    MMM-Iobroker "undefined"
    7 Posts 6 Posters 3.9k Views 6 Watching
    • F
      fischi87
      Hello guys,
      i installed the MMM-Iobroker module but it is just for mqtt devices possible to display them because i get in my mirror the message “undefined” when i write in the config other devices for example hm-rpc.
      thanks
      C 1 Reply Last reply
        Chris87-ux @fischi87
        @fischi87 said in MMM-Iobroker "undefined":
        Hello guys,
        thanks
        i have the same issue now, i would like to dislay modbus values.
        Unfortunately it seems to not work.
        Does anyone have a solution for this?
          Jensen
          Hi all,
          same on my side, always “undefined”
          Any idea?
          BR Jens
            Burn78
            Please install in ioBroker the Adapter “Simple RESTful API”
            config.js from the mirror look like this.
                                    module: 'MMM-ioBroker',
                                    position: 'bottom_right',
                                            host: 'IP from ioBroker',
                                            port: '8087',
                                            https: false,
                                            devices: [
                                                    { name: "Badezimmer",
                                                            deviceStates: [
        { id: 'zigbee.0.001.temperature', icon: 'wi wi-thermometer', suffix: '°' },
        { id: 'zigbee.0.001.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
              Jensen
              the solution was to modify MMM-ioBroker.js
                getTemplate: function () {
                  return 'MMM-ioBroker.njk';
                roessi
                @Jensen
                hi, thx this helped me.
                But now I only see this, do you know why it cannot get data?
                I tried with
                "http://192.168.0.102:8087/get/hm-rpc.0.OEQ0348511.1.HUMIDITY"
                at Safari and the response ist the fuel data string
                {"val":52,"ack":true,"ts":1585485874168,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1585560601523,"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":99,"unit":"%","role":"value.humidity","name":"TempFeuchtHof.HUMIDITY"},"native":{"AutoconfRoles":"WEATHER","DEFAULT":0,"FLAGS":1,"ID":"HUMIDITY","MAX":99,"MIN":0,"OPERATIONS":5,"TAB_ORDER":1,"TYPE":"INTEGER","UNIT":"%"},"_id":"hm-rpc.0.OEQ0348511.1.HUMIDITY","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                • kusselinK
                  kusselin
                  Hi, i have updated to the actually MM. other things in the config i haven´t changed.
                  I have install the simple restful API Adapter in iobroker and before the latest uodate all is going.
                  Now nothing is going…
                  Whre is the mistake?
