Solved no /etc/kbd/config Folder/File
ok now there was no error for use the command
@Miked180 and screen saver should now be off on your system
the log will say what it did
~/screensaver.log
This is in the log:
xscreensaver running
xscreensaver already disabled
disable screensaver via gsettings was true and uint32 300
install screensaver via lightdm.conf
disable screensaver via lxsession
gsettings screen saver already disabled
screensaver via lightdm already disabled
lxsession screen saver already disabled
lxsession screen saver already disabled -
@Miked180 yeh, it adds to the log each time its run
lxsession screen saver already disabledas it has become more difficult to figure out which setting is actually in control
(some newer OS’s have gsettings capability, but different versions do or do not use it)…
so I report them all… -
no i have a black screen after ca 2 mins and cant wake up with mouse or keyboard
ok thanks
have you any idea ?
@Miked180 see my prior updated reply
i have delete MMM-Motion Detector from the config.js and since this i have no black screen, i will test for longer timer
I wait for tomorrow for my new cas with fan cooler . I have 70 ° Temp now , this is to much , maybe this is the problem too
Thansk now for the big help, in the next days i know more .
@Miked180 ok, the black screen means that the UI portion of MM has died… usually due to some coding error or unexpected error…
