    MMM-Screencast erro
    23 Posts 4 Posters 8.5k Views 4 Watching
    • I
      iorifly
      Dear,
          I set the module and I get this error.
      > magicmirror@2.10.0 start /home/pi/MagicMirror
      > ./run-start.sh
      [15:57:07.067] [LOG]    Starting MagicMirror: v2.10.0
      [15:57:07.101] [LOG]    Loading config ...
      [15:57:07.121] [LOG]    Loading module helpers ...
      [15:57:07.127] [LOG]    No helper found for module: alert.
      [15:57:07.412] [LOG]    Initializing new module helper ...
      [15:57:07.416] [LOG]    Module helper loaded: updatenotification
      [15:57:07.420] [LOG]    No helper found for module: clock.
      [15:57:07.821] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/xmlbuilder/lib/XMLRaw.js:1
      (function (exports, require, module, __filename, __dirname, process, global, Buffer) { return function (exports, require, module, __filename, __dirname) { =���o��P�ᔱ��/�~�4��UY��5�qs����+�D1�#?��$
      SyntaxError: Unexpected token =
          at new Script (vm.js:74:7)
          at createScript (vm.js:246:10)
          at Object.runInThisContext (vm.js:298:10)
          at Module._compile (internal/modules/cjs/loader.js:678:28)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
      [15:57:07.825] [LOG]    Loading module helpers ...
      [15:57:07.827] [LOG]    No helper found for module: alert.
      [15:57:07.830] [LOG]    Initializing new module helper ...
      [15:57:07.832] [LOG]    Module helper loaded: updatenotification
      [15:57:07.835] [LOG]    No helper found for module: clock.
      [15:57:07.863] [ERROR]  App threw an error during load
      [15:57:07.865] [ERROR]  /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/xmlbuilder/lib/XMLRaw.js:1
      [15:57:07.873] [LOG]    Whoops! There was an uncaught exception...
      [15:57:07.875] [ERROR]  /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/xmlbuilder/lib/XMLRaw.js:1
      [15:57:07.893] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [15:57:07.897] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [15:57:08.505] [LOG]    Launching application.
      [15:57:16.454] [LOG]    Shutting down server...
      [15:57:16.464] [LOG]    Stopping module helper: updatenotification
      [15:57:16.466] [LOG]    Stopping module helper: updatenotification
      part of my config
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      		        module: 'MMM-Screencast',
      		        position: 'bottom_right', // This position is for a hidden <div /> and not the screencast window
      			        position: 'bottomRight',
      			        height: 300,
      			        width: 500,
      			header: "Feriados",
      						symbol: "calendar-check",
      						url: "https://www.calendarlabs.com/ical-calendar/ics/37/Brazil_Holidays.ics"					}
      			module: "compliments",
      			position: "lower_third"
        sdetweil @iorifly
        @iorifly seems one of the module dependencies is garbled… try this
        cd ~/MagicMirror/modules/MMM-Screencast
        rm -rf node_modules
        npm install
        npm start
          sdetweil @iorifly
          @iorifly how did u update to 2.10?
          • I
            iorifly
            How did I update my MM? I installed it from scratch … Already in this version.
              sdetweil @iorifly
              @iorifly ok, installed… good (update just came out, so most have updated from 2.9)
              can u tell me the output of
              node -v
              npm -v
              • I
                iorifly
                pi@raspberrypi:~/MagicMirror $ node -v
                v10.18.0
                pi@raspberrypi:~/MagicMirror $ npm -v
                6.13.4
                • I
                  iorifly
                  That is why almost no module works for me … I’m struggling to put the Home assistant and also nothing !!
                    sdetweil @iorifly
                    rm -rf node_modules
                    npm install
                    npm start
                    • I
                      iorifly
                      @sdetweil said in MMM-Screencast erro:
                      npm install
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Screencast $ npm install
                      > electron@3.1.13 postinstall /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/electron
                      > node install.js
                      added 208 packages from 211 contributors and audited 369 packages in 55.818s
                      1 package is looking for funding
                        run `npm fund` for details
                      found 11 vulnerabilities (5 low, 2 moderate, 4 high)
                        run `npm audit fix` to fix them, or `npm audit` for details
                        sdetweil @iorifly
                        @iorifly ok, and restarting ?
