    SimpleLogo auto change logo not working
    21 Posts 3 Posters 8.2k Views 3 Watching
      RoadRunnr1469
      Module.register("MMM-SimpleLogo", {
          // Default module config.
          defaults: {
              text: "",
              fileUrl: "modules/MMM-SimpleLogo/public/Amc.JPG",
              width: "200px",
      	notification: "SIMPLE_LOGO_UPDATE",
              position: "top_center",
              refreshInterval: 1000
          start: function() {
              if (this.config.refreshInterval > 0) {
                  var self = this;
                  var imgsrc = self.config.fileUrl;
                  this.interval = setInterval(function() {
                      img = document.querySelector(".simple-logo__container img[src*='" + imgsrc + "']");
                      if(!imgsrc.includes("?"))
                              imgsrc += '?' + Date.now();
                      else
                              imgsrc += '&' + Date.now();
                      img.setAttribute('src', imgsrc);
                  }, this.config.refreshInterval);
          getStyles: function () {
              return [
                  this.file('css/mmm-simplelogo.css')
          notificationReceived: function(notification, payload) {
              if (notification == "SIMPLE_LOGO_UPDATE") {
                  // stop auto-refresh (if any)
                      clearInterval(this.interval);
                  // update with new parameters
                  for (var attr in payload) this.config[attr] = payload[attr];
                  // restart auto-refresh (if any)
                  this.start();
                  this.updateDom();
          // Override dom generator.
          getDom: function() {
              wrapper.className = 'simple-logo__container';
              wrapper.classList.add(this.config.position);
              wrapper.style.width = this.config.width;
              var text = document.createTextNode(this.config.text);
              wrapper.appendChild(text);
              var img = document.createElement("img");
              img.setAttribute('src', this.config.fileUrl);
              wrapper.appendChild(img);
              return wrapper;
        sdetweil @RoadRunnr1469
        @RoadRunnr1469 u don’t edit the SimpleLogo.js file (in general u NEVER edit the module files unless u are making code fixes or enhancements)
        you edit the config.js
        default is NEVER update
        in config.js
           module: "MMM-SimpleLogo",
           position: ????,
              refreshInterval:  5* 60 * 1000   // 5 minutes, times  60 seconds times 1000 milliseconds per second
              fileUrl: "???????"
        everything in the config: { … }
        overrides the moduleName.js defaults: { …} items of the same names
        R 1 Reply Last reply
        • F
          FlameShotBow
          As @sdetweil stated you shouldn’t be editing the modules JavaScript file.
          To ensure that the SimpleLogo module has not been damaged I would reinstall the module and the OnScreenMenu module if you edited the JavaScript of that too.
          Once you have a fresh install of SimpleLogo and OnScreenMenu you need to edit the config file in magic mirror and not any of the module files.
          I’m not sure what you mean about the “auto chance” aspect. If you want the logos to automatically change then I would suggest sending a notification to SimpleLogo using ModuleScheduler. On the other hand, if you want to manually change them. You can use the OnScreenMenu module like so:
              module: "MMM-OnScreenMenu",
              position: "top_centre",
                  menuItems: {
                      notify1: {
                          title: "AMC Logo",
                          payload: {
                              width: "750px"
                      notify2: {
                          title: "Show other logo",
                          payload: {
                              fileUrl: "modules/MMM-SimpleLogo/public/......",
                              width: "1050px"
          which should hopefully give you the option to change the logo manually.
          Hope this helps.
          Pretty experienced with programming - Pretty not experienced with magic mirrors
            RoadRunnr1469
            I don’t understand why people have to be so confrontational and un helpful. Making changes the the DEFAULT portion of the main file ONLY affects the initial settings.
            As far as what I mean by auto changing logo, that is what I understood by the documentation for the module.
            Dynamic to me means it will change at a given amount of time…
            ****** Copy/Paste from MMM-SimpleLogo*****
            The MMM-SimpleLogo module supports the notification event SIMPLE_LOGO_UPDATE which allows the configuration to be dynamically modified. As an example, the MMM-OnScreenMenu module might be used to dynamic adjust the fileURL parameter as follows
              RoadRunnr1469 @sdetweil
              @sdetweil changing the simplelogo.js back and putting updates in config.js has not made any changes. the logo still stays on the same logo, never changes.
