    MM crashes after latest update
    19 Posts 2 Posters 6.0k Views 2 Watching
      joberbroeckling
      Yes. That was what I meant. I did a npm install in all of the module folders. It seems like the system load has increased since the latest update.
        what modules do you have installed?
        can u run my update script…
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
        then the update info will be in the ~/MagicMirror/installers/upgrade.log
          joberbroeckling
          @sdetweil said in MM crashes after latest update:
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
          I updated with the script and I am seeing the same issue.
            sdetweil @joberbroeckling
            @joberbroeckling on, can u post the upgrade.log
              joberbroeckling
              Upgrade started - Thu Apr  2 18:40:15 MST 2020
              system is Linux raspberrypi 4.19.113-v7+ #1300 SMP Thu Mar 26 16:53:09 GMT 2020 armv7l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretch) Release: 9.11 Codename: stretch
              user requested to force apply changes
              doing test run = false
              saving custom.css
              remote name = origin
              upgrading from version 2.11.0 to 2.11.0
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up-to-date with 'origin/master'.
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
              	modified:   package-lock.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	core
              	css/custom.css.backup
              	css/save_custom.css
              no changes added to commit (use "git add" and/or "git commit -a")
              there are 1 local files that are different than the master repo
                 package-lock.json
              save/restore files selection = n
              restoring package-lock.json from repo
              test merge result rc='' , if empty, no conflicts
              executing merge, apply specified
              merge result rc= 0
               Already up-to-date.
              processor architecture is armv7l
              > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              > magicmirror@2.11.0 install /home/pi/MagicMirror
              " && cd vendor && npm install --loglevel=error
              audited 220 packages in 11.443s
              found 8 vulnerabilities (7 low, 1 high)
                run `npm audit fix` to fix them, or `npm audit` for details
              > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
              > npm run install-fonts && echo "MagicMirror installation finished successfully!
              > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
              > echo "Installing fonts ...
              " && cd fonts && npm install --loglevel=error
              audited 1 package in 0.963s
              found 0 vulnerabilities
              added 3 packages from 39 contributors, updated 30 packages and audited 3040 packages in 90.677s
              47 packages are looking for funding
                run `npm fund` for details
              found 23 vulnerabilities (20 low, 3 moderate)
              npm install completed - Thu Apr  2 18:42:09 MST 2020 on base
              downloading dumpactivemodules script
              processing for module MMM-DarkSkyForecast please wait
              audited 12116 packages in 19.742s
              1 package is looking for funding
              processing complete for module MMM-DarkSkyForecast
              processing for module MMM-homeassistant-sensors please wait
              audited 1 package in 1.058s
              processing complete for module MMM-homeassistant-sensors
              processing for module MMM-Remote-Control please wait
              audited 36 packages in 1.997s
              processing complete for module MMM-Remote-Control
              processing for module MMM-CountDown please wait
              npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself.
              npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
              npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
              npm WARN MMM-CountDown@1.0.0 No repository field.
              audited 429 packages in 9.677s
              9 packages are looking for funding
              processing complete for module MMM-CountDown
              audited 429 packages in 10.51s
              audited 429 packages in 9.549s
              processing for module MMM-SystemStats please wait
              audited 1 package in 1.046s
              processing complete for module MMM-SystemStats
              processing for module MMM-CalendarExt2 please wait
              audited 5 packages in 1.106s
              processing complete for module MMM-CalendarExt2
              restoring custom.css
              removing git alias
              Upgrade ended - Thu Apr  2 18:43:39 MST 2020
                @joberbroeckling said in MM crashes after latest update:
                MMM-Remote-Control
                has an issue against it not working on 2.11, and
                maybe MMM-homeassistant-sensors… I can’t tell, there are 6 different versions… which one do you have?
                (git remote -v in the module folder will give the git repo name).
                  joberbroeckling
                  https://github.com/Snille/MMM-homeassistant-sensors
                    @joberbroeckling ok. That one only has fonts as a dependency
                      joberbroeckling
                      I think it may be the DarkSky module. Since I have reached my API request limit it has stopped crashing.
                        joberbroeckling
                        I think I spoke too soon. I removed the DarkSky, Remote Control and Home Assistant Sensors modules and it still crashes on start up. The system load is high but after a while it decreases. I think I will try to a fresh install and see what happens.
                          joberbroeckling
                          I did a fresh install and installed the modules one at a time. I commented out the modules I already added in my config file. I did notice there is a thread going on regarding MMM-Remote-Control module not working with latest update. So I removed it because I don’t use it that much anyways.
                          Then I un-commented all the modules in my config file and it crashed again. I think it has to do with Electron. But I am not a professional and I am only doing this for fun. The CPU load is huge when it starts up. I don’t think this will work on RPI 3 anymore.
                          I reverted back to 2.10.1 and everything seems to work fine.
                            @joberbroeckling i have it running on pi 0, pi 3, pi 4, odroid, nano, ubuntu, and Mac catalina
                            no issues…
                            I don’t use remote-control or pir, or buttons
                            there is a fix for the remote-control in that topic (u have to change the code)
                            so, fresh install, no additions/changes, does it run ok?
                              joberbroeckling
                              If I do a fresh install and add the same modules (except remote-control) I had before it crashes. So I am not sure how to test which module is causing the issue.
                                @joberbroeckling disabled all the modules u added,
                                add
                                disabled:true.
                                to each module section
                                module:?????,
                                disabled:true,
                                pm2 stop 0
                                one at a time, change true to false, restart mirror
                                npm start dev
                                if it works, ctrl-c to kill mirror, edit config, enable next
                                and repeat
                                if it fails, see the terminal window and developers window, console tab for errors
                                ctrl c on terminal window to exit
                                  joberbroeckling
                                  I think I figured out what the issue is. It has to do with the MMM-WatchDog and the interval was too low. It was previously set to 10s. I upped it to 30s and it hasn’t restarted since.
