    MagicMirror stopped working after screensaver installed
    16 Posts 2 Posters 5.7k Views 3 Watching
      sdetweil @demetry07
      @demetry07 said in MagicMirror stopped working after screensaver installed:
      After I installed the screensaver
      what does that mean?
        demetry07
        I installed
        apt-get install xscreensaver
          sdetweil @demetry07
          @demetry07 ok… that should not have affected the mirror in any way…
            demetry07
            I agree but that was all I did.
            Installed then disabled making the screen go blank then sudo reboot.
            After reboot I get the error I posted above.
              sdetweil @demetry07
              @demetry07 weird…
              please do
              npm instal
              advise npm start results after
                demetry07
                That fixed it thank you.
                  sdetweil @demetry07
                  @demetry07 for the future, I have a script as part of install to disable screensaver on a lot of systems…
                  its also in the installers folder with 2.10
                  screensaveroff.sh
                  D 1 Reply Last reply
                    demetry07 @sdetweil
                    @sdetweil When I ran the install it asked me if I wanted to disable screensaver and I said yes but my screen was still going black over night. I would have to CTRL-Q out then it would run again automatically after a few seconds. Thought installing the screensaver and disabling it would help. Will see after tonight.
                      demetry07
                      I spoke to soon. This morning it stopped working again.
                      I ran
                      npm install
                      then
                      sudo reboot
                      then cd ~/MagicMirror
                      then
                      npm start
                      Here are the results
                      magicmirror@2.10.0 start /home/pi/MagicMirror
                      ./run-start.sh
                      [11:35:13.428] [LOG] Starting MagicMirror: v2.10.0
                      [11:35:13.448] [LOG] Loading config …
                      [11:35:13.463] [LOG] Loading module helpers …
                      [11:35:13.466] [LOG] No helper found for module: alert.
                      [11:35:13.594] [LOG] Initializing new module helper …
                      [11:35:13.596] [LOG] Module helper loaded: updatenotification
                      [11:35:13.597] [LOG] No helper found for module: clock.
                      [11:35:13.599] [LOG] No helper found for module: currentweather.
                      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorENS_14SideEffectTypeE
                      npm ERR! code ELIFECYCLE
                      npm ERR! syscall spawn
                      npm ERR! file sh
                      npm ERR! errno ENOENT
                      npm ERR! magicmirror@2.10.0 start: ./run-start.sh
                      npm ERR! spawn ENOENT
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.10.0 start script.
                      npm ERR! /home/pi/.npm/_logs/2020-01-07T17_35_13_737Z-debug.log
                      I pulled the log file here is the data in the log file.
                      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                      2 info using npm@6.13.4
                      3 info using node@v10.18.0
                      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                      5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
                      6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
                      7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
                      8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                      9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
                      10 silly lifecycle magicmirror@2.10.0~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
                      11 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
                      12 verbose stack Error: magicmirror@2.10.0 start: ./run-start.sh
                      12 verbose stack spawn ENOENT
                      12 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                      12 verbose stack at ChildProcess.emit (events.js:198:13)
                      12 verbose stack at maybeClose (internal/child_process.js:982:16)
                      12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                      13 verbose pkgid magicmirror@2.10.0
                      14 verbose cwd /home/pi/MagicMirror
                      15 verbose Linux 4.19.75-v7+
                      16 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
                      17 verbose node v10.18.0
                      18 verbose npm v6.13.4
                      19 error code ELIFECYCLE
                      20 error syscall spawn
                      21 error file sh
                      22 error errno ENOENT
                      23 error magicmirror@2.10.0 start: ./run-start.sh
                      23 error spawn ENOENT
                      24 error Failed at the magicmirror@2.10.0 start script.
                      24 error This is probably not a problem with npm. There is likely additional logging output above.
                      25 verbose exit [ 1, true ]
                      Thoughts?
                        sdetweil @demetry07
                        fun times!!
                        do
                        npm install electron-rebuild
                        node_modules/.bin/electron-rebuild
                          demetry07
                          Ran the suggested commands see below. Looks like they both ran just fine.
                          pi@raspberrypi:~/MagicMirror $ npm install electron-rebuild
                          • electron-rebuild@1.8.8
                            added 68 packages from 42 contributors and audited 3926 packages in 124.52s
                          16 packages are looking for funding
                          run npm fund for details
                          found 0 vulnerabilities
                          pi@raspberrypi:~/MagicMirror $ node_modules/.bin/electron-rebuild
                          ✔ Rebuild Complete
                          ./run-start.sh
                          [11:51:32.453] [LOG] Starting MagicMirror: v2.10.0
                          [11:51:32.478] [LOG] Loading config …
                          [11:51:32.491] [LOG] Loading module helpers …
                          [11:51:32.494] [LOG] No helper found for module: alert.
                          [11:51:32.615] [LOG] Initializing new module helper …
                          [11:51:32.617] [LOG] Module helper loaded: updatenotification
                          [11:51:32.619] [LOG] No helper found for module: clock.
                          [11:51:32.620] [LOG] No helper found for module: currentweather.
                          npm ERR! file sh
                          npm ERR!
                          npm ERR! /home/pi/.npm/_logs/2020-01-07T17_51_32_806Z-debug.log
                            sdetweil @demetry07
                            @demetry07 ok, module is a pain in the butt…
                            cd modules/MMM-PIR
                            npm install
                            ~/MagicMirror/node_modules/.bin/electron-rebuild
                              demetry07
                              Yeah I missed that in the log I see it now. Thanks for the help after updating that Module it’s starting again. Do you have a recommendation for a PIR Module that works better then something else?
                                sdetweil @demetry07
                                @demetry07 no… sorry, none of the PIR modules play nice
                                  demetry07
                                  Ok thank you again for helping.