                @RoadRunnr1469 ok, looking thru the code and doc
                Refresh/refetch image file between interval. Only use this if your image url return different image after some interval of time, even the fileUrl is not changed.
                the code adds a time to the end of the fileurl to force a unique value. You could do this if the URl to the file stayed the same, but the actual file was different (something overwrote the file since last time)
                so, they planned on the something changing the actual logo file contents
                            this.interval = setInterval(function() {   // < --- start a recurring timer
                                        imgsrc += '?' + Date.now();  // < ---
                                else
                                        imgsrc += '&' + Date.now();  // < -----
                            }, this.config.refreshInterval);  // < ---  refresh time
                the code also allows some other module to send it a message to change the logo url
                we are not being ‘un helpful’, the design of the mirror app is to INTENTIONALLY keep people from having to change the module file for different options…
                so, when we see someone going down that path, we want to get them back on the design
                I can look at the module code from github, I can’t see what you did locally. (in general)
                makes it harder to help, and changes made get wiped out if there is a module update…
                (that tends to make people upset when their stuff is lost!)
                but your and my initial understanding of what was supposed to happen (as I didn’t know anything about this module), is wrong… update the cycle time but keep the same exact image and nothing will change.
                you can prove this with 2 logo files.
                start with one, and then copy the other over the 1st while the module is working.
                we are all volunteers here…
                  RoadRunnr1469
                  The ReadMe file shows this
                  cat README.md
                  Module: MMM-SimpleLogo
                  The MMM-SimpleLogo module is third party modules of the MagicMirror. This module simply displays logo.
                  Using the module
                          module: 'MMM-SimpleLogo',
                          position: 'top_left',    // This can be any of the regions.
                  Configuration options
                  The following properties can be configured:
                  Option Description
                  fileUrl File url.
                  Possible values: Logo link form internet or path to your local files relative to MagicMirror directory
                  Default value: 'modules/MMM-SimpleLogo/public/logo.png'
                  width Set width of your logo, height is auto.
                  Possible values: '300px' or '50%'
                  Default value: '200px'
                  position Horizontal position on current container
                  Possible values: left, center, or right
                  Default value: left
                  refreshInterval Refresh/refetch image file between interval. Only use this if your image url return different image after some interval of time, even the fileUrl is not changed. See this case #2, awesome project by @ElYoM
                  Possible values: 1000, 2000, or 10000
                  Default value: 0 (disabled)
                  text Text above the image.
                  Possible values: Any text
                  Default value: Simple Logo
                  Notification Events
                  The MMM-SimpleLogo module supports the notification event SIMPLE_LOGO_UPDATE which allows the configuration to be dynamically modified. As an example, the MMM-OnScreenMenu module might be used to dynamic adjust the fileURL parameter as follows:
                          menuItems: {
                              notify1: {
                                  title: "Show Cat",
                                  payload: {
                                      fileUrl: "cat.jpg",
                                      width: "750px"
                              notify2: {
                                  title: "Show Dog",
                                  payload: {
                                      fileUrl: "dog.jpg",
                                      width: "1050px"
                    @RoadRunnr1469 right. Some external module sends a message.
                    I didn’t look at that code
                    R 3 Replies Last reply
                      Based on the section “Notification Events” I added a section as called out.
                      this isn’t letting me paste it in here, says it is spam.
                        I added this to the config.js file
                                            position: "bottom_right",
                                                    menuItems: {
                                                    notify1: {
                                                            title: "Patch",
                                                            payload: {
        width: "200px"
                                                          notify2: {
        title: "Support",
        payload: {
        fileUrl: "modules/MMM-SimpleLogo/public/RedSupport.jpg",
        width: "150px"
                            @RoadRunnr1469 I won’t be able to look at this til tomorrow or Sunday.
                            Open the developers window ctrl-shift-i select the console tab and scroll up to see any messages sent from the on screen module
                              @RoadRunnr1469 I installed the module, and modified one of mine to send the notification, and it worked as expected.
                                @RoadRunnr1469 and you installed the “MMM-OnScreenMenu” module too, right?
                                  @sdetweil yes, and the on screen option works fine changes the logo as expected.
                                    @RoadRunnr1469 cool… can u mark this as resolved now?
                                      RoadRunnr1469
                                      no, the SimpleLogo auto changer part still is not working.
                                        @RoadRunnr1469 ok, YOU have to actually update the fileUrl file with new contents.
                                        it loads the SAME fileUrl over and over and over and over
                                        it adds a fake timestamp to the URL to force the browser cache to see a different file
                                        which loads a new instance into the cache…
                                        so somehow you have to do
                                        cp  whatever_source_path/new_logo_to_display.jpg  ~/MagcMirror/modules/MMM-SimpleLogo/public/Amc.JPG
                                        I have tested this and it works
                                        also I think
                                        the content of the new logo image TYPE must match the file extension… it is expecting jpg
                                        so cannot change to gif/png for next ones to load
