    MMM-usonic Problems
    24 Posts 2 Posters 6.0k Views 2 Watching
      sgarg15
      Hey guys,
      So i am trying to get my ultrasonic sensors to work and i found this module and i was wondering if anyone has had luck trying to get this module to work
      https://github.com/mochman/mmm-usonic @mochman
      Because after following the steps i run the MagicMirror and bunch of errors show up. So if you got this too work please let me know
        sdetweil @sgarg15
        @sgarg15 what errors show up?
          sgarg15 @sdetweil
          so rn i did the install in the /home/pi/node_modules and i put this in my MMM-Swipe node_helper.js file. (var usonic = require('mmm-usonic'); )
          So then when i run the MagicMirror using npm start these errors show up
          home/pi/MagicMirror/node_modules/electron/dist/electron: symbol lookup error: /home/pi/node_modules/mmm-usonic/build/Release/usonic.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorENS_14SideEffectTypeE
          npm ERR! code ELIFECYCLE
          npm ERR! syscall spawn
          npm ERR! file sh
          npm ERR! errno ENOENT
          npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
          npm ERR! spawn ENOENT
          npm ERR!
          npm ERR! Failed at the magicmirror@2.10.1 start script.
          npm ERR!     /root/.npm/_logs/2020-03-28T03_18_41_984Z-debug.log
            sdetweil @sgarg15
            @sgarg15 said in MMM-usonic Problems:
            what install?
            MMM_Swipe (https://github.com/mochman/MMM-Swipe)
            already lists that dependency in package.json
              "dependencies": {
                "math-statistics": "latest",
                "mmm-usonic": "latest",
                "mmm-gpio": "latest"
            and lists that file in node_helper.js
            const usonic = require('mmm-usonic');
            the install instructions say
            1. Navigate into your MagicMirror's modules folder and execute git clone https://github.com/mochman/MMM-Swipe.git. A new folder labeled MMM-Swipe will appear, cd into it.
            2 Execute npm install to install the dependencies
            if u are adding a library to a module, then in the module folder
            /home/pi/MagicMirror/modules/module_name   (MMM-Swipe in this case)
            you would do
            npm install --save mmm-usonic
            if all of that is ok, then sometimes a module ships a library that is built on a specific level of electron,
            and our is different…
            so do
            npm install electron-rebuild
            node_modules/.bin/electron-rebuild
            to rebuild the used libraries to match the installed electron version
              sgarg15 @sdetweil
              So i tried redownloading the module andi get this error when i npm install
              > electron-rebuild -e ../../node_modules/electron-prebuilt
              An unhandled error occurred inside electron-rebuild
              Unable to find electron's version number, either install it or specify an explicit version
              Error: Unable to find electron's version number, either install it or specify an explicit version
                  at /home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/src/cli.js:86:19
                  at Generator.next (<anonymous>)
                  at fulfilled (/home/pi/MagicMirror/modules/MMM-Swipe/node_modules/electron-rebuild/lib/src/cli.js:6:58)
              npm ERR! errno 255
              npm ERR! MMM-Swipe@1.1.1 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
              npm ERR! Exit status 255
              npm ERR!
              npm ERR! Failed at the MMM-Swipe@1.1.1 postinstall script.
              it says it cant find the electron version number, but idk how to fix it
                sgarg15
                Any ideas?
                  sdetweil @sgarg15
                  @sgarg15 maybe can look tomorrow, not home now
                    @sdetweil that module (mmm-usonic) is not for magic mirror, but a library for a potential module to use to talk to the hardware…
                    sadly has same labeling and same verbiage (module)
                    he wrote MMM-Swipe, which uses his library (mmm-usonic)
                      @sgarg15 to fix the electron rebuild problem,
                      the package.json file in MMM-Swipe and change
                      this
                          "postinstall": "node_modules/.bin/electron-rebuild -e ../../node_modules/electron-prebuilt"
                      to this
                          "postinstall": "node_modules/.bin/electron-rebuild"
                        sgarg15 @sdetweil
                        @sdetweil So the install worked properly but then when i ran sudo npm start it gave this error
                        [1580:0329/130746.224199:FATAL:electron_main_delegate.cc(211)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
                        Any idea what that means?
