    trouble with MMM-remote-control
    14 Posts 2 Posters 4.3k Views 2 Watching
      sdetweil @thehoopjr
      @thehoopjr start from the top…
      var config = {
      a module
      another module
      ];   end of modules list
      }   end of var config
      T 1 Reply Last reply
      • T
        thehoopjr @sdetweil
        @sdetweil All of that matches what I have in my config file. The check is only giving me errors in the remote module. it starts at line 90 and finishes at line 99.
        module: "MMM-Remote-Control",
        , position: "bottom_bar",
        customCommand: {},  // Optional, See "Using Custom Commands" below
        customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
        showModuleApiMenu: true, // Optional, Enable the Module Controls menu
        apiKey: "",         // Optional, See API/README.md for details
        pi@jakemagicmirror:~/MagicMirror $ npm run config:check
        > magicmirror@2.10.1 config:check /home/pi/MagicMirror
        > node tests/configs/check_config.js
        Checking file...  /home/pi/MagicMirror/config/config.js
        Line 91 col 37 Extra comma. (it breaks older versions of IE)
        Line 92 col 9 Expected '}' to match '{' from line 90 and instead saw ','.
        Line 92 col 11 Expected ']' to match '[' from line 33 and instead saw 'position'.
        Line 92 col 19 Expected '}' to match '{' from line 11 and instead saw ':'.
        Line 92 col 20 Missing semicolon.
        Line 93 col 9 Expected an assignment or function call and instead saw an expression.
        Line 93 col 15 Missing semicolon.
        Line 93 col 9 Unrecoverable syntax error. (87% scanned).
        do you think you could point out any errors in there?
        thanks
          sdetweil @thehoopjr
          @thehoopjr said in trouble with MMM-remote-control:
          two commas in a row
          i hate his doc to uncomment that position line, with the leading comma
              module: 'MMM-Remote-Control'   // < --- notice this DOES NOT have the comma
              // , position: 'bottom_left'   //< ---------- there
          • T
            thehoopjr @sdetweil
            @sdetweil so I should remove that leading comma and it should fix it?
              sdetweil @thehoopjr
              @thehoopjr leading or prior line trailing…
              just have 1… then try it…
              • T
                thehoopjr @sdetweil
                @sdetweil that worked! thank you. the mirror started but all of my modules say they’re loading and the webpage won’t load. they’ve been stuck on loading for 10 minutes.
                any ideas?
                  sdetweil @thehoopjr
                  @thehoopjr open the developers window, ctrl-shift-i, select the console tab, scroll up to find any errors (usually red text
                  • T
                    thehoopjr @sdetweil
                    @sdetweil no red text and no errors as far as I know. Anything else?
                      sdetweil @thehoopjr
                      @thehoopjr how are u startung MM?? use the terminal window
                      npm start dev
                      ctrl-c to close it
                      messages presented in terminal window too
                      • T
                        thehoopjr @sdetweil
                        @sdetweil It worked! i’m up and running. thank you
                          sdetweil @thehoopjr
                          @thehoopjr cool. What was the problem?
