Solved Update MMM
Thank you atm I’m doing a backup of the SD card as separate and i might put an pre updated copy back on and run that until then.
Thank you
hello! I have the same problem. I am going to test the command to check. Updat in progress. I will see if it’s okay after updating. Thanks for your help!
doesn t work… already black screen… I have PIR Sensor too
I did this :
login as: pi pi@192.168.1.18's password: Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Apr 2 09:55:59 2020 from 192.168.1.11 pi@raspberrypi:~ $ cd MagicMirror/ pi@raspberrypi:~/MagicMirror $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git pi@raspberrypi:/ $ git checkout modules/node_modules/node_helper/index.js fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git pi@raspberrypi:/ $ pi@raspberrypi:/ $ login as: pi pi@192.168.1.18's password: Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Apr 2 10:20:36 2020 pi@raspberrypi:~ $ pi@raspberrypi:~ $ cd MagicMirror/ pi@raspberrypi:~/MagicMirror $ npm stop npm ERR! missing script: stop npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-04-02T08_23_06_473Z-debug.log pi@raspberrypi:~/MagicMirror $ pm2 stop mm [PM2][ERROR] Process or Namespace mm not found pi@raspberrypi:~/MagicMirror $ pm2 stop error: missing required argument `id|name|namespace|all|json|stdin' pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0) [PM2] [MagicMirror](0) ✓ ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” #: “#!/bin/bash: Aucun fichier ou dossier de ce type pi@raspberrypi:~/MagicMirror $ cd .. pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” #: “#!/bin/bash: Aucun fichier ou dossier de ce type pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)" $$\ $$\ $$\ $$\ $$\ $$\ $$$$$$\ $$$\ $$$ | \__| $$$\ $$$ |\__| $$ __$$\ $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ \__/ $$ | $$\$$\$$ $$ | \____$$\ $$ __$$\ $$ |$$ _____|$$\$$\$$ $$ |$$ |$$ __$$\ $$ __$$\ $$ __$$\ $$ __$$\ $$$$$$ | $$ \$$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ \$$$ $$ |$$ |$$ | \__|$$ | \__|$$ / $$ |$$ | \__|$$ ____/ $$ |\$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |\$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ | $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ | $$ | \$$$$$$ |$$ | $$$$$$$$\ \__| \__| \_______| \____$$ |\__| \_______|\__| \__|\__|\__| \__| \______/ \__| \________| $$\ $$ | \$$$$$$ | \______/ install log being saved to /home/pi/install.log Updating packages ... Installing helper tools ... Check current Node installation ... Node currently installed. Checking version number. Minimum Node version: v10.1.0 Installed Node version: v10.15.2 No Node.js upgrade necessary. Check current NPM installation ... NPM currently installed. Checking version number. Minimum npm version: V6.0.0 Installed npm version: V6.13.6 No npm upgrade necessary. It seems like MagicMirror is already installed. To prevent overwriting, the installer will be aborted. Please rename the ~/MagicMirror folder and try again. If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory. pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" the log will be /home/pi/MagicMirror/installers/upgrade.log No LSB modules are available. doing test run = true update log will be in /home/pi/MagicMirror/installers/upgrade.log upgrading from version 2.11.0 to 2.11.0 fetching latest revisions there are 1 local files that are different than the master repo package-lock.json any *-lock.json files do not need to be saved do you want to save these files for later (Y/n)?y processing dependency changes for active modules with package.json files processing for module MMM-Selfieshot please wait ---------------------------------- skipped processing for MMM-Selfieshot, doing test run processing complete for module MMM-Selfieshot processing for module MMM-Strava please wait ---------------------------------- skipped processing for MMM-Strava, doing test run processing complete for module MMM-Strava processing for module MMM-PIR-Sensor please wait ---------------------------------- skipped processing for