    MM crashes after latest update
    19 Posts 2 Posters 6.0k Views 2 Watching
      what modules do you have installed?
      can u run my update script…
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
      then the update info will be in the ~/MagicMirror/installers/upgrade.log
        joberbroeckling
        @sdetweil said in MM crashes after latest update:
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
        I updated with the script and I am seeing the same issue.
          sdetweil @joberbroeckling
          @joberbroeckling on, can u post the upgrade.log
            joberbroeckling
            Upgrade started - Thu Apr  2 18:40:15 MST 2020
            system is Linux raspberrypi 4.19.113-v7+ #1300 SMP Thu Mar 26 16:53:09 GMT 2020 armv7l GNU/Linux
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretch) Release: 9.11 Codename: stretch
            user requested to force apply changes
            doing test run = false
            saving custom.css
            remote name = origin
            upgrading from version 2.11.0 to 2.11.0
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is up-to-date with 'origin/master'.
              (use "git add <file>..." to update what will be committed)
              (use "git checkout -- <file>..." to discard changes in working directory)
            	modified:   package-lock.json
            Untracked files:
              (use "git add <file>..." to include in what will be committed)
            	core
            	css/custom.css.backup
            	css/save_custom.css
            no changes added to commit (use "git add" and/or "git commit -a")
            there are 1 local files that are different than the master repo
               package-lock.json
            save/restore files selection = n
            restoring package-lock.json from repo
            test merge result rc='' , if empty, no conflicts
            executing merge, apply specified
            merge result rc= 0
             Already up-to-date.
            processor architecture is armv7l
            > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            > magicmirror@2.11.0 install /home/pi/MagicMirror
            " && cd vendor && npm install --loglevel=error
            audited 220 packages in 11.443s
            found 8 vulnerabilities (7 low, 1 high)
              run `npm audit fix` to fix them, or `npm audit` for details
            > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
            > npm run install-fonts && echo "MagicMirror installation finished successfully!
            > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
            > echo "Installing fonts ...
            " && cd fonts && npm install --loglevel=error
            audited 1 package in 0.963s
            found 0 vulnerabilities
            added 3 packages from 39 contributors, updated 30 packages and audited 3040 packages in 90.677s
            47 packages are looking for funding
              run `npm fund` for details
            found 23 vulnerabilities (20 low, 3 moderate)
            npm install completed - Thu Apr  2 18:42:09 MST 2020 on base
            downloading dumpactivemodules script
            processing for module MMM-DarkSkyForecast please wait
            audited 12116 packages in 19.742s
            1 package is looking for funding
            processing complete for module MMM-DarkSkyForecast
            processing for module MMM-homeassistant-sensors please wait
            audited 1 package in 1.058s
            processing complete for module MMM-homeassistant-sensors
            processing for module MMM-Remote-Control please wait
            audited 36 packages in 1.997s
            processing complete for module MMM-Remote-Control
            processing for module MMM-CountDown please wait
            npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself.
            npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
            npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
            npm WARN MMM-CountDown@1.0.0 No repository field.
            audited 429 packages in 9.677s
            9 packages are looking for funding
            processing complete for module MMM-CountDown
            audited 429 packages in 10.51s
            audited 429 packages in 9.549s
            processing for module MMM-SystemStats please wait
            audited 1 package in 1.046s
            processing complete for module MMM-SystemStats
            processing for module MMM-CalendarExt2 please wait
            audited 5 packages in 1.106s
            processing complete for module MMM-CalendarExt2
            restoring custom.css
            removing git alias
            Upgrade ended - Thu Apr  2 18:43:39 MST 2020
              @joberbroeckling said in MM crashes after latest update:
              MMM-Remote-Control
              has an issue against it not working on 2.11, and
              maybe MMM-homeassistant-sensors… I can’t tell, there are 6 different versions… which one do you have?
              (git remote -v in the module folder will give the git repo name).
                joberbroeckling
                https://github.com/Snille/MMM-homeassistant-sensors
                  @joberbroeckling ok. That one only has fonts as a dependency
                    joberbroeckling
                    I think it may be the DarkSky module. Since I have reached my API request limit it has stopped crashing.
                      joberbroeckling
                      I think I spoke too soon. I removed the DarkSky, Remote Control and Home Assistant Sensors modules and it still crashes on start up. The system load is high but after a while it decreases. I think I will try to a fresh install and see what happens.
                        joberbroeckling
                        I did a fresh install and installed the modules one at a time. I commented out the modules I already added in my config file. I did notice there is a thread going on regarding MMM-Remote-Control module not working with latest update. So I removed it because I don’t use it that much anyways.
                        Then I un-commented all the modules in my config file and it crashed again. I think it has to do with Electron. But I am not a professional and I am only doing this for fun. The CPU load is huge when it starts up. I don’t think this will work on RPI 3 anymore.
                        I reverted back to 2.10.1 and everything seems to work fine.
                          @joberbroeckling i have it running on pi 0, pi 3, pi 4, odroid, nano, ubuntu, and Mac catalina
                          no issues…
                          I don’t use remote-control or pir, or buttons
                          there is a fix for the remote-control in that topic (u have to change the code)
                          so, fresh install, no additions/changes, does it run ok?
                            joberbroeckling
                            If I do a fresh install and add the same modules (except remote-control) I had before it crashes. So I am not sure how to test which module is causing the issue.
                              @joberbroeckling disabled all the modules u added,
                              add
                              disabled:true.
                              to each module section
                              module:?????,
                              disabled:true,
                              pm2 stop 0
                              one at a time, change true to false, restart mirror
                              npm start dev
                              if it works, ctrl-c to kill mirror, edit config, enable next
                              and repeat
                              if it fails, see the terminal window and developers window, console tab for errors
                              ctrl c on terminal window to exit
                                joberbroeckling
                                I think I figured out what the issue is. It has to do with the MMM-WatchDog and the interval was too low. It was previously set to 10s. I upped it to 30s and it hasn’t restarted since.
