js:982:16)
              12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
              13 verbose pkgid magicmirror@2.10.0
              14 verbose cwd /home/pi/MagicMirror
              15 verbose Linux 4.19.75-v7+
              16 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
              17 verbose node v10.18.0
              18 verbose npm v6.13.4
              19 error code ELIFECYCLE
              20 error syscall spawn
              21 error file sh
              22 error errno ENOENT
              23 error magicmirror@2.10.0 start: ./run-start.sh
              23 error spawn ENOENT
              24 error Failed at the magicmirror@2.10.0 start script.
              24 error This is probably not a problem with npm. There is likely additional logging output above.
              25 verbose exit [ 1, true ]
              Thoughts?
                sdetweil @demetry07
                @demetry07 said in MagicMirror stopped working after screensaver installed:
                fun times!!
                do
                npm install electron-rebuild
                node_modules/.bin/electron-rebuild
                  demetry07
                  Ran the suggested commands see below. Looks like they both ran just fine.
                  pi@raspberrypi:~/MagicMirror $ npm install electron-rebuild
                  • electron-rebuild@1.8.8
                    added 68 packages from 42 contributors and audited 3926 packages in 124.52s
                  16 packages are looking for funding
                  run npm fund for details
                  found 0 vulnerabilities
                  pi@raspberrypi:~/MagicMirror $ node_modules/.bin/electron-rebuild
                  ✔ Rebuild Complete
                  ./run-start.sh
                  [11:51:32.453] [LOG] Starting MagicMirror: v2.10.0
                  [11:51:32.478] [LOG] Loading config …
                  [11:51:32.491] [LOG] Loading module helpers …
                  [11:51:32.494] [LOG] No helper found for module: alert.
                  [11:51:32.615] [LOG] Initializing new module helper …
                  [11:51:32.617] [LOG] Module helper loaded: updatenotification
                  [11:51:32.619] [LOG] No helper found for module: clock.
                  [11:51:32.620] [LOG] No helper found for module: currentweather.
                  npm ERR! file sh
                  npm ERR!
                  npm ERR! /home/pi/.npm/_logs/2020-01-07T17_51_32_806Z-debug.log
                    sdetweil @demetry07
                    @demetry07 ok, module is a pain in the butt…
                    cd modules/MMM-PIR
                    npm install
                    ~/MagicMirror/node_modules/.bin/electron-rebuild
                      demetry07
                      Yeah I missed that in the log I see it now. Thanks for the help after updating that Module it’s starting again. Do you have a recommendation for a PIR Module that works better then something else?
                        sdetweil @demetry07
                        @demetry07 no… sorry, none of the PIR modules play nice
                          demetry07
                          Ok thank you again for helping.