MMM-PIR-Sensor, doing test run processing complete for module MMM-PIR-Sensor processing for module MMM-Spotify please wait ---------------------------------- skipped processing for MMM-Spotify, doing test run processing complete for module MMM-Spotify processing for module MMM-Hotword please wait ---------------------------------- skipped processing for MMM-Hotword, doing test run processing complete for module MMM-Hotword processing for module MMM-AssistantMk2 please wait ---------------------------------- skipped processing for MMM-AssistantMk2, doing test run processing complete for module MMM-AssistantMk2 test run, restoring files stashed pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply the log will be /home/pi/MagicMirror/installers/upgrade.log No LSB modules are available. doing test run = false update log will be in /home/pi/MagicMirror/installers/upgrade.log local version 2.11.0 already same as master 2.11.0 pi@raspberrypi:~ $ npm start npm ERR! code ENOENT npm ERR! syscall open npm ERR! path /home/pi/package.json npm ERR! errno -2 npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm ERR! enoent This is related to npm not being able to find a file. npm ERR! enoent npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-04-02T09_03_45_797Z-debug.log pi@raspberrypi:~ $ sudo reboot pi@raspberrypi:~ $ login as: pi pi@192.168.1.18's password: Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Apr 2 11:04:36 2020 pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)" server does not have extension for -dpms option pi@raspberrypi:~ $ pi@raspberrypi:~ $ fixuppm2.sh -bash: fixuppm2.sh : commande introuvable pi@raspberrypi:~ $ pm2 stop mm ^C pi@raspberrypi:~ $ pm2 stop MagicMirror [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0) [PM2] [MagicMirror](0) ✓ ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)" pi@raspberrypi:~ $ pi@raspberrypi:~ $ fixuppm2.sh -bash: fixuppm2.sh : commande introuvable pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)" pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)" the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log removed 207 packages in 17.491s npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/pm2/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) [PM2][ERROR] File /home/pi/MagicMirror/installers/pm2_MagicMirror.json not found [PM2] Saving current process list... [PM2][WARN] PM2 is not managing any process, skipping save... [PM2][WARN] To force saving use: pm2 save --force pi@raspberrypi:~ $ sudo reboot
And during the update :
pi@raspberrypi:~/MagicMirror $ git pull && npm install Mise à jour 5bf90ae..447c0bf Fast-forward .eslintrc.json | 1 + .github/ISSUE_TEMPLATE.md | 21 +- .travis.yml | 27 +- CHANGELOG.md | 59 +- Gruntfile.js | 13 +- clientonly/index.js | 2 - config/config.js.sample | 18 +- index.html | 2 +- installers/dumpactivemodules.js | 15 - installers/fixuppm2.sh | 183 - installers/mm.sh | 1 + installers/pm2_MagicMirror.json | 7 - installers/postinstall/postinstall.sh | 2 - installers/raspberry.sh | 569 --- installers/screensaveroff.sh | 101 - installers/upgrade-script.sh | 361 -- js/app.js | 11 +- js/electron.js | 2 - js/loader.js | 6 +- js/main.js | 15 +- js/module.js | 11 +- js/node_helper.js | 4 +- js/server.js | 14 +- js/socketclient.js | 8 +- modules/README.md | 721 ---- modules/default/alert/README.md | 63 +- modules/default/calendar/README.md | 105 +- modules/default/calendar/calendar.js | 4 +- modules/default/calendar/calendarfetcher.js | 13 +- modules/default/calendar/debug.js | 2 +- .../default/calendar/vendor/ical.js/node-ical.js | 15 +- modules/default/clock/README.md | 54 +- modules/default/clock/clock.js | 58 +- modules/default/clock/clock_screenshot.png | Bin 30525 -> 0 bytes modules/default/clock/clock_styles.css | 10 + modules/default/compliments/README.md | 148 +- modules/default/compliments/compliments.js | 41 +- .../default/compliments/compliments_screenshot.png | Bin 26157 -> 0 bytes modules/default/currentweather/README.md | 86 +- modules/default/currentweather/currentweather.js | 23 +- .../default/currentweather/weather_screenshot.png | Bin 38566 -> 0 bytes modules/default/helloworld/README.md | 23 +- modules/default/newsfeed/README.md | 104 +- modules/default/newsfeed/newsfeed.js | 5 +- modules/default/newsfeed/newsfeed_screenshot.png | Bin 45375 -> 0 bytes modules/default/updatenotification/README.md | 24 +- modules/default/updatenotification/node_helper.js | 74 +- .../updatenotification/updatenotification.js | 1 + modules/default/weather/README.md | 117 +- modules/default/weather/current.png | Bin 8141 -> 0 bytes modules/default/weather/forecast.png | Bin 16385 -> 0 bytes modules/default/weatherforecast/README.md | 79 +- .../weatherforecast/forecast_screenshot.png | Bin 86206 -> 0 bytes package-lock.json | 4524 +++++++++----------- package.json | 21 +- run-start.sh | 67 - serveronly/index.js | 3 +- tests/configs/check_config.js | 14 +- .../modules/compliments/compliments_date.js | 41 + .../modules/weather/forecastweather_default.js | 46 +- .../modules/weather/forecastweather_options.js | 52 +- tests/e2e/modules/compliments_spec.js | 15 + tests/e2e/modules/mocks/weather_current.js | 98 +- tests/e2e/modules/mocks/weather_forecast.js | 184 +- tests/e2e/modules/weather_spec.js | 39 +- tests/e2e/vendor_spec.js | 15 +- tests/node_modules/webdriverajaxstub/index.js | 4 +- tests/unit/functions/currentweather_spec.js | 1 + tests/unit/functions/weatherforecast_spec.js | 1 + translations/fi.json | 5 +- translations/he.json | 36 + translations/hr.json | 2 +- translations/pl.json | 3 +- translations/pt-br.json | 5 +- translations/tr.json | 14 +- translations/translations.js | 10 +- translations/uk.json | 36 + untrack-css.sh | 11 - 78 files changed, 2680 insertions(+), 5790 deletions(-) mode change 100755 => 100644 CHANGELOG.md delete mode 100644 installers/dumpactivemodules.js delete mode 100755 installers/fixuppm2.sh delete mode 100644 installers/pm2_MagicMirror.json delete mode 100644 installers/postinstall/postinstall.sh delete mode 100755 installers/raspberry.sh delete mode 100755 installers/screensaveroff.sh delete mode 100755 installers/upgrade-script.sh delete mode 100644 modules/README.md delete mode 100644 modules/default/clock/clock_screenshot.png delete mode 100644 modules/default/compliments/compliments_screenshot.png delete mode 100644 modules/default/currentweather/weather_screenshot.png delete mode 100644 modules/default/newsfeed/newsfeed_screenshot.png delete mode 100644 modules/default/weather/current.png delete mode 100644 modules/default/weather/forecast.png delete mode 100644 modules/default/weatherforecast/forecast_screenshot.png delete mode 100755 run-start.sh create mode 100644 tests/configs/modules/compliments/compliments_date.js create mode 100644 translations/he.json create mode 100644 translations/uk.json delete mode 100755 untrack-css.sh npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this instal led. > electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron -chromedriver > node ./download-chromedriver.js > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron > node install.js Downloading tmp-1525-1-SHASUMS256.txt-6.1.7 [============================================>] 100.0% of 5.56 kB (5.56 kB/s) > magicmirror@2.11.0 install /home/pi/MagicMirror > echo "Installing vendor files ... " && cd vendor && npm install --loglevel=error Installing vendor files ... audited 220 packages in 25.414s found 8 vulnerabilities (7 low, 1 high) run `npm audit fix` to fix them, or `npm audit` for details > magicmirror@2.11.0 postinstall /home/pi/MagicMirror > npm run install-fonts && echo "MagicMirror installation finished successfully! " > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror > echo "Installing fonts ... " && cd fonts && npm install --loglevel=error Installing fonts ... audited 1 package in 3.182s found 0 vulnerabilities MagicMirror installation finished successfully! