    Trouble accessing Raspbian desktop after fresh install
    5 Posts 2 Posters 1.1k Views 2 Watching
      byte_me
      Hi all,
      I recently did a fresh install / setup for my mirror (with the latest version of MagicMirror) and almost everything is working perfectly. Before the install, I used to be able to access the top menu bar by pressing ALT, and then minimizing or closing the window to take me back to the Raspbian desktop. Now, when I minimize or close the window it takes me to a black screen with no UI and the only thing I can do is right click to get a few menu options like open terminal, setup, and exit openbox. If I exit, the screen remains black but no longer displays any options on right click. I have tried every key on the keyboard and absolutely nothing happens. The same occurs if I run:
      pm2 stop mm
      I’m not sure what is going on here, but I have no way to access my Raspbian desktop unless I disable the MagicMirror autostart - which will allow me to access the Desktop on boot.
      I haven’t been able to find any relevant documentation, other than an old thread which describes the way I used to access the desktop before installing the newest version.
      https://forum.magicmirror.builders/topic/1801/get-back-to-desktop
      I appreciate any help and suggestions!
        sdetweil @byte_me
        @byte_me how did u install?
        Do this
        pm2 delete mm
        Then run the pm2setup script from here
          byte_me @sdetweil
          @sdetweil said in Trouble accessing Raspbian desktop after fresh install:
          Do this
          pm2 delete mm
          I installed MagicMirror manually using this guide:
          https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
          I used this guide for the setup:
          https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
          And this to install pm2 and autostart:
          https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
          I will try deleting mm this afternoon and reinstalling pm2, thanks for the suggestion
            sdetweil @byte_me
            @byte_me and I might suggest using the automated install script on that same page.
            Delete or rename the MagicMirror folder before running the install script.
              byte_me
              Do this
              pm2 delete mm
              Thanks! This suggestion worked and I can now exit to Raspbian!