                        • I
                          iorifly
                          Worked, thank you!!
                          • I
                            iorifly
                            Could you help me with the Home Assistant module?
                              sdetweil @iorifly
                              @iorifly sorry, don’t know anything about it… what is the problem?
                              • I
                                iorifly
                                > ./run-start.sh
                                [17:20:12.438] [LOG]    Starting MagicMirror: v2.10.0
                                [17:20:12.470] [LOG]    Loading config ...
                                [17:20:12.491] [LOG]    Loading module helpers ...
                                [17:20:12.495] [LOG]    No helper found for module: alert.
                                [17:20:12.748] [LOG]    Initializing new module helper ...
                                [17:20:12.751] [LOG]    Module helper loaded: updatenotification
                                [17:20:12.754] [LOG]    No helper found for module: clock.
                                [17:20:14.468] [LOG]    Initializing new module helper ...
                                [17:20:14.470] [LOG]    Module helper loaded: calendar
                                [17:20:14.472] [LOG]    No helper found for module: compliments.
                                [17:20:15.942] [LOG]    Initializing new module helper ...
                                [17:20:15.944] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                [17:20:16.102] [LOG]    Initializing new module helper ...
                                [17:20:16.104] [LOG]    Module helper loaded: newsfeed
                                [17:20:16.121] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'underscore'
                                [17:20:16.125] [LOG]    Loading module helpers ...
                                [17:20:16.128] [LOG]    No helper found for module: alert.
                                [17:20:16.131] [LOG]    Initializing new module helper ...
                                [17:20:16.133] [LOG]    Module helper loaded: updatenotification
                                [17:20:16.136] [LOG]    No helper found for module: clock.
                                [17:20:16.139] [LOG]    Initializing new module helper ...
                                [17:20:16.141] [LOG]    Module helper loaded: calendar
                                [17:20:16.143] [LOG]    No helper found for module: compliments.
                                [17:20:16.145] [LOG]    Initializing new module helper ...
                                [17:20:16.147] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                [17:20:16.150] [LOG]    Initializing new module helper ...
                                [17:20:16.152] [LOG]    Module helper loaded: newsfeed
                                [17:20:16.159] [ERROR]  App threw an error during load
                                [17:20:16.163] [ERROR]  Error: Cannot find module 'underscore'
                                    at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                    at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-HASS/node_helper.js:14:9)
                                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-HASS/node_helper.js:227:3)
                                    at Module._compile (internal/modules/cjs/loader.js:711:30)
                                [17:20:16.171] [LOG]    Whoops! There was an uncaught exception...
                                [17:20:16.174] [ERROR]  { Error: Cannot find module 'underscore'
                                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) code: 'MODULE_NOT_FOUND' }
                                [17:20:16.209] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [17:20:16.211] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                [17:20:16.925] [LOG]    Launching application.
                                [17:20:34.995] [LOG]    Shutting down server...
                                [17:20:35.006] [LOG]    Stopping module helper: updatenotification
                                [17:20:35.008] [LOG]    Stopping module helper: calendar
                                [17:20:35.010] [LOG]    Stopping module helper: MMM-DarkSkyForecast
                                [17:20:35.012] [LOG]    Stopping module helper: newsfeed
                                [17:20:35.014] [LOG]    Stopping module helper: updatenotification
                                [17:20:35.016] [LOG]    Stopping module helper: calendar
                                [17:20:35.018] [LOG]    Stopping module helper: MMM-DarkSkyForecast
                                [17:20:35.019] [LOG]    Stopping module helper: newsfeed
                                I confess I don’t know if the error is only in MM. But nothing happens in the Home assistant. That is, accuses nothing.
