    Update MMM
    75 Posts 8 Posters 52.8k Views 9 Watching
      sdetweil @mattx38
      @mattx38 no issue… the ‘default’ instructions don’t consider all the other things that will break.
      even my upgrade script does not handle these problems… as they are so module specific…
      my french is a LOT worse than your english!..
        mattx38
        Ok I understand.
        I saw a message on the Remote Control module github and it seams there is also a problem with it after the MMM update.
        My MagicMirror was running as a charm till this update. I saw the alert on the MM screen so I did it… what a shame
          mattx38
          It is still running, but nothing changed into the terminal.
          After the command “npm install --save-dev electron-rebuild” I had this message :
          • electron-rebuild@1.10.1
            updated 2 packages and audited 822 packages in 16.302s
          3 packages are looking for funding
          run npm fund for details
          found 9 low severity vulnerabilities
          run npm audit fix to fix them, or npm audit for details
          Should I run “npm fund” and “npm audit fix” before launching the second command ?
            sdetweil @mattx38
            @mattx38 no, those won’t help anything
              sdetweil @mattx38
              @mattx38 did u disable pir-sensor?
              are there still problems (dev window, terminal window?)
                mattx38
                Yes I disabled it.
                Can I run a new Putty window while the rebuild of Assistant is running, to check ?
                  sdetweil @mattx38
                  @mattx38 sure
                    mattx38
                    [2020-04-01 23:02:44.155] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary modu le because it was not installed for the current system
                    Expected directory: electron-v6.1-linux-arm-glibc
                    Found: [electron-v3.1-linux-arm-glibc, node-v64-linux-arm-glibc]
                    This problem can often be fixed by running “npm rebuild” on the current system
                    Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk 2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc _node.node’
                    Require stack:
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_exten sion.js
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_int erceptors.js
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/index.js
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/co mponents/assistant.js
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/in dex.js
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js
                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                    • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai n.js
                      sdetweil @mattx38
                      @mattx38 i’m sorry, now out of my depth of solutions… you’ll have to get @Sean (MMM-AssistantMk2 author) involved…
                        mattx38
                        Ok, thanks for your help so far.
                        The rebuilding is not done yet ; still running.
                          mattx38
                          Rebuild is done for the Assistant. The MM is launnching again. I didn’t try to activate it by saying “Jarvis” (everyone is sleeping at home).
                          I put PIR module ON, black screen again, and still this error :
                          [2020-04-01 23:30:25.054] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
                          was compiled against a different Node.js version using
                          NODE_MODULE_VERSION 64. This version of Node.js requires
                          NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                          the module (for instance, using npm rebuild or npm install).
                          EDIT : So I did a “npm install” into the MMM-PIR-Sensor folder, and now it works again.
                          A very big THANK YOU to YOU !!!
                            sdetweil @mattx38
                            @mattx38 cool. My update script would have fixed PIR problem. But not assistant or hotword
                              Peter Leemon
                              HI all I’m getting the following message on my MM screen “MagicMirror2 update available” then underneath “The current installation is 2994 comments behind on the master branch”
                              Anyone know how to resolve this issue?
                                sdetweil @Peter Leemon
                                @Peter-Leemon run my update script from here
                                  Peter Leemon @sdetweil
                                  @sdetweil run the first script?
                                    @Peter-Leemon
                                    upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
                                    it should handle all the work… and give you a trial run of all that…
                                    only applying changes if u request them
                                    give it a try this works on Mac as well
                                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                    no changes are made to the local repo or the working copy
                                    if you WANT to actually apply the changes do
                                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                    there is a log file (upgrade.log) in the MagicMirror/installers folder…
                                      @sdetweil said in Update MMM:
                                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                      sorry a noob here do i run this in terminal?
                                        @Peter-Leemon yes, stop MM first of course
                                          Peter Leemon
                                          when I paste bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh) i get no such file or directory
                                            @Peter-Leemon dang forum, change the " to wrong character… copy/paste it again
                                            need the trailing quote too
                                            • 2 / 4
