Solved MMM-Screencast erro
Dear,
I set the module and I get this error.
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.10.0 start /home/pi/MagicMirror > ./run-start.sh [15:57:07.067] [LOG] Starting MagicMirror: v2.10.0 [15:57:07.101] [LOG] Loading config ... [15:57:07.121] [LOG] Loading module helpers ... [15:57:07.127] [LOG] No helper found for module: alert. [15:57:07.412] [LOG] Initializing new module helper ... [15:57:07.416] [LOG] Module helper loaded: updatenotification [15:57:07.420] [LOG] No helper found for module: clock. [15:57:07.821] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/xmlbuilder/lib/XMLRaw.js:1 (function (exports, require, module, __filename, __dirname, process, global, Buffer) { return function (exports, require, module, __filename, __dirname) { =���o��P�ᔱ��/�~�4��UY��5�qs����+�D1�#?��$ ^ SyntaxError: Unexpected token = at new Script (vm.js:74:7) at createScript (vm.js:246:10) at Object.runInThisContext (vm.js:298:10) at Module._compile (internal/modules/cjs/loader.js:678:28) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) at Module.load (internal/modules/cjs/loader.js:620:32) at tryModuleLoad (internal/modules/cjs/loader.js:559:12) at Function.Module._load (internal/modules/cjs/loader.js:551:3) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) [15:57:07.825] [LOG] Loading module helpers ... [15:57:07.827] [LOG] No helper found for module: alert. [15:57:07.830] [LOG] Initializing new module helper ... [15:57:07.832] [LOG] Module helper loaded: updatenotification [15:57:07.835] [LOG] No helper found for module: clock. [15:57:07.863] [ERROR] App threw an error during load [15:57:07.865] [ERROR] /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/xmlbuilder/lib/XMLRaw.js:1 (function (exports, require, module, __filename, __dirname, process, global, Buffer) { return function (exports, require, module, __filename, __dirname) { =���o��P�ᔱ��/�~�4��UY��5�qs����+�D1�#?��$ ^ SyntaxError: Unexpected token = at new Script (vm.js:74:7) at createScript (vm.js:246:10) at Object.runInThisContext (vm.js:298:10) at Module._compile (internal/modules/cjs/loader.js:678:28) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) at Module.load (internal/modules/cjs/loader.js:620:32) at tryModuleLoad (internal/modules/cjs/loader.js:559:12) at Function.Module._load (internal/modules/cjs/loader.js:551:3) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) [15:57:07.873] [LOG] Whoops! There was an uncaught exception... [15:57:07.875] [ERROR] /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/xmlbuilder/lib/XMLRaw.js:1 (function (exports, require, module, __filename, __dirname, process, global, Buffer) { return function (exports, require, module, __filename, __dirname) { =���o��P�ᔱ��/�~�4��UY��5�qs����+�D1�#?��$ ^ SyntaxError: Unexpected token = at new Script (vm.js:74:7) at createScript (vm.js:246:10) at Object.runInThisContext (vm.js:298:10) at Module._compile (internal/modules/cjs/loader.js:678:28) at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) at Module.load (internal/modules/cjs/loader.js:620:32) at tryModuleLoad (internal/modules/cjs/loader.js:559:12) at Function.Module._load (internal/modules/cjs/loader.js:551:3) at Module.require (internal/modules/cjs/loader.js:658:17) at require (internal/modules/cjs/helpers.js:20:18) [15:57:07.893] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [15:57:07.897] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [15:57:08.505] [LOG] Launching application. [15:57:16.454] [LOG] Shutting down server... [15:57:16.464] [LOG] Stopping module helper: updatenotification [15:57:16.466] [LOG] Stopping module helper: updatenotification
part of my config
modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: 'MMM-Screencast', position: 'bottom_right', // This position is for a hidden <div /> and not the screencast window config: { position: 'bottomRight', height: 300, width: 500, } }, { module: "calendar", header: "Feriados", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "https://www.calendarlabs.com/ical-calendar/ics/37/Brazil_Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, {
@iorifly seems one of the module dependencies is garbled… try this
cd ~/MagicMirror/modules/MMM-Screencast rm -rf node_modules npm install cd ~/MagicMirror npm start
@iorifly how did u update to 2.10?
How did I update my MM? I installed it from scratch … Already in this version.
@iorifly ok, installed… good (update just came out, so most have updated from 2.9)
can u tell me the output of
node -v
npm -v -
pi@raspberrypi:~/MagicMirror $ node -v v10.18.0 pi@raspberrypi:~/MagicMirror $ npm -v 6.13.4 pi@raspberrypi:~/MagicMirror $
That is why almost no module works for me … I’m struggling to put the Home assistant and also nothing !!
@sdetweil said in MMM-Screencast erro:
npm install
pi@raspberrypi:~/MagicMirror/modules/MMM-Screencast $ npm install > electron@3.1.13 postinstall /home/pi/MagicMirror/modules/MMM-Screencast/node_modules/electron > node install.js added 208 packages from 211 contributors and audited 369 packages in 55.818s 1 package is looking for funding run `npm fund` for details found 11 vulnerabilities (5 low, 2 moderate, 4 high) run `npm audit fix` to fix them, or `npm audit` for details pi@raspberrypi:~/MagicMirror/modules/MMM-Screencast $
@iorifly ok, and restarting ?
Worked, thank you!!
