    MagicMirror won't start after update
    5 Posts 2 Posters 1.4k Views 2 Watching
    • H Offline
      harrycool25
      After the recent update (yes, I used the reccommeded command from the FAQ :) ), MagicMirror just won’t start. When attempting to start it using pm2 (previously worked normally), it says it’s started, but no windows show up whatsoever. Then, when I try to run
      npm start
      inside the /MagicMirror folder, this error pops up:
      > magicmirror@2.10.1 start /home/pi/MagicMirror
      > ./run-start.sh
      App threw an error during load
      /home/pi/MagicMirror/node_modules/ws/lib/websocket.js:347
            ...options
      SyntaxError: Unexpected token ...
          at createScript (vm.js:74:10)
          at Object.runInThisContext (vm.js:116:10)
          at Module._compile (module.js:533:28)
          at Object.Module._extensions..js (module.js:580:10)
          at Module.load (module.js:503:32)
          at tryModuleLoad (module.js:466:12)
          at Function.Module._load (module.js:458:3)
          at Module.require (module.js:513:17)
          at require (internal/module.js:11:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/ws/index.js:3:19)
      A JavaScript error occurred in the main process
      Uncaught Exception:
            ...options
      Can anyone assist me in diagnosing this mess? I am very new to Linux so I have zero idea what’s going on here.
      Thank you all so much, and have a nice day.
        sdetweil @harrycool25
        @harrycool25 how did u update?
          @harrycool25 said in MagicMirror won't start after update:
          i suspect you did
          git pull
          but did NOT do the
          npm install
          required for this update
          • H Offline
            harrycool25 @sdetweil
            I’ve also run
            npm install
            inside the MagicMirror folder when updating. No idea what happened next. Is there anyway I could, I don’t know, revert changes?
              @harrycool25 ok, let’s see if we can fix it
              Do
              rm -rf node_modules
              npm install
              Then
              npm start
