    Cannot hide SSID and Password in MMM-WiFiPassword
    15 Posts 3 Posters 4.5k Views 3 Watching
    • T Offline
      tino
      Hi @ all !
      I tried the module . Actually works quite well. Unfortunately I don’t get the SSID and password hidden. Here is my code, maybe someone has an idea. ;)
          module: 'MMM-WiFiPassword',
          position: "bottom_right",
              //See 'Configuration options' for more information.
              showNetwork: true,
              network: "WLAN-59xxx",
              password: "4471435172xxxxx",
              showNetwork: false,
              showPassword: false
        sdetweil @tino
        @tino exactly like this, cut/paste from config
                network: "xxxxx",
                password: "xxxxxxxxxx",
        	showPassword: false
        T 2 Replies Last reply Reply Quote 0
          sdetweil @tino
          @tino please for all posts of config info or code, please use the code block wrapper
          thats the button above </>, select the text u paste and then hit the button
            Alloc
            Dont you need a , after showPassword: false?
              sdetweil @Alloc
              @Alloc no, its the last one, so comma is not required
                sdetweil @tino
                @tino did it show the network? u have it twice
                  Alloc @sdetweil
                  @sdetweil Ahh okay, i was just looking at the github, so there its wrong.
                  https://github.com/TeraTech/MMM-WiFiPassword
                  How to use this module
                  As with other MM modules, add this array to the config/config.js file
                  modules:[
                          network: "my_network",
                          password: "my_pass",
                    sdetweil @Alloc
                      sdetweil @Alloc
                      @Alloc doesn’t hurt to add it (so u don’t forget when u add something else onto the end,
                      but is not ‘required’ on the last entry
                      • T Offline
                        tino
                        yes sorry, i have already tried a little. That’s why it’s there twice. But no matter what I do. With “,” without “,” false, true or whatever it changes nothing.
                          sdetweil @tino
                          @tino I just installed the module, and used the config as shown on the module readme page
                          and added showPassword: false
                          and it worked as expected. shows the network name, but not the password
                          this module, right? https://github.com/TeraTech/MMM-WiFiPassword
                          and if I comment out the showPassword: false
                          the password is displayed
