    MM crashes after latest update
    19 Posts 2 Posters 6.0k Views 2 Watching
      sdetweil @joberbroeckling
      @joberbroeckling on, can u post the upgrade.log
        joberbroeckling
        Upgrade started - Thu Apr  2 18:40:15 MST 2020
        system is Linux raspberrypi 4.19.113-v7+ #1300 SMP Thu Mar 26 16:53:09 GMT 2020 armv7l GNU/Linux
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 9.11 (stretch) Release: 9.11 Codename: stretch
        user requested to force apply changes
        doing test run = false
        saving custom.css
        remote name = origin
        upgrading from version 2.11.0 to 2.11.0
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is up-to-date with 'origin/master'.
          (use "git add <file>..." to update what will be committed)
          (use "git checkout -- <file>..." to discard changes in working directory)
        	modified:   package-lock.json
        Untracked files:
          (use "git add <file>..." to include in what will be committed)
        	core
        	css/custom.css.backup
        	css/save_custom.css
        no changes added to commit (use "git add" and/or "git commit -a")
        there are 1 local files that are different than the master repo
           package-lock.json
        save/restore files selection = n
        restoring package-lock.json from repo
        test merge result rc='' , if empty, no conflicts
        executing merge, apply specified
        merge result rc= 0
         Already up-to-date.
        processor architecture is armv7l
        > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
        > node install.js
        > magicmirror@2.11.0 install /home/pi/MagicMirror
        " && cd vendor && npm install --loglevel=error
        audited 220 packages in 11.443s
        found 8 vulnerabilities (7 low, 1 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
        > npm run install-fonts && echo "MagicMirror installation finished successfully!
        > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
        > echo "Installing fonts ...
        " && cd fonts && npm install --loglevel=error
        audited 1 package in 0.963s
        found 0 vulnerabilities
        added 3 packages from 39 contributors, updated 30 packages and audited 3040 packages in 90.677s
        47 packages are looking for funding
          run `npm fund` for details
        found 23 vulnerabilities (20 low, 3 moderate)
        npm install completed - Thu Apr  2 18:42:09 MST 2020 on base
        downloading dumpactivemodules script
        processing for module MMM-DarkSkyForecast please wait
        audited 12116 packages in 19.742s
        1 package is looking for funding
        processing complete for module MMM-DarkSkyForecast
        processing for module MMM-homeassistant-sensors please wait
        audited 1 package in 1.058s
        processing complete for module MMM-homeassistant-sensors
        processing for module MMM-Remote-Control please wait
        audited 36 packages in 1.997s
        processing complete for module MMM-Remote-Control
        processing for module MMM-CountDown please wait
        npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself.
        npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
        npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
        npm WARN MMM-CountDown@1.0.0 No repository field.
        audited 429 packages in 9.677s
        9 packages are looking for funding
        processing complete for module MMM-CountDown
        audited 429 packages in 10.51s
        audited 429 packages in 9.549s
        processing for module MMM-SystemStats please wait
        audited 1 package in 1.046s
        processing complete for module MMM-SystemStats
        processing for module MMM-CalendarExt2 please wait
        audited 5 packages in 1.106s
        processing complete for module MMM-CalendarExt2
        restoring custom.css
        removing git alias
        Upgrade ended - Thu Apr  2 18:43:39 MST 2020
          @joberbroeckling said in MM crashes after latest update:
          MMM-Remote-Control
          has an issue against it not working on 2.11, and
          maybe MMM-homeassistant-sensors… I can’t tell, there are 6 different versions… which one do you have?
          (git remote -v in the module folder will give the git repo name).
            joberbroeckling
            https://github.com/Snille/MMM-homeassistant-sensors
              @joberbroeckling ok. That one only has fonts as a dependency
                joberbroeckling
                I think it may be the DarkSky module. Since I have reached my API request limit it has stopped crashing.
                  joberbroeckling
                  I think I spoke too soon. I removed the DarkSky, Remote Control and Home Assistant Sensors modules and it still crashes on start up. The system load is high but after a while it decreases. I think I will try to a fresh install and see what happens.
                    joberbroeckling
                    I did a fresh install and installed the modules one at a time. I commented out the modules I already added in my config file. I did notice there is a thread going on regarding MMM-Remote-Control module not working with latest update. So I removed it because I don’t use it that much anyways.
                    Then I un-commented all the modules in my config file and it crashed again. I think it has to do with Electron. But I am not a professional and I am only doing this for fun. The CPU load is huge when it starts up. I don’t think this will work on RPI 3 anymore.
                    I reverted back to 2.10.1 and everything seems to work fine.
                      @joberbroeckling i have it running on pi 0, pi 3, pi 4, odroid, nano, ubuntu, and Mac catalina
                      no issues…
                      I don’t use remote-control or pir, or buttons
                      there is a fix for the remote-control in that topic (u have to change the code)
                      so, fresh install, no additions/changes, does it run ok?
                        joberbroeckling
                        If I do a fresh install and add the same modules (except remote-control) I had before it crashes. So I am not sure how to test which module is causing the issue.
                          @joberbroeckling disabled all the modules u added,
                          add
                          disabled:true.
                          to each module section
                          module:?????,
                          disabled:true,
                          pm2 stop 0
                          one at a time, change true to false, restart mirror
                          npm start dev
                          if it works, ctrl-c to kill mirror, edit config, enable next
                          and repeat
                          if it fails, see the terminal window and developers window, console tab for errors
                          ctrl c on terminal window to exit
                            joberbroeckling
                            I think I figured out what the issue is. It has to do with the MMM-WatchDog and the interval was too low. It was previously set to 10s. I upped it to 30s and it hasn’t restarted since.
