Solved MMM-Screencast erro
@iorifly seems one of the module dependencies is garbled… try this
cd ~/MagicMirror/modules/MMM-Screencast rm -rf node_modules npm install cd ~/MagicMirror npm start
@sdetweil said in MMM-Screencast erro:
npm install
pi@raspberrypi:~/MagicMirror/modules/MMM-Screencast $ npm install > electron@3.1.13 postinstall /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/electron > node install.js added 208 packages from 211 contributors and audited 369 packages in 55.818s 1 package is looking for funding run `npm fund` for details found 11 vulnerabilities (5 low, 2 moderate, 4 high) run `npm audit fix` to fix them, or `npm audit` for details pi@raspberrypi:~/MagicMirror/modules/MMM-Screencast $
@iorifly ok, and restarting ?
Worked, thank you!!
Could you help me with the Home Assistant module?
@iorifly sorry, don’t know anything about it… what is the problem?
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.10.0 start /home/pi/MagicMirror > ./run-start.sh [17:20:12.438] [LOG] Starting MagicMirror: v2.10.0 [17:20:12.470] [LOG] Loading config ... [17:20:12.491] [LOG] Loading module helpers ... [17:20:12.495] [LOG] No helper found for module: alert. [17:20:12.748] [LOG] Initializing new module helper ... [17:20:12.751] [LOG] Module helper loaded: updatenotification [17:20:12.754] [LOG] No helper found for module: clock. [17:20:14.468] [LOG] Initializing new module helper ... [17:20:14.470] [LOG] Module helper loaded: calendar [17:20:14.472] [LOG] No helper found for module: compliments. [17:20:15.942] [LOG] Initializing new module helper ... [17:20:15.944] [LOG] Module helper loaded: MMM-DarkSkyForecast [17:20:16.102] [LOG] Initializing new module helper ... [17:20:16.104] [LOG] Module helper loaded: newsfeed [17:20:16.121] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'underscore' [17:20:16.125] [LOG] Loading module helpers ... [17:20:16.128] [LOG] No helper found for module: alert. [17:20:16.131] [LOG] Initializing new module helper ... [17:20:16.133] [LOG] Module helper loaded: updatenotification [17:20:16.136] [LOG] No helper found for module: clock. [17:20:16.139] [LOG] Initializing new module helper ... [17:20:16.141] [LOG] Module helper loaded: calendar [17:20:16.143] [LOG] No helper found for module: compliments. [17:20:16.145] [LOG] Initializing new module helper ... [17:20:16.147] [LOG] Module helper loaded: MMM-DarkSkyForecast [17:20:16.150] [LOG] Initializing new module helper ... [17:20:16.152] [LOG] Module helper loaded: newsfeed [17:20:16.159] [ERROR] App threw an error during load [17:20:16.163] [ERROR] Error: Cannot find module 'underscore' at Module._resolveFilename (internal/modules/cjs/loader.js:602:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at Function.Module._load (internal/modules/cjs/loader.js:528:25) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-HASS/node_helper.js:14:9) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-HASS/node_helper.js:227:3) at Module._compile (internal/modules/cjs/loader.js:711:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) [17:20:16.171] [LOG] Whoops! There was an uncaught exception... [17:20:16.174] [ERROR] { Error: Cannot find module 'underscore' at Module._resolveFilename (internal/modules/cjs/loader.js:602:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at Function.Module._load (internal/modules/cjs/loader.js:528:25) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-HASS/node_helper.js:14:9) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-HASS/node_helper.js:227:3) at Module._compile (internal/modules/cjs/loader.js:711:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) code: 'MODULE_NOT_FOUND' } [17:20:16.209] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [17:20:16.211] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [17:20:16.925] [LOG] Launching application. [17:20:34.995] [LOG] Shutting down server... [17:20:35.006] [LOG] Stopping module helper: updatenotification [17:20:35.008] [LOG] Stopping module helper: calendar [17:20:35.010] [LOG] Stopping module helper: MMM-DarkSkyForecast [17:20:35.012] [LOG] Stopping module helper: newsfeed [17:20:35.014] [LOG] Stopping module helper: updatenotification [17:20:35.016] [LOG] Stopping module helper: calendar [17:20:35.018] [LOG] Stopping module helper: MMM-DarkSkyForecast [17:20:35.019] [LOG] Stopping module helper: newsfeed pi@raspberrypi:~/MagicMirror $
I confess I don’t know if the error is only in MM. But nothing happens in the Home assistant. That is, accuses nothing.
@iorifly said in MMM-Screencast erro:
Cannot find module ‘underscore’
looks like the module author forgot to update the package.json to indicate this library was needed
do thiscd ~/MagicMirror/modules/MMM-HASS npm install underscore cd ~/MagicMirror npm start
I opened issue in the module github repo
https://github.com/aserramonner/MMM-HASS/issues/14 -
You are great!
In the meantime, I tried another module, MMM-homeassistant-sensors.
It carries the MM. However I get this error msg. and no other module loads … gets msg from “loading”
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.10.0 start /home/pi/MagicMirror > ./run-start.sh [19:50:41.053] [LOG] Starting MagicMirror: v2.10.0 [19:50:41.091] [LOG] Loading config ... [19:50:41.111] [LOG] Loading module helpers ... [19:50:41.119] [LOG] No helper found for module: alert. [19:50:41.315] [LOG] Initializing new module helper ... [19:50:41.319] [LOG] Module helper loaded: updatenotification [19:50:41.321] [LOG] No helper found for module: clock. [19:50:42.483] [LOG] Initializing new module helper ... [19:50:42.485] [LOG] Module helper loaded: MMM-Screencast [19:50:43.894] [LOG] Initializing new module helper ... [19:50:43.896] [LOG] Module helper loaded: calendar [19:50:43.898] [LOG] No helper found for module: compliments. [19:50:45.187] [LOG] Initializing new module helper ... [19:50:45.190] [LOG] Module helper loaded: MMM-DarkSkyForecast [19:50:45.320] [LOG] Initializing new module helper ... [19:50:45.322] [LOG] Module helper loaded: newsfeed [19:50:45.330] [LOG] Initializing new module helper ... [19:50:45.332] [LOG] Module helper loaded: MMM-homeassistant-sensors [19:50:45.333] [LOG] All module helpers loaded. [19:50:45.342] [LOG] Starting server on port 8080 ... [19:50:45.441] [LOG] Server started ... [19:50:45.444] [LOG] Connecting socket for: updatenotification [19:50:45.448] [LOG] Connecting socket for: MMM-Screencast [19:50:45.452] [LOG] Connecting socket for: calendar [19:50:45.454] [LOG] Starting node helper for: calendar [19:50:45.457] [LOG] Connecting socket for: MMM-DarkSkyForecast [19:50:45.459] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast] [19:50:45.462] [LOG] Connecting socket for: newsfeed [19:50:45.465] [LOG] Starting module: newsfeed [19:50:45.528] [LOG] Connecting socket for: MMM-homeassistant-sensors [19:50:45.533] [LOG] Sockets connected & modules started ... [19:50:45.538] [LOG] Ready to go! Please point your browser to: http://localhost:8080 Starting chromium browser now, have patience, it takes a minute --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version= events.js:174 throw er; // Unhandled 'error' event ^ Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed at doWrite (_stream_writable.js:411:19) at writeOrBuffer (_stream_writable.js:399:5) at Socket.Writable.write (_stream_writable.js:299:11) at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46) at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10) at process.emit (events.js:198:13) at process._fatalException (internal/bootstrap/node.js:497:27) ^C pi@raspberrypi:~/MagicMirror $
