    Black screen after update 2.11 (electron)
    24 Posts 2 Posters 7.2k Views 2 Watching
      sdetweil @Blackmirror
      @Blackmirror did u npm install in the folder first?
        Blackmirror
        yes i have
          @Blackmirror what node version are you one
          node -v
            Blackmirror
            it is v6.10.2
              @Blackmirror hm… you should be on v 10.??
              how did u upgrade? and from what version?
                Blackmirror
                I have only git pull yesterday in cd Magicmirror and in all modules npm install.
                After this I get a black screen so I have rebuild electron in cd magicmirror and all modules. and npm install again.
                  @Blackmirror said in Black screen after update 2.11 (electron):
                  and npm install (in base and module folders) (as this will copy down new files based on the MM changes)
                  and THEN
                  electron-rebuild
                  AND you did npm install in MagicMirror folder, BEFORE all modules
                    Blackmirror
                    yes. first cd magicmirror after this the modules
                      @sdetweil maybe run my upgrade script …
                      from here
                      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                        Blackmirror
                        @sdetweil said in Black screen after update 2.11 (electron):
                        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
                        ok. Now I have no black screnn but the mirror say i must install a config.js, but my old config.js is in the folder.
                          @Blackmirror how did u start mm??? pm2 or npm start?
                          open the developers window, ctrl-shift-i on keyboard, select the console tab, and scroll up to find any errors (usually red text)…
                          this same error is displayed in a module crashes hard
                          B 1 Reply Last reply
                            Blackmirror @sdetweil
                            sorry i have not all // delete from the MMM-Buttons module. It the same blank mirror.
                            At I get the same errors in the MMM-Buttons module after npm install. Your script have not wrote that it is make npm install at the MMM-Buttons module
                              MMM-Buttons
                              it should, there is a package.json file present…
                              please show me upgrade.log
                              ~/MagicMirror/installers/upgrade.log
                                Blackmirror
                                Yes it have it.
                                I can not open the log file.
                                No authorization.
                                S B 2 Replies Last reply
                                  @Blackmirror eh? was created in user name running the script
                                  please do
                                  ls -laF ~/MagicMirror/installers
                                  show results
                                    Blackmirror @Blackmirror
                                    Okay works if it run in single steps
                                    Upgrade started - Sa Apr  4 17:52:55 CEST 2020
                                    system is Linux Mirror 4.9.22-v7+ #987 SMP Fri Apr 14 23:23:05 BST 2017 armv7l GNU/L$
                                    the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Rele$
                                    user requested to force apply changes
                                    doing test run = false
                                    saving custom.css
                                    remote name = origin
                                    upgrading from version 2.11.0 to 2.11.0
                                    fetching latest revisions
                                    git fetch rc=0
                                    current branch = master
                                    On branch master
                                    Your branch is up-to-date with 'origin/master'.
                                      (use "git add <file>..." to update what will be committed)
                                      (use "git checkout -- <file>..." to discard changes in working directory)
                                            modified:   package.json
                                    Untracked files:
                                      (use "git add <file>..." to include in what will be committed)
                                            core
                                            css/save_custom.css
                                            modules/default/compliments/compliments.json
                                      @Blackmirror there should be more
                                        Untracked files:
                                                core
                                                css/save_custom.css
                                        no changes added to commit (use "git add" and/or "git commit -a")
                                        there are 1 local files that are different than the master repo
                                           package.json
                                        save/restore files selection = y
                                        Saved working directory and index state WIP on master: 447c0bf Merge pull request #1968 from MichMich/develop
                                        HEAD ist jetzt bei 447c0bf Merge pull request #1968 from MichMich/develop
                                        test merge result rc='' , if empty, no conflicts
                                        executing merge, apply specified
                                        merge result rc= 0
                                         Already up-to-date.
                                        processor architecture is armv7l
                                        > magicmirror@2.11.0 install /home/pi/MagicMirror
                                        " && cd vendor && npm install --loglevel=error
                                        > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                                        > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                        > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                                        > echo "Installing fonts ...
                                        " && cd fonts && npm install --loglevel=error
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        npm WARN ws@7.2.3 requires a peer of bufferutil@^4.0.1 but none was installed.
                                        npm WARN ws@7.2.3 requires a peer of utf-8-validate@^5.0.2 but none was installed.
                                        npm install completed - Sa Apr  4 17:54:21 CEST 2020 on base
                                        downloading dumpactivemodules script
                                        processing for module MMM-Carousel please wait
                                        processing complete for module MMM-Carousel
                                        processing for module MMM-Podcast please wait
                                        > Magic-Mirror-Module-Podcast@1.0.1 postinstall /home/pi/MagicMirror/modules/MMM-Podcast
                                        > electron-rebuild -e ../../node_modules/electron
                                        - Searching dependency tree
                                        ✔ Rebuild Complete
                                        processing complete for module MMM-Podcast
                                        processing for module MMM-DWD-WarnWeather please wait
                                        processing complete for module MMM-DWD-WarnWeather
                                        processing for module MMM-Todoist please wait
                                        processing complete for module MMM-Todoist
                                        processing for module MMM-FRITZ-Box-Callmonitor please wait
                                        processing complete for module MMM-FRITZ-Box-Callmonitor
                                        processing for module MMM-RadioDe please wait
                                        processing complete for module MMM-RadioDe
                                        processing for module MMM-Fuel please wait
                                        npm WARN eslint-config-airbnb-base@11.1.3 requires a peer of eslint@^3.19.0 but none was installed.
                                        npm WARN eslint-plugin-import@2.2.0 requires a peer of eslint@2.x - 3.x but none was installed.
                                        processing complete for module MMM-Fuel
                                        restoring custom.css
                                        removing git alias
                                        we stashed a set of files that appear changed from the latest repo versions. you should review them
                                        Upgrade ended - Sa Apr  4 17:55:24 CEST 2020
                                        Upgrade started - Sa Apr  4 17:57:51 CEST 2020
                                        system is Linux Mirror 4.9.22-v7+ #987 SMP Fri Apr 14 23:23:05 BST 2017 armv7l GNU/Linux
                                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 8.0 (jessie) Release: 8.0 Codename: jessie
                                        saving custom.css
                                        git fetch rc=0
                                        On branch master
                                        Untracked files:
                                                core
                                                css/save_custom.css
                                                installers/stashed_files
                                        nothing added to commit but untracked files present (use "git add" to track)
                                        no files different from github version
                                        merge result rc= 0
                                         Already up-to-date.
                                        npm install completed - Sa Apr  4 17:58:55 CEST 2020 on base
                                        no modules found needing npm refresh
                                        removing git alias
                                        Upgrade ended - Sa Apr  4 17:58:55 CEST 2020
                                          @Blackmirror can u show me the config.js section for MMM-Button?
                                          my code (dumpActiveModules.js) lists out the modules that are enabled…
                                                 module: 'MMM-Buttons',
                                            //                        classes: 'default everyone',
                                                minShortPressTime: 20,
                                                bounceTimeout: 10,
                                                         buttons: [
                                                         pin: 10,
                                                         longPress: {
        notification: "CURRENT_PROFILE",
        payload: "default"},
                                                         shortPress: {
        payload: "Radio"}},
                                                        pin: 11,
                                                        longPress: {
                                                          notification: "BUTTON_PRESSED",
                                                          payload: true
                                                       shortPress: {
                                                          payload: true
                                            But I think it have not update the MMM-Buttons because it was out comment.
                                            I have your script restarted at now it comes the same error codes as I start npm install in the MMM-Buttons module
