    Unable to install dependencies
    14 Posts 2 Posters 4.3k Views 2 Watching
    • N Offline
      nathan.joslin @sdetweil
      install starting  - Thu Feb 13 15:20:04 EST 2020
      installing on armv7l processor system
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      Updating packages ...
      Get:1 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB] Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] Reading package lists... E: Release file for http://archive.raspberrypi.org/debian/dists/buster/InRelease is not valid yet (invalid for another 7d 17h 12min 50s). Updates for this repository will not be applied. E: Release file for http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease is not valid yet (invalid for another 10d 2h 34min 25s). Updates for this repository will not be applied.
      apt-get update  completed ok
      apt upgrade result =rc=0 Reading package lists...
      Building dependency tree...
      Reading state information...
      Calculating upgrade...
      Installing helper tools ...
      Minimum Node version: v10.1.0
      Installed Node version: v10.15.2
      No Node.js upgrade necessary.
      Minimum npm version: V6.0.0
      Installed npm version: V5.8.0
      npm should be upgraded.
      Installing npm ...
      npm is already the newest version (5.8.0+ds6-4).
      upgrading npm to latest
      npm installation Done! version=V5.8.0
      Cloning MagicMirror ...
      Cloning MagicMirror Done!
      Installing dependencies ...
      Unable to install dependencies!
        sdetweil @nathan.joslin
        @nathan-joslin wow…
        If you do npm install in the MagicMirror folder. What other output do u get?
        • N Offline
          pi@raspberrypi:~ $ mmpm -M
          MagicMirror directory not found. Installing MagicMirror...
          $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
          $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
          $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
          $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
          $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
          $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
          \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                  \______/
          install log being saved to /home/pi/install.log
          Reading package lists... Done
          build-essential is already the newest version (12.6).
          curl is already the newest version (7.64.0-4).
          git is already the newest version (1:2.20.1-2+deb10u1).
          unzip is already the newest version (6.0-23+deb10u1).
          wget is already the newest version (1.20.1-1.1).
          Installing npm ...
          npm WARN npm npm does not support Node.js v10.15.2
          npm WARN npm You should probably upgrade to a newer version of node as we
          npm WARN npm can't make any promises that npm will work with this version.
          npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
          npm WARN npm You can find the latest version at https://nodejs.org/
          npm ERR! code CERT_NOT_YET_VALID
          npm ERR! errno CERT_NOT_YET_VALID
          npm ERR! request to https://registry.npmjs.org/npm failed, reason: certificate is not yet valid
          npm ERR!     /root/.npm/_logs/2020-02-13T20_21_42_189Z-debug.log
          Cloning into 'MagicMirror'...
          remote: Enumerating objects: 331, done.
          remote: Counting objects: 100% (331/331), done.
          remote: Compressing objects: 100% (295/295), done.
          remote: Total 331 (delta 42), reused 194 (delta 23), pack-reused 0
          Receiving objects: 100% (331/331), 676.44 KiB | 105.00 KiB/s, done.
          Resolving deltas: 100% (42/42), done.
          npm ERR! request to https://registry.npmjs.org/feedme failed, reason: certificate is not yet valid
          npm ERR!     /home/pi/.npm/_logs/2020-02-13T20_22_17_662Z-debug.log
          pi@raspberrypi:~ $
          Not sure if this helps either, I just deleted the MagicMirror folder before trying again.
          • N Offline
            pi@raspberrypi:~/MagicMirror $ npm install
            npm ERR! request to https://registry.npmjs.org/iconv-lite failed, reason: certificate is not yet valid
            npm ERR!     /home/pi/.npm/_logs/2020-02-13T20_26_05_452Z-debug.log
            Sorry I didn’t see your response, here is npm install
              @nathan-joslin that CERT NOT VALID is a real problem…
              Will have to research
              • N Offline
                @sdetweil Why did your installation script not work? Tonight I may have time to delete the MagicMirror folder and use your script and show you what that says.
                  @nathan-joslin one suggestion for the cert error is to insure your system time is set correctly.
                  My script is the same as before, and fails if npm install fails
                  My script shows the same error, see line 5 of the log. Looks like the system date is in the past
                  N 2 Replies Last reply Reply Quote 0
                  • N Offline
                    Okay I’ll look into it tonight, just have some things to take care of first. I thought it may have been related to the time, but when I tried to change the time it wasn’t letting me. I even rebooted multiple times. But I’ll try to get back to you tonight
                    • N Offline
                      I was finally able to install it correctly using your script. For some reason using
                      raspi-config
                      was not changing the date and time so I had to do it manually. Thank you so much for your help! I didn’t think the date and time being off by 9 days would have been an issue. I hope my friends and I will be able to accomplish want we want to do with this, but that may have to be a surprise for later. Thanks once again.
                        @nathan-joslin np. We all learned something. Now to detect it, and help others
                          @nathan-joslin i have added code to the installer to check for and report the date/time problem…
                          thanks for your help!
