    Black screen after update 2.11 (electron)
    24 Posts 2 Posters 5.7k Views 2 Watching
      Blackmirror
      it is v6.10.2
        sdetweil @Blackmirror
        @Blackmirror hm… you should be on v 10.??
        how did u upgrade? and from what version?
          Blackmirror
          I have only git pull yesterday in cd Magicmirror and in all modules npm install.
          After this I get a black screen so I have rebuild electron in cd magicmirror and all modules. and npm install again.
            @Blackmirror said in Black screen after update 2.11 (electron):
            and npm install (in base and module folders) (as this will copy down new files based on the MM changes)
            and THEN
            electron-rebuild
            AND you did npm install in MagicMirror folder, BEFORE all modules
              Blackmirror
              yes. first cd magicmirror after this the modules
                @sdetweil maybe run my upgrade script …
                from here
                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                  Blackmirror
                  @sdetweil said in Black screen after update 2.11 (electron):
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
                  ok. Now I have no black screnn but the mirror say i must install a config.js, but my old config.js is in the folder.
                    @Blackmirror how did u start mm??? pm2 or npm start?
                    open the developers window, ctrl-shift-i on keyboard, select the console tab, and scroll up to find any errors (usually red text)…
                    this same error is displayed in a module crashes hard
                      Blackmirror @sdetweil
                      sorry i have not all // delete from the MMM-Buttons module. It the same blank mirror.
                      At I get the same errors in the MMM-Buttons module after npm install. Your script have not wrote that it is make npm install at the MMM-Buttons module
                        MMM-Buttons
                        it should, there is a package.json file present…
                        please show me upgrade.log
                        ~/MagicMirror/installers/upgrade.log
