    MMM-BackgroundSlideshow Update
    3 Posts 2 Posters 1.6k Views 2 Watching
    • T Offline
      Thierry17
      I installed the MMM-BackgroundSlideshow module from the command line
      git clone https://github.com/darickc/MMM-BackgroundSlideshow.git
      Everything worked very well.
      A few days ago a message appeared for the update of this module with 3 late commits on the master branch.
      I then made on command line
      git pull https://github.com/darickc/MMM-BackgroundSlideshow.git
      The update was not done with the following message:
      *branch HEAD -> FETCH_HEAD
      Fatal: refusal to merge unrelated histories
      I deleted the MMM-BackgroundSlideshow folder and redo the installation on the command line.
      This morning the update message came back.
      Did I make a manipulation error or is there a command to do to merge the histories.
      thank you in advance
        sdetweil @Thierry17
        @Thierry17 said in MMM-BackgroundSlideshow Update:
        do
        cd ~/MagicMirror/modules/MMM-BackgroundSlideshow
        git pull
        • T Offline
          Thierry17
          Thank you very much,
          now I have Update dc2 …
          1 file changed, 1 insert (+), 1 deletion (-).
          I think the update went well.
          To see tomorrow if I no longer have the update message.
          Cordially
