    organization of the text next to the icon.
    48 Posts 3 Posters 26.8k Views 5 Watching
    • I Offline
      iorifly
      As I said. If I position the module on the left side. Everything is perfectly aligned.
      If I place the module on the right side, the text is far from the icons.
      Taking advantage of that will look at the code. It is possible, for example, when he displays “off” or “on” he writes in my language …
      I don’t think so, as it pulls that information from the Home Assistant server.
      • I Offline
        iorifly
        I did not find any css files in this addom.
        It would be possible to add lines to separate some functions, or I’m saying stupidity.
          sdetweil @iorifly
          @iorifly
          yes, he creates an html table (table)
          and each row is a table row (tr)
          you would have to move this
          		// Name
          		newCell = newrow.insertCell(1);
          		newText = document.createTextNode(name);
          		newCell.appendChild(newText);
          		// Value
          		newCell = newrow.insertCell(2);
          		newCell.className = "align-right"
          			newText = document.createTextNode(value);
          		// Unit
          		newCell = newrow.insertCell(3);
          		newCell.className = "align-left"
          			newText = document.createTextNode(unit);
          in front of this
          		// icons
          		newCell = newrow.insertCell(0);
          and change the insertCell(?) numbers back to 0-3 in order again
          change 1 to 0,
          2 to 1,
          3 to 2
          and 0 to 3
          as for left/right areas of screen… yes, it is quite a challenge to have the text properly aligned, regardless of the area of the screen (position) selected… there is NO ‘simple’ fix
          • I Offline
            iorifly
            I will try to play with this. But already mine gave a north !!!
               I will try to create the lines. About aligning if standing next to the icons already helps. Now creating html is simpler. I will try to understand. Anything I report.
              doubleT Module Developer
              Wait! I think that’s not what @iorifly wants, right?
              If I understand this correct (and it is difficult to understand ;) ) the text in the middle should be aligned left?
              • I Offline
                iorifly
                I will send another photo. with the module positioned to the left of the screen.
                  sdetweil @doubleT
                  @doubleT yes, you are correct… sorry, I misunderstood , I thought he wanted the icons on the right end of the line
                  • I Offline
                    iorifly
                    I actually want it that way. See how the text is perfectly aligned to the icon.
                    https://imgur.com/InsQd3x
                    • I Offline
                      iorifly
                      I also wanted to put lines
                      Like the ones I set as an example. I actually want white line like the one under “Home assistant”
                      https://imgur.com/sx9Muq2
                        Ok, I understand. I’m looking at the code and I think it’s not written very good. There are cells named “align-left” and “align-right” – stupid in this case as there’s no CSS for it and the cells are taking their alignment from the module position, it seems.
                        Are you familiar with the dev mode? Can you check the html structure of the table and see if the cells and table rows that you try to change have any class names?
                        I’m trying to figure this out and then I’d suggest some entries in the custom.css file.
                          text alignment, you will have to change the code. the author did not provide element classes you could modify with css. (see the code from one of my prior posts, he just set style to ‘align-left’ or ‘align-right’ or let it default (text nodes align right by default for ltr languages)
                          adding a line under some entries,
                          you will have to modify the code to add that capability
                            It can be done in css even if there are no class names. Give me a minute.
                            • I Offline
                              iorifly
                              Thanks! I’m in no hurry. Even because it took me a long time to get here. sdetweil helped me extremely.
                              Thank you very much for all your support! sensational you !!!.
                                If you want to work in the code and are not afraid that an update might overwrite it, you could try to change
                                		// Name
                                to
                                		// Name
                                		newCell.className = "align-left";
                                That seems to be what’s aligning the icon cell to the left. That css comes from MM’s main.css.
                                • I Offline
                                  iorifly
                                  I will try to locate this code.
                                  in which module file do I look for it?
                                    MMM-homeassistant-sensors.js
                                    • I Offline
                                      iorifly
                                      @doubleT said in organization of the text next to the icon.:
                                      newCell.className = “align-left”;
                                      alignment resolved. Can I now create lines to separate groups? Or is it impossible?
                                        Ok, please keep in mind that this is not the best solution (working directly in the code).
                                        If you want to make the changes via custom.css file, try this:
                                        (Now, since the module is called “MMM-homeassistant-sensors” I’m going to assume the element is identifiable with _“.module.MMM-homeassistant-sensors” …)
                                        Tell each 2nd cell to align its content left:
                                        .module.MMM-homeassistant-sensors table tr td:nth-of-type(2) {
                                            text-align: left;
                                        Tell the cells of the 3rd and 6th line to have a bottom border line:
                                        .module.MMM-homeassistant-sensors table tr:nth-of-type(3) td,
                                        .module.MMM-homeassistant-sensors table tr:nth-of-type(6) td {
                                            border-bottom: 1px solid white;
                                        If the line is separated, try:
                                        .module.MMM-homeassistant-sensors table {
                                            border-spacing: 0;
                                        EDIT: There was an error, it’s text-align, of course. Not test-align.
                                        • I Offline
                                          iorifly
                                          Let me see if I got it. I need to change the custom.css file. Where is it located?
                                          in the css folder. I only have the main.css file
                                            Create a file named “custom.css” and put the code from above inside it.