                                  sdetweil @iorifly
                                  @iorifly said in MMM-Screencast erro:
                                  Cannot find module ‘underscore’
                                  looks like the module author forgot to update the package.json to indicate this library was needed
                                  do this
                                  cd ~/MagicMirror/modules/MMM-HASS
                                  npm install underscore
                                  npm start
                                    I opened issue in the module github repo
                                    https://github.com/aserramonner/MMM-HASS/issues/14
                                    • I
                                      iorifly
                                      You are great!
                                      In the meantime, I tried another module, MMM-homeassistant-sensors.
                                      It carries the MM. However I get this error msg. and no other module loads … gets msg from “loading”
                                      > ./run-start.sh
                                      [19:50:41.053] [LOG] Starting MagicMirror: v2.10.0
                                      [19:50:41.091] [LOG] Loading config ...
                                      [19:50:41.111] [LOG] Loading module helpers ...
                                      [19:50:41.119] [LOG] No helper found for module: alert.
                                      [19:50:41.315] [LOG] Initializing new module helper ...
                                      [19:50:41.319] [LOG] Module helper loaded: updatenotification
                                      [19:50:41.321] [LOG] No helper found for module: clock.
                                      [19:50:42.483] [LOG] Initializing new module helper ...
                                      [19:50:42.485] [LOG] Module helper loaded: MMM-Screencast
                                      [19:50:43.894] [LOG] Initializing new module helper ...
                                      [19:50:43.896] [LOG] Module helper loaded: calendar
                                      [19:50:43.898] [LOG] No helper found for module: compliments.
                                      [19:50:45.187] [LOG] Initializing new module helper ...
                                      [19:50:45.190] [LOG] Module helper loaded: MMM-DarkSkyForecast
                                      [19:50:45.320] [LOG] Initializing new module helper ...
                                      [19:50:45.322] [LOG] Module helper loaded: newsfeed
                                      [19:50:45.330] [LOG] Initializing new module helper ...
                                      [19:50:45.332] [LOG] Module helper loaded: MMM-homeassistant-sensors
                                      [19:50:45.333] [LOG] All module helpers loaded.
                                      [19:50:45.342] [LOG] Starting server on port 8080 ...
                                      [19:50:45.441] [LOG] Server started ...
                                      [19:50:45.444] [LOG] Connecting socket for: updatenotification
                                      [19:50:45.448] [LOG] Connecting socket for: MMM-Screencast
                                      [19:50:45.452] [LOG] Connecting socket for: calendar
                                      [19:50:45.454] [LOG] Starting node helper for: calendar
                                      [19:50:45.457] [LOG] Connecting socket for: MMM-DarkSkyForecast
                                      [19:50:45.459] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                                      [19:50:45.462] [LOG] Connecting socket for: newsfeed
                                      [19:50:45.465] [LOG] Starting module: newsfeed
                                      [19:50:45.528] [LOG] Connecting socket for: MMM-homeassistant-sensors
                                      [19:50:45.533] [LOG] Sockets connected & modules started ...
                                      [19:50:45.538] [LOG]
                                      Ready to go! Please point your browser to: http://localhost:8080
                                      Starting chromium browser now, have patience, it takes a minute
                                       --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
                                      events.js:174
                                            throw er; // Unhandled 'error' event
                                      Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                          at doWrite (_stream_writable.js:411:19)
                                          at writeOrBuffer (_stream_writable.js:399:5)
                                          at Socket.Writable.write (_stream_writable.js:299:11)
                                          at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
                                          at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10)
                                          at process.emit (events.js:198:13)
                                          at process._fatalException (internal/bootstrap/node.js:497:27)
                                      ^C
                                        jorgnyg
                                        I’m getting the same “Unhandled ‘error’”-error. However, I’m not using this module at all.
                                          sdetweil @jorgnyg
                                          @jorgnyg well then it’s a problem in another module
                                            sdetweil @iorifly
                                            @iorifly can u do this
                                            which chromium-browser
                                            it should return something, not an empty line
                                              I installed this module and am running split mode… I don’t see any errors, but I don’t have an HA system talk to…
                                              I get the header on the page, that says the module started
