    MagicMirror stopped working after screensaver installed
    16 Posts 2 Posters 5.7k Views 3 Watching
      demetry07
      I agree but that was all I did.
      Installed then disabled making the screen go blank then sudo reboot.
      After reboot I get the error I posted above.
        sdetweil @demetry07
        @demetry07 weird…
        please do
        npm instal
        advise npm start results after
          demetry07
          That fixed it thank you.
            sdetweil @demetry07
            @demetry07 for the future, I have a script as part of install to disable screensaver on a lot of systems…
            its also in the installers folder with 2.10
            screensaveroff.sh
            D 1 Reply Last reply
              demetry07 @sdetweil
              @sdetweil When I ran the install it asked me if I wanted to disable screensaver and I said yes but my screen was still going black over night. I would have to CTRL-Q out then it would run again automatically after a few seconds. Thought installing the screensaver and disabling it would help. Will see after tonight.
                demetry07
                I spoke to soon. This morning it stopped working again.
                I ran
                npm install
                then
                sudo reboot
                then cd ~/MagicMirror
                then
                npm start
                Here are the results
                magicmirror@2.10.0 start /home/pi/MagicMirror
                ./run-start.sh
                [11:35:13.428] [LOG] Starting MagicMirror: v2.10.0
                [11:35:13.448] [LOG] Loading config …
                [11:35:13.463] [LOG] Loading module helpers …
                [11:35:13.466] [LOG] No helper found for module: alert.
                [11:35:13.594] [LOG] Initializing new module helper …
                [11:35:13.596] [LOG] Module helper loaded: updatenotification
                [11:35:13.597] [LOG] No helper found for module: clock.
                [11:35:13.599] [LOG] No helper found for module: currentweather.
                /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorENS_14SideEffectTypeE
                npm ERR! code ELIFECYCLE
                npm ERR! syscall spawn
                npm ERR! file sh
                npm ERR! errno ENOENT
                npm ERR! magicmirror@2.10.0 start: ./run-start.sh
                npm ERR! spawn ENOENT
                npm ERR!
                npm ERR! Failed at the magicmirror@2.10.0 start script.
                npm ERR! /home/pi/.npm/_logs/2020-01-07T17_35_13_737Z-debug.log
                I pulled the log file here is the data in the log file.
                1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                2 info using npm@6.13.4
                3 info using node@v10.18.0
                4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                5 info lifecycle magicmirror@2.10.0~prestart: magicmirror@2.10.0
                6 info lifecycle magicmirror@2.10.0~start: magicmirror@2.10.0
                7 verbose lifecycle magicmirror@2.10.0~start: unsafe-perm in lifecycle true
                8 verbose lifecycle magicmirror@2.10.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                9 verbose lifecycle magicmirror@2.10.0~start: CWD: /home/pi/MagicMirror
                10 silly lifecycle magicmirror@2.10.0~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
                11 info lifecycle magicmirror@2.10.0~start: Failed to exec start script
                12 verbose stack Error: magicmirror@2.10.0 start: ./run-start.sh
                12 verbose stack spawn ENOENT
                12 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                12 verbose stack at ChildProcess.emit (events.js:198:13)
                12 verbose stack at maybeClose (internal/child_process.js:982:16)
                12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                13 verbose pkgid magicmirror@2.10.0
                14 verbose cwd /home/pi/MagicMirror
                15 verbose Linux 4.19.75-v7+
                16 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
                17 verbose node v10.18.0
                18 verbose npm v6.13.4
                19 error code ELIFECYCLE
                20 error syscall spawn
                21 error file sh
                22 error errno ENOENT
                23 error magicmirror@2.10.0 start: ./run-start.sh
                23 error spawn ENOENT
                24 error Failed at the magicmirror@2.10.0 start script.
                24 error This is probably not a problem with npm. There is likely additional logging output above.
                25 verbose exit [ 1, true ]
                Thoughts?
                  sdetweil @demetry07
                  @demetry07 said in MagicMirror stopped working after screensaver installed:
                  fun times!!
                  do
                  npm install electron-rebuild
                  node_modules/.bin/electron-rebuild
                    demetry07
                    Ran the suggested commands see below. Looks like they both ran just fine.
                    pi@raspberrypi:~/MagicMirror $ npm install electron-rebuild
                    • electron-rebuild@1.8.8
                      added 68 packages from 42 contributors and audited 3926 packages in 124.52s
                    16 packages are looking for funding
                    run npm fund for details
                    found 0 vulnerabilities
                    pi@raspberrypi:~/MagicMirror $ node_modules/.bin/electron-rebuild
                    ✔ Rebuild Complete
                    ./run-start.sh
                    [11:51:32.453] [LOG] Starting MagicMirror: v2.10.0
                    [11:51:32.478] [LOG] Loading config …
                    [11:51:32.491] [LOG] Loading module helpers …
                    [11:51:32.494] [LOG] No helper found for module: alert.
                    [11:51:32.615] [LOG] Initializing new module helper …
                    [11:51:32.617] [LOG] Module helper loaded: updatenotification
                    [11:51:32.619] [LOG] No helper found for module: clock.
                    [11:51:32.620] [LOG] No helper found for module: currentweather.
                    npm ERR! file sh
                    npm ERR!
                    npm ERR! /home/pi/.npm/_logs/2020-01-07T17_51_32_806Z-debug.log
                      sdetweil @demetry07
                      @demetry07 ok, module is a pain in the butt…
                      cd modules/MMM-PIR
                      npm install
                      ~/MagicMirror/node_modules/.bin/electron-rebuild
                        demetry07
                        Yeah I missed that in the log I see it now. Thanks for the help after updating that Module it’s starting again. Do you have a recommendation for a PIR Module that works better then something else?
                          sdetweil @demetry07
                          @demetry07 no… sorry, none of the PIR modules play nice
                            demetry07
                            Ok thank you again for helping.