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fse vents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"} ) added 124 packages from 84 contributors, removed 79 packages, updated 54 package s and moved 1 package in 774.482s 26 packages are looking for funding run `npm fund` for details pi@raspberrypi:~/MagicMirror $ sudo reboot pi@raspberrypi:~ $ npm start npm ERR! code ENOENT npm ERR! syscall open npm ERR! path /home/pi/package.json npm ERR! errno -2 npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm ERR! enoent This is related to npm not being able to find a file. npm ERR! enoent npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-04-02T07_56_36_218Z-debug.log pi@raspberrypi:~ $ cd MagicMirror/ pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.11.0 start /home/pi/MagicMirror > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [2020-04-02 09:57:00.458] [LOG] Starting MagicMirror: v2.11.0 [2020-04-02 09:57:00.477] [LOG] Loading config ... [2020-04-02 09:57:00.488] [LOG] Loading module helpers ... [2020-04-02 09:57:00.492] [LOG] No helper found for module: alert. [2020-04-02 09:57:00.601] [LOG] Initializing new module helper ... [2020-04-02 09:57:00.604] [LOG] Module helper loaded: updatenotification [2020-04-02 09:57:00.607] [LOG] No helper found for module: clock. [2020-04-02 09:57:01.480] [LOG] Initializing new module helper ... [2020-04-02 09:57:01.481] [LOG] Module helper loaded: calendar [2020-04-02 09:57:01.700] [LOG] Initializing new module helper ... [2020-04-02 09:57:01.703] [LOG] Module helper loaded: MMM-Selfieshot [2020-04-02 09:57:01.705] [LOG] No helper found for module: compliments. [2020-04-02 09:57:01.708] [LOG] No helper found for module: currentweather. [2020-04-02 09:57:01.711] [LOG] No helper found for module: weatherforecast. [2020-04-02 09:57:02.820] [LOG] Initializing new module helper ... [2020-04-02 09:57:02.822] [LOG] Check MagicMirror version for node helper 'MM M-Strava' - Minimum version: 2.2.0 - Current version: 2.11.0 [2020-04-02 09:57:02.823] [LOG] Version is ok! [2020-04-02 09:57:02.824] [LOG] Module helper loaded: MMM-Strava [2020-04-02 09:57:02.861] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirro r/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 73. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`). [2020-04-02 09:57:02.864] [LOG] Loading module helpers ... [2020-04-02 09:57:02.867] [LOG] No helper found for module: alert. [2020-04-02 09:57:02.869] [LOG] Initializing new module helper ... [2020-04-02 09:57:02.871] [LOG] Module helper loaded: updatenotification [2020-04-02 09:57:02.873] [LOG] No helper found for module: clock. [2020-04-02 09:57:02.875] [LOG] Initializing new module helper ... [2020-04-02 09:57:02.877] [LOG] Module helper loaded: calendar [2020-04-02 09:57:02.878] [LOG] Initializing new module helper ... [2020-04-02 09:57:02.879] [LOG] Module helper loaded: MMM-Selfieshot [2020-04-02 09:57:02.881] [LOG] No helper found for module: compliments. [2020-04-02 09:57:02.882] [LOG] No helper found for module: currentweather. [2020-04-02 09:57:02.883] [LOG] No helper found for module: weatherforecast. [2020-04-02 09:57:02.884] [LOG] Initializing new module helper ... [2020-04-02 09:57:02.885] [LOG] Check MagicMirror version for node helper 'MM M-Strava' - Minimum version: 2.2.0 - Current version: 2.11.0 [2020-04-02 09:57:02.886] [LOG] Version is ok! [2020-04-02 09:57:02.887] [LOG] Module helper loaded: MMM-Strava [2020-04-02 09:57:02.899] [ERROR] App threw an error during load [2020-04-02 09:57:02.902] [ERROR] Error: The module '/home/pi/MagicMirror/modul es/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 73. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`). at process.func (electron/js2c/asar.js:138:31) at process.func [as dlopen] (electron/js2c/asar.js:138:31) at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18) at Object.func (electron/js2c/asar.js:138:31) at Object.func [as .node] (electron/js2c/asar.js:138:31) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindin gs/bindings.js:112:48) at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7 :31 at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu les/epoll/epoll.js:15:3) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu les/onoff/onoff.js:5:15) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) [2020-04-02 09:57:02.907] [LOG] Whoops! There was an uncaught exception... [2020-04-02 09:57:02.909] [ERROR] Error: The module '/home/pi/MagicMirror/modul es/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 64. This version of Node.js requires NODE_MODULE_VERSION 73. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`). at process.func (electron/js2c/asar.js:138:31) at process.func [as dlopen] (electron/js2c/asar.js:138:31) at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18) at Object.func (electron/js2c/asar.js:138:31) at Object.func [as .node] (electron/js2c/asar.js:138:31) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindin gs/bindings.js:112:48) at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7 :31 at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu les/epoll/epoll.js:15:3) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu les/onoff/onoff.js:5:15) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) [2020-04-02 09:57:02.917] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [2020-04-02 09:57:02.918] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [2020-04-02 09:57:03.080] [LOG] Launching application. ^C[2020-04-02 09:59:16.827] [LOG] Shutting down server... [2020-04-02 09:59:16.835] [LOG] Stopping module helper: updatenotification [2020-04-02 09:59:16.836] [LOG] Stopping module helper: calendar [2020-04-02 09:59:16.837] [LOG] Stopping module helper: MMM-Selfieshot [2020-04-02 09:59:16.838] [LOG] Stopping module helper: MMM-Strava [2020-04-02 09:59:16.839] [LOG] Stopping module helper: updatenotification [2020-04-02 09:59:16.840] [LOG] Stopping module helper: calendar [2020-04-02 09:59:16.842] [LOG] Stopping module helper: MMM-Selfieshot [2020-04-02 09:59:16.843] [LOG] Stopping module helper: MMM-Strava pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.11.0 start /home/pi/MagicMirror > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [2020-04-02 09:59:39.647] [LOG] Starting MagicMirror: v2.11.0 [2020-04-02 09:59:39.665] [LOG] Loading config ... [2020-04-02 09:59:39.675] [LOG] Loading module helpers ... [2020-04-02 09:59:39.682] [LOG] No helper found for module: alert. [2020-04-02 09:59:39.796] [LOG] Initializing new module helper ... [2020-04-02 09:59:39.798] [LOG] Module helper loaded: updatenotification [2020-04-02 09:59:39.799] [LOG] No helper found for module: clock. [2020-04-02 09:59:40.636] [LOG] Initializing new module helper ... [2020-04-02 09:59:40.637] [LOG] Module helper loaded: calendar [2020-04-02 09:59:40.856] [LOG] Initializing new module helper ... [2020-04-02 09:59:40.858] [LOG] Module helper loaded: MMM-Selfieshot [2020-04-02 09:59:40.861] [LOG] No helper found for module: compliments. [2020-04-02 09:59:40.862] [LOG] No helper found for module: currentweather. [2020-04-02 09:59:40.864] [LOG] No helper found for module: weatherforecast. [2020-04-02 09:59:41.992] [LOG] Initializing new module helper ... [2020-04-02 09:59:41.994] [LOG] Check MagicMirror version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.11.0 [2020-04-02 09:59:41.996] [LOG] Version is ok! [2020-04-02 09:59:41.997] [LOG] Module helper loaded: MMM-Strava [2020-04-02 09:59:42.049] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.051] [LOG] Module helper loaded: newsfeed [2020-04-02 09:59:42.054] [LOG] No helper found for module: MMM-YouTube. [2020-04-02 09:59:42.074] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.076] [LOG] Module helper loaded: MMM-Spotify [2020-04-02 09:59:42.382] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node' Require stack: - /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - [2020-04-02 09:59:42.385] [LOG] Loading module helpers ... [2020-04-02 09:59:42.388] [LOG] No helper found for module: alert. [2020-04-02 09:59:42.391] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.392] [LOG] Module helper loaded: updatenotification [2020-04-02 09:59:42.394] [LOG] No helper found for module: clock. [2020-04-02 09:59:42.396] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.397] [LOG] Module