Black screen after update 2.11 (electron)
@Blackmirror did u npm install in the folder first?
yes i have
@Blackmirror what node version are you one
node -v
it is v6.10.2
@Blackmirror hm… you should be on v 10.??
how did u upgrade? and from what version?
I have only git pull yesterday in cd Magicmirror and in all modules npm install.
After this I get a black screen so I have rebuild electron in cd magicmirror and all modules. and npm install again. -
@Blackmirror said in Black screen after update 2.11 (electron):
and npm install (in base and module folders) (as this will copy down new files based on the MM changes)
and THEN
electron-rebuildAND you did npm install in MagicMirror folder, BEFORE all modules
yes. first cd magicmirror after this the modules
@sdetweil maybe run my upgrade script …
from here
https://github.com/sdetweil/MagicMirror_scriptsbash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force -
@sdetweil said in Black screen after update 2.11 (electron):
bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
ok. Now I have no black screnn but the mirror say i must install a config.js, but my old config.js is in the folder.
