    Rpi 4 and two monitors
    60 Posts 6 Posters 42.9k Views 6 Watching
      sdetweil @NathTheDude
      @NathTheDude sorry. I left out the pm2 steps
      From mm2 folder do
      pm2 start installers/pm2???.json
      pm2 save
      Where the json file is the one u modified.
      It should start the second mirror app.
      The only difference is that window-positio info. And on reboot
      pm2 status should show both.
      Can u show the two chromium browser lines?
      I will attempt to recreate here
      • N
        NathTheDude
        Hey @sdetweil , after looking at how the current MM is setup with pm2 (pm2 show MagicMirror) this had the ‘mm.sh’ as the target.
        Within the MM2 folder I ran: ‘pm2 start ./installers/mm.sh --name MagicMirror2’ which started the MM2 but on the first screen. Then used pm2 save.
        I just setup pm2 with the .json file instead of the mm.sh file and the results seem to be the same from what i can see with it getting displayed on the first screen.
        Within the start-run.sh, I can comment out the chromium line and and it will not break anything which makes me think this line is not being referenced.
        MM line:
        chromium-browser --noerrdialogs --kiosk --user-data-dir='Default' --window-position=0,0 --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
        MM2 line:
        chromium-browser --noerrdialogs --kiosk  --disable-infobars --app=http://localhost:8082 --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --window-postion=1920,0 --user-data-dir='Test2' 2>/dev/null
          @NathTheDude if u start the json file, pm2 reads the info, gives u a nice name etc.
          pm2 delete 0 or 1
          pm2 save
          Then pm2 start the json file.
          And pm2 save
          To save for reboot
            @NathTheDude
            I was able to recreate the problem, and good news its just a typo
            should be
            --window-position=1920,0
            missing i in position
            • N
              NathTheDude
              Thank you for this although it is still producing 2 x MM’s on the first screen (MM and MM2), not sure what could be wrong. If you have it working it obviously must me something I have done wrong…hmmmmm.
              I will review all the files and let you know if I find anything.
              • N
                NathTheDude
                @sdetweil . I know it is a bit extreme but thought I would just start again and burn another image to the SD card. I am in the same position though
                • burnt image to sd card, booted rpi and did an update, enabled SSH and VNC
                • installed MM with your automation script
                • copied the ‘MagicMirror’ Folder to ‘MagicMirror2’, in the new folder I updated:
                  – config.js - just updated port to 8082
                  – run-start.sh - updated with window position and profile
                  – mm.sh - new location
                  – pm2_MagicMirror.json - updated with new locations
                • within the MagicMirror2 folder,
                  – pm2 start ./installers/pm2_MagicMirror.json
                  – pm2 save
                • This then started another MM from the MM2 folder on to screen 1
                • htop confirms that processes are running from both MagicMirror and MagicMirror2
                • pm2 status confirms that both are up
                In your setup, if you update the chromium line within run-start.sh with bad entries does that break your setup. Does not seem to be running this command from what I can see in my setup
                  well, I finally got it to work , note I have two displays that support 4k, 3840x2160, so my screen pos is double yours
                  in /boot/config.txt
                  [pi4]
                  # Enable DRM VC4 V3D driver on top of the dispmanx display stack
                  dtoverlay=vc4-fkms-v3d
                  max_framebuffers=4
                  and in /boot/cmdline.txt
                  add cma=384M to the end of the line, like this…
                  plymouth.ignore-serial-consoles cma=384M
                  then you must power down and back up for these changes to be applied
                  found here
                  https://retropie.org.uk/forum/topic/24436/drm_ioctl_mode_create_dumb-failed-cannot-allocate-memory/9
                  I was getting the DRM cannot allocate memory error
                  MagicMirror/run-start.sh line for chromium
                  chromium-browser -noerrdialogs -kiosk --user-data-dir='Default' --window-position=0,0 -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
                  MagicMirror2/run-start.sh line for chromium
                  chromium-browser --disable-bundled-ppapi-flash -noerrdialogs -kiosk -start_maximized  --window-position="3840,0" --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors  --user-data-dir='Test2'  # 2>/dev/null
                  this boots up and both MM start via pm2 and display on separate screens, with different content (modules in different positions)
                  here is a screenshot of my dev system connected to both MM servers at the same time
                  (the displays are two hdmi ports on the same TV, so I can’t show them physically at the same time)
                  alt text
                  • N
                    NathTheDude
                    @sdetweil - nice 2 x 4k’s.
                    So, I did what you mentioned in your last post but unfortunetly I am in the same issue. I wonder if your problem was more to do with 2 x 4k’s which is perhaps different to mine? I am not sure.
                    • N
                      NathTheDude
                      @sdetweil - if you comment out the chromium line in the run-start.sh does this cause you any issues/errors?
                        @NathTheDude no… you could just change config.js to serverOnly:true, then it won’t try to start chrome
                          @NathTheDude I started by doing
                          cd MagicMirror
                          node serveronly
                          note no npm start needed, will run til you ctrl-break out
                          then tried multiple tries to get chrome on the second display…
                          (it works manually if the position is mispelled!)
                          then once it worked reliably,
                          i killed the server instance
                          then I used pm2 to stop/start that instance til I got that to work.
                          note that I had to use
                          –disable-bundled-ppapi-flash
                          on the second instance as it collided with the 1st…
                          • K
                            krocaq @sdetweil
                            @saljoke
                            Hi. Thats right. i only use 1 Pi4 to serve both displays via 2 MM instances. first the originally MagicMirror directory and the second in a MagicMirror2 directory. Both powered up via PM2 and turned off and on via PIR sensor.
                            The config looks like this:
                            language: “de”,
                            logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”],
                            timeFormat: 24,
                            units: “metric”,
                            electronOptions: {fullscreen:true, x:1920},
                            1920 is the resolution witdh of the main display.
                            Very easy to handle and good for the electrical consumption
                              sdetweil @krocaq
                              @krocaq see my comment here , you can do it with ONE directory
                              https://forum.magicmirror.builders/topic/17239/two-display/2?_=1663555322286
                              • 3 / 3
