    Remote Control doesn't work for me, Please help!
    7 Posts 4 Posters 1.8k Views 4 Watching
    • T Offline
      ttarzan
      @justlearning I think it’s just missing a comma in the first line. Try
      modules: ‘MMM Remote Control’,
        Alloc
        Please use the </> when posting code
            module: 'MMM-Remote-Control'
            // , position: 'bottom_left'
                customCommand: {},  // Optional, See "Using Custom Commands" below
                customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                apiKey: "",         // Optional, See API/README.md for details
        My guess is that your problem is within point 3.
        (3) For security reasons, the MagicMirror (and therefore the Remote Control) is not reachable externally. To change this, configure address, and ipWhitelist in your config.js (see these lines in the sample config). For
        example change address to 0.0.0.0 and add two allowed devices with IP-Adresses 192.168.0.42 and 192.168.0.50:
        address : ‘0.0.0.0’,
        port: 8080,
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.0.42”, “::ffff:192.168.0.50”],"
        You can also add multiple devices in an IP range (e.g. all devices with 192.168.0.X):
        ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/120", "192.168.0.1/24"],
          justlearning @Alloc
          @Alloc Thanks for the advice, I have now gotten to the point , its showing that the : HTTP://ip-of-your-mirror:8080/remote.html this is what I see. Here is all my code now:
          Thanks to anyone that can solve my stupidity!
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	//address: "localhost", // Address to listen on, can be:
          	address: "0.0.0.0",
          	port: 8080,
          	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
          	ipWhitelist: [], // Set [] to allow all IP addresses
          	language: "en",
          	timeFormat: 12,
          	units: "metric",
          			     // false, default for all  NON-armv6l devices
          			module: "alert",
          			module: "updatenotification",
          			position: "bottom_bar"
          			module: "clock",
          			position: "top_left"
          			header: "Canadian Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/canada_Holidays.ics"					}
                  disabled: false,
                  module: 'MMM-Lunartic',
                  position: 'top_right', // Best in left, center, or right regions
                      mode: "rotating", // rotating or static
                      image: "animation", // animation, current, DayNight or static
                      distance: "km", // miles or km
          	    sounds: "no", // howling wolf, only on a full moon
                      useHeader: false, // true if you want a header
                      header: "The Lunartic is in my head", // Any text you want
                      maxWidth: "300px",
                      animationSpeed: 0,
                      rotateInterval: 15000,
            module: "MMM-GooglePhotos",
            position: "center",
              albumId: ["XXXXXXXXXXXXXXXXXXX"], // your album id(s) from result of `auth_and_test.js`
              refreshInterval: 1000*60,
              scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
              //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
              sort: "time", //'time', 'reverse', 'random'
              showWidth: "800px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
              showHeight: "600px",
              originalWidthPx: 800, // original size of loaded image. (related with image quality)
              originalHeightPx: 600, // Bigger size gives you better quality, but can give you network burden.
              opacity: 1, // target "opacity" property (https://www.w3schools.com/cssref/css3_pr_opacity.asp)
              mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
              //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          					position: "bottom_right",
          				locationID: "6173331",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "XXXXXXXXXXXXXX"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				appid: "XXXXXXXXXXXXX"
                      apiKey: ''
              module: 'MMM-Remote-Control',
               //uncomment the following line to show the URL of the remote control on the mirror
               position: 'bottom_left',
            module: "MMM-NowPlayingOnSpotify",
            position: "bottom_left",
              clientID: "XXXXXXXXXXXXXXXXXXXXX",
              clientSecret: "XXXXXXXXXXXXXXX",
              accessToken: "XXXXXXXXXXXXXXXXX",
              refreshToken: "XXXXXXXXXXXXX"
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "Canada News",
          						url: "https://www.ctvnews.ca/rss/ctvnews-ca-canada-public-rss-1.822284"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
          A lavolp3L 2 Replies Last reply Reply Quote 0
            Alloc @justlearning
            @justlearning I would edit that out, because it shows all your API secrets.
            Fx. Spotify
            • lavolp3L Offline
              lavolp3 Module Developer @Alloc
              @Alloc @justlearning I have removed some sensitive information
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • lavolp3L Offline
                lavolp3 Module Developer @justlearning
                @justlearning said in Remote Control doesn't work for me, Please help!:
                its showing that the : HTTP://ip-of-your-mirror:8080/remote.html this is what I see.Here is all my code now:
                What is the remaining problem? What happens if you visit the site in your browser?
