    MMM-Touch
    36 Posts 7 Posters 25.5k Views 10 Watching
      A Former User
      MMM-Touch
      MagicMirror module for universal touch gesture commander using touchscreen
      Screenshot
      Features
      • Multi-fingers supported. (If your touchpanel or touchframe would support.)
      • Available gestures : TAP, PRESS, SWIPE_UP/DOWN/LEFT/RIGHT, MOVE_UP/DOWN/LEFT/RIGHT, ROTATE_CW/CCW, PINCH_IN/OUT.
        • Example : TAP_1(tapping with 1 finger), SWIPE_LEFT_2(swiping left with 2 fingers), PINCH_IN_3(pinching-in with 3 fingers)
        • For ROTATE_CW and ROTATE_CCW, only 2 fingers are recognizable. (sorry, I’m not good at math.)
      • Available commands :
        • Emitting custom notification
        • Executing shell script/command directly
        • Executing method of module(s)
        • Usual JavaScript codes
      • Different gestures and commands with mode by condition.
      • Dynamic configuration : Other module easily add gestureCommand for itself by notification
      [card:eouia/MMM-Touch]
      U 1 Reply Last reply Reply Quote 2
        dvbit
        Aha interesting Sean
        Will be trying it with https://github.com/dvbit/Kinect-Mouse-Swipe-C-Module
          dvbit
          I need to upgrade the c code to at least catch two hands :-)
            A Former User @dvbit
            @dvbit intersting trial. this module can capture only one touch point also. I think u might need to emit “touch” events instead of “mouse” events.( but common onclick and onrelease event will be compatible)
              dvbit @Guest
              @Sean Uhm .If I understand your touch plugin intercepts “tap” events in the OS.
              If that is the case I have to find a way to simulate those in my C program.
              Currently the program uses the X11 simulation functions to emit fake clicks and movement events
              Is this the case?
              It is really a pity that all kinect libraries of projects such as openni are really old as it is hard to find documentation. harder updated documentation.
              Ideally the kinect would have a “Tuio” driver for X server so mecoming for all intent and purposes a multi touch device.
              I have tried to revive that too before this was developed.
              I will give it a new try.
              https://code.google.com/archive/p/tuiokinect/
                @dvbit
                i used default touch events of browser.(IE and Safari doesn’t support but we are commonly use electron-chromium)
                https://developer.mozilla.org/en-US/docs/Web/API/Touch_events
                I don’t know anything about kinnect library, so i don’t know whether your code can emit specific event. anyway if possible, it can be used together.
                  dvbit @Guest
                  @Sean Ok. I think that then if it intercepts browser touch events it will be really possible.
                  Right now I am trying to compile tuiokinect :-)
                  That would add full multitouch air gestures… so would be really fantastic with your plugin ;-)
                  • U Offline
                    undeterred @Guest
                    @Sean Hi, I’d like to get this module working with a HyperPixel4 touchscreen. Unfortunately I obtain an error when changing modes that stops the module from working. Is this the correct place to post to obtain help?
                    Also, I have a degree in applied maths. Perhaps I can help with the rotation maths?
                    Many thanks.
                      A Former User @undeterred
                      @undeterred
                      What kind of error did you meet? Post a issue on github repository with more detailed information. I’ll inspect.
                      MrCoffeeM 1 Reply Last reply Reply Quote 0
                      • MrCoffeeM Offline
                        MrCoffee @Guest
                        @Sean Thank you for sharing this great module.
                        I am not very good at programming, but playing around a little helped me understand.
                        However I am wondering if it is possible to create more buttons?
                        Is there a way to modify the code (if necessary just quick and dirty) or do you think I can run multiple instances at the same time?
                        And one more question: is it possible to change the displayed name to an icon?
                        Thanks a lot.
                        Mr.Coffee
                        • MrCoffeeM Offline
                          MrCoffee @MrCoffee
                          I have just seen that Sean is not on duty anymore.
                          Anyway it seems like now I got it how the module works.
                          Great stuff. Thanks for sharing.
                          But I still got two questions.
                          1. If I enter some code in the section “onNotification” and restart the mirror, nothing happens. The monitor stays black. Not even an error in the config is mentioned. I tried the example code and even code written on my own. Both the same.
                            Do you have any idea what the reason might be? is it a bug or my fault?
                          2. I unterstood that I just define the mode and it is not important where to touch on the display as long it is my defined gesture.
                            What I would love to do, is have a floorplan on my mirror with my smart home connected. For example I would have 5 icons of bulbs, which should be turned on by pressing the icon.
                            Is it possible to modify the module in such a way? If I am right, it is not possible right now, because a gesture like pressing can only be used once.
                          Thanks a lot.
                            sdetweil @MrCoffee
                            @MrCoffee Yes, Sean stepped away from MM for personal reasons a few months back. No one has taken over active support for this module. (he had like 70 modules)
                            • MrCoffeeM Offline
                              MrCoffee @sdetweil
                              Maybe someone else uses the module with its “onNotification” option and might help out.
                                sdetweil @MrCoffee
                                @MrCoffee I don’t see a module of this name with his name
                                I see https://github.com/gfischershaw/MMM-Touch
                                and what is the question about onNotification?
                                when a notification is received, you can examine and optionally respond (somehow)
                                • MrCoffeeM Offline
                                  MrCoffee @sdetweil
                                  @sdetweil Yes that is the same module. Sean changed the ownership when he left: Seans modules
                                  The onNotification function seems important to me. if I change to page two for example, the gestures can be defined in another way compared to page one.
                                  My problem is, when I add the code and restart my mirror everthing stays black. usually if there is a bug in the config.js an error is mentioned. but in this case it just stays black.
                                  If I uncomment the code everthing is fine again.
                                  This even happens when i use the example code. Knowing that it wont do anything on my magic mirror, it should start anyway.
                                  So i am wondering if there is a bug or if i am doing something wrong?
                                  Do you use the module?
                                    sdetweil @MrCoffee
                                    @MrCoffee no… never seen it before…
                                    how do you start MM
                                    npm start
                                    or pm2?
                                    if npm start , keyboard alt-spacebar, n to minimize
                                    if pm2,
                                    pm2 logs --lines=100
                                    if still nothing obvious, open the developers window, ctrl-shoft-i on the mirror keyboard,
                                    select the tab labeled console and scroll up… errors are usually in red text
                                    • MrCoffeeM Offline
                                      MrCoffee @sdetweil
                                      @sdetweil Thanks I didn´t know these commands. Unfortunately I use it installed by docker and headlless on a other device.
                                        sdetweil @MrCoffee
                                        @MrCoffee yeh, skip docker til you get it working…
                                        • MrCoffeeM Offline
                                          MrCoffee @sdetweil
                                          @sdetweil I just tried ctrl-shift-i with a working mirror. On the tab console I could see a css error, but everything works.
                                          Then i added the onNotification code. Still the same. no mirror starting, and on the console tab there is no error. it ends with “initializing MagicMirror”.
                                          But nothing happens.
                                            sdetweil @MrCoffee
                                            @MrCoffee ok, then it must be back on the terminal window where i started MM
                                            either there is a module missing
                                            a syntax error
                                            or some fatal problem in the front end (mmm-touch.js)