helper loaded: calendar [2020-04-02 09:59:42.398] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.398] [LOG] Module helper loaded: MMM-Selfieshot [2020-04-02 09:59:42.400] [LOG] No helper found for module: compliments. [2020-04-02 09:59:42.401] [LOG] No helper found for module: currentweather. [2020-04-02 09:59:42.402] [LOG] No helper found for module: weatherforecast. [2020-04-02 09:59:42.403] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.404] [LOG] Check MagicMirror version for node helper 'MMM-Strava' - Minimum version: 2.2.0 - Current version: 2.11.0 [2020-04-02 09:59:42.405] [LOG] Version is ok! [2020-04-02 09:59:42.406] [LOG] Module helper loaded: MMM-Strava [2020-04-02 09:59:42.407] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.408] [LOG] Module helper loaded: newsfeed [2020-04-02 09:59:42.410] [LOG] No helper found for module: MMM-YouTube. [2020-04-02 09:59:42.412] [LOG] Initializing new module helper ... [2020-04-02 09:59:42.414] [LOG] Module helper loaded: MMM-Spotify [2020-04-02 09:59:42.428] [ERROR] App threw an error during load [2020-04-02 09:59:42.429] [ERROR] Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node' Require stack: - /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at Function.Module._load (internal/modules/cjs/loader.js:531:27) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js:8:29) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:11:18) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at loadModule (/home/pi/MagicMirror/js/app.js:131:17) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) [2020-04-02 09:59:42.432] [LOG] Whoops! There was an uncaught exception... [2020-04-02 09:59:42.433] [ERROR] Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node' Require stack: - /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at Function.Module._load (internal/modules/cjs/loader.js:531:27) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js:8:29) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:11:18) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) at Function.Module._load (internal/modules/cjs/loader.js:560:12) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at loadModule (/home/pi/MagicMirror/js/app.js:131:17) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) { code: 'MODULE_NOT_FOUND', requireStack: [ '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js', '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js', '/home/pi/MagicMirror/js/app.js', '/home/pi/MagicMirror/js/electron.js', '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js', undefined ] } [2020-04-02 09:59:42.447] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [2020-04-02 09:59:42.449] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [2020-04-02 09:59:42.629] [LOG] Launching application. ^C[2020-04-02 10:01:17.981] [LOG] Shutting down server... [2020-04-02 10:01:17.990] [LOG] Stopping module helper: updatenotification [2020-04-02 10:01:17.992] [LOG] Stopping module helper: calendar [2020-04-02 10:01:17.993] [LOG] Stopping module helper: MMM-Selfieshot [2020-04-02 10:01:17.994] [LOG] Stopping module helper: MMM-Strava [2020-04-02 10:01:17.996] [LOG] Stopping module helper: newsfeed [2020-04-02 10:01:17.997] [LOG] Stopping module helper: MMM-Spotify [2020-04-02 10:01:17.999] [LOG] Stopping module helper: updatenotification [2020-04-02 10:01:18.001] [LOG] Stopping module helper: calendar [2020-04-02 10:01:18.003] [LOG] Stopping module helper: MMM-Selfieshot [2020-04-02 10:01:18.005] [LOG] Stopping module helper: MMM-Strava [2020-04-02 10:01:18.007] [LOG] Stopping module helper: newsfeed [2020-04-02 10:01:18.009] [LOG] Stopping module helper: MMM-Spotify pi@raspberrypi:~/MagicMirror $ git pull Déjà à jour. pi@raspberrypi:~/MagicMirror $ apt-get update Lecture des listes de paquets... Fait E: Impossible d'ouvrir le fichier verrou /var/lib/apt/lists/lock - open (13: Permission non accordée) E: Impossible de verrouiller le répertoire /var/lib/apt/lists/ W: Problème de suppression du lien /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission