child_process won't execute
13 Posts 3 Posters 2.4k Views 3 Watching
  • T Offline
    Temisola1
    I’m trying to execute a python script using the child_process. However my function doesn’t seem to be triggering.
    const spawn = require("child_process").spawn
    var NodeHelper = require("node_helper")
    const process = spawn("python3", ["return_something.py"])
      start: function() {
        this.countDown = 10000000
          switch(notification){
              case "DO_YOUR_JOB":
                console.log(payload)
                this.sendSocketNotification("I_DID", (this.countDown - payload))
                break
              case "RETRIEVE_DATA":
                this.job()
                break
      job: function(){
        console.log("I'm trying to retrieve data")
        process.stdout.on('data', (data)=>{
          //********everything works up till here
            console.log("inside")
          var result = String.fromCharCode.apply(null, new Uint16Array((data)))
          this.sendSocketNotification("DATA_RETRIEVED", result)
    Python script.
    import sys
    print("Hello, I'm Amira")
    sys.stdout.flush()
      how about like this
        start: function() {
                case "DO_YOUR_JOB":
                  break
                  this.job()
                  break
        job: function(){
         var process = spawn("python3", ["return_something.py"])
      T 1 Reply Last reply Apr 2, 2020, 4:46 AM Reply Quote 0
      • T Offline
        Temisola1 @sdetweil
        @sdetweil thanks for the response. that doesn’t seem to be working either.
        Is there something I need to install to be able to use stdout?
        S 1 Reply Last reply Apr 2, 2020, 4:48 AM Reply Quote 0
          sdetweil @Temisola1
          @Temisola1 i will look at it in the morning…
          you are seeing the “I’m trying to retrieve data”
          in the terminal window where you did npm start, right?
          T 1 Reply Last reply Apr 2, 2020, 4:48 AM Reply Quote 0
          • T Offline
            Temisola1 @sdetweil
            @sdetweil That is correct. It works up till that point.
            S 1 Reply Last reply Apr 2, 2020, 4:57 AM Reply Quote 0
              sdetweil @Temisola1
              @Temisola1 if you run this does it work from the terminal window?
              testit.py
              import sys
              # Takes first name and last name via command
              # line arguments and then display them
              print("Output from Python")
              print("First name: " )
              print("Last name: " )
              testit.js
                var spawn = require("child_process").spawn;
                  // Parameters passed in spawn -
                  // 1. type_of_script
                  // 2. list containing Path of the script
                  //    and arguments for the script
                  // E.g : http://localhost:3000/name?firstname=Mike&lastname=Will
                  // so, first name = Mike and last name = Will
                  var process = spawn('python3',["./testit.py"]);
                 //                         req.query.firstname,
                   //                       req.query.lastname] );
                  // Takes stdout data from script which executed
                  // with arguments and send this data to res object
                  process.stdout.on('data', (data)=> {
                      console.log("received " +data);
              works for me… (note python script path is ./, make sure u have right path to py file)
              then do
              node testit.js
              T 2 Replies Last reply Apr 2, 2020, 5:27 AM Reply Quote 0
              • T Offline
                Temisola1
                @sdetweil said in child_process won't execute:
                node testit.js
                Yes, that works in the console.
                • T Offline
                  Temisola1 @sdetweil
                  @sdetweil So I tried putting in the full path in my node_helper as opposed to relative path and that seemed to work. is there a way I can log the current directory in nodejs. It seems that’s the issue
                  S 1 Reply Last reply Apr 2, 2020, 11:38 AM Reply Quote 0
                  • T Offline
                    Temisola1 @sdetweil
                    @sdetweil after running successfully a few times it now returns Buffer 48 45 5c… or something that looks like hexadecimal code
                    S 1 Reply Last reply Apr 2, 2020, 12:21 PM Reply Quote 0
                      sdetweil @Temisola1
                      @Temisola1 the node_helper doesn’t know where it is… but the Modulename does…
                      this.path
                      so, you can add that to the config info you send down in the typical
                      sendSocketNotification(“somevalue”, this.config)
                      to pass parameters to the node_helper