non accordée) W: Problème de suppression du lien /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission non accordée) pi@raspberrypi:~/MagicMirror $ cd .. pi@raspberrypi:~ $ apt-get update Lecture des listes de paquets... Fait E: Impossible d'ouvrir le fichier verrou /var/lib/apt/lists/lock - open (13: Permission non accordée) E: Impossible de verrouiller le répertoire /var/lib/apt/lists/ W: Problème de suppression du lien /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission non accordée) W: Problème de suppression du lien /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission non accordée) pi@raspberrypi:~ $ ^C pi@raspberrypi:~ $ cmd": "cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js -bash: cmd: cd : commande introuvable pi@raspberrypi:~ $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git pi@raspberrypi:/ $ ls bin boot dev etc home lib lost+found media mnt opt proc root run sbin srv sys tmp usr var pi@raspberrypi:/ $
Thanks for help…
after had followed the explanations page 3, the mirror is okay.
But, he seems that jarvis doesn’t work as before… when I say ‘what time is it’ he open a windows with the google search haha but otherwize the over questions are ok, jarvis answer correctly.
After, The module spotify doesn t work and PIR sensor… I will check it
sorry for my english, i m french -
Some problem:
git pull
Updating 5bf90ae…447c0bf
error: Your local changes to the following files would be overwritten by merge:
package-lock.json
Please commit your changes or stash them before you merge.
Abortinghelp me please, thanks
@jims said in Update MMM:
if at the same level u have to use ‘force’ as ‘apply’ will stop if the same level
always start MM from the ~/MagicMirror folder, not the users home folder
no update from version 2.10.1 to 2.11.0
in the folder:pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
bash: warning: setlocale: LC_ALL: cannot change locale (it_IT)
update log will be in /home/pi/MagicMirror/installers/upgrade.logupgrading from version 2.10.1 to 2.11.0
bash: line 396: warning: setlocale: LC_ALL: cannot change locale (it_IT)
there are 2 local files that are different than the master repomodules/default/compliments/compliments.js
package-lock.jsonany *-lock.json files do not need to be saved
do you want to save these files for later (Y/n)?n
skipping restore for modules/default/compliments/compliments.js, doing test run
skipping restore for package-lock.json, doing test run
processing dependency changes for active modules with package.json filesprocessing for module MMM-network-signal please wait
skipped processing for MMM-network-signal, doing test run
processing complete for module MMM-network-signalprocessing for module MMM-GooglePhotos please wait
skipped processing for MMM-GooglePhotos, doing test run
processing complete for module MMM-GooglePhotosprocessing for module MMM-COVID19-SPARKLINE please wait
skipped processing for MMM-COVID19-SPARKLINE, doing test run
processing complete for module MMM-COVID19-SPARKLINEprocessing for module MMM-NowPlayingOnSpotify please wait
skipped processing for MMM-NowPlayingOnSpotify, doing test run
processing complete for module MMM-NowPlayingOnSpotifyprocessing for module MMM-AlexaControl please wait
skipped processing for MMM-AlexaControl, doing test run
processing complete for module MMM-AlexaControl -
@minomit said in Update MMM:
upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it it should handle all the work… and give you a trial run of all that… only applying changes if u request them give it a try this works on Mac as well bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" no changes are made to the local repo or the working copy **if you WANT to actually apply the changes do** bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply there is a log file (upgrade.log) in the MagicMirror/installers folder…
I built it to TEST first… and not just blindly apply… give u a chance to figure out what to do…
notice it highlights a file u might want to look out for
did u change this? if so, your changes might be lost
